Question about Nokia Consumer Headset
Hi does anyone have any step by step instrcutions on how to replace the whole facia for the Nokia N95 8gb?
  • 906 Answers
Good day,
hope this link below answer your query.
nokia
Posted on Jul 28, 2010
    Sniper:
  • 87 Answers
1. Slide the phone upwards and remove the two screws.
2. Slide the phone the other way and remove the other two screws.
3. Using a plastic pryer, remove the front cover.
4. Lift off the ribbon cable off the lcd screen carefully and remove it from its holding (keep it in a safe place for installing it later on)
5. Using the plastic pryer, lift off the back cover off the phone.
6. Unscrew the 4 metal screws to take off the top part where the power button is and the bottom part where the battery/usb part is.
7. Install the housing and put everything back in order.
Cheers.
Posted on Aug 15, 2009
Disassemble Miele fascia panel and control
There' s three reasons I can think of for removing a facia plate.
1- replacing a damaged original
2- accessing the control module
3-changing the language
On older models you may have to unplug the unit and remove the top to access screws that hold the facia housing. Then remove the housing to access the facia.
On newer models the screws were placed under the facia so the techs' don't have to remove the top.
Use a plastic paint scraper thin enough to get in between the facia and the housing. Pick a spot along the top or bottom and push straight into the gap. You can only go in about 1 mm until you stop. While still holding pressure inward pry the tool's back end away from the facia - up if your in the top edge or down if your in the bottom edge, until you access the inner step of the housing. Once your tool slips past the step, slide the tool left or right to find the locking tabs and pop them open. The facia will bend a bit. Watch that you don't drop it or it may scratch. The first is the hardest so be vigilant.
If you bought a new Miele Facia panel you should call their customer service support team. That's what they are for. They will be glad to guide you by telephone.
If your just curious to see what's underneath don't bother, unless you like looking at mounting screws for the plastic housing.
Nov 07, 2014 | Washing Machines
I have just moved into a new home with Ariston FB 52 IX AUS and there is no manual and the pictures around the knobs have been rubbed off could someone please help me. thanks
Hi we are in the same situation and phoned the NZ office that deal with Ariston and they stated that is costs $136 to replace the facia panel. She stated she would send me a manual a week ago and still nothing. She stated that there are no Ariston facias in Nz and they don't know when they are coming or if they are going to be coming in. Would definately not buy an ariston oven.
Good luck to anyone else in the same position, I wish I knew what each dial was for on mine.
Maree.
Mar 29, 2013 | Ovens
Install panel facia on bosch dishwasher
You should be able to google your model number and get step by step details.
Jan 28, 2013 | Bosch Dishwashers
What is the cost of nokia 2730 facia ?
The approximate rate is $7.14 as on 04/05/12.
May 03, 2012 | Nokia 2730 Cell Phone
Detachable face does not work.
Unfortunatley, detachable facias do fail from time to time.
The important thing is to ensure the facia is locking "tightly" to the head unit and making good contact with the copper pins.
If your model facia is not the pin connection type, but has the ribbon cable, then the ribbon cables are easily relaceable (these were a common repair item).
If there is an internal issue with your facia, then have it checked for "dry joints" - this is where over time, a solder joint has dried up and not making proper contact.
Whichever repair is required, always price up a replacement facia first, as this is sometimes cheaper than paying someone to inspect and repair your faulty facia.
Cheers,
Jun 14, 2011 | Dual Electronics XDM6400 CD Player
Hi I am trying to remove plastic facia to swap out keyboard - i have prised the plastic hinge covers off but the plastic facia seems to be fized at either end near the speaker grills ..would appreciate if...
Hi
Click on this link and it should take you to the website to download the manual
you will need adobe reader installed to be able to read it
and click save then save it to your documents or desktop or a spare drive
for future reference
http://www.pc-ap.fujitsu.com/support/index.html
good luck
please let us know if this was helpful
Jan 24, 2011 | Fujitsu LifeBook S7020 Notebook
How do i replace the touch screen on my nokia 5800
Please take your Nokia 5800 to a Nokia center for replacement of screen. That's the only thing you can do for your screen.
Hope this helped.
Regards
Aug 13, 2009 | Nokia 5800 XpressMusic Smartphone
Installing new steroe
No it is not necessary to remove whole dashboard. AUDIO UNIT 1. Disconnect negative battery terminal. 2. Remove center facia panel.c984350.gif
May 30, 2008 | 1996 Hyundai Sonata
FACIA
If you have the new facia cover it is easier than you think. Take a flathead screw driver and gently start lifting the facia up from the key pad.
May 23, 2008 | Nokia N73 Cellular Phone
Nokia Consumer Headset Logo
Top Nokia Radio Communications Experts
shaun taylor
woodzowl307
Are you a Nokia Radio Communication Expert? Answer questions, earn points and help others
