Question about Memorex MLT3221 32 in. LCD TV
TV will not turn on. Went dead shortly after turning on can't get it to turn on again. Seems like it is not getting AC. Yes its plugged in and there is juice to the socket.
I have a Memorex ML TD 3222 flat panel TV less than 6 months old. Two days ago I turned the TV on using the remote control. It came on for a second and then went dead. I could not get it to come back on using the remote or the switch on the TV. It doesn't appear to be receiving AC at all, as if it blew a circuit breaker or some relay tied to the AC line. What do you think? Rufus Graves
  • jeffro195710 May 25, 2009
    I have the same problem with mine which is about a year old. Able to determine that AC is getting to the power supply pcb and that the fuse on the pcb is good. It appears the power supply pcb is dead.
    Trying to find a schematic for the pcb or a new one>
If the red ring in front of tv is not lit when it is plugged in it is probably the power pcb. I just ordered one from searspartsdirect.com part # 860-AZO-IPOS150H FOR $45 plus shipping. installed today and everything is fine.
Posted on Jun 20, 2009
Tv turns off by itself, three times in past two days, would come back on by itself now it went off and can't turn back on
The dam main board the tv Tuner signal board was dying and now it is dead.Tv now still have power light LED indication it is on just no picture wright?Yes.This tv the Tuner signal board is it dead.Can u do some basic mechanical work like take thing aparts and putting it back together again?Yes,tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish tv Tuner signal board for the replacement.Or the shops will cost u a little more than half of a new tv to service by them,because this tv,the main board it is dead,not serviceable only replaced that it.
Jun 12, 2011 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Yesterday I started having problems turning the tv back on with my remote. I noticed the power indicator blinked 10x in a row then it would pause in the off position, then start blinking again. I ended up...
Take the tv aparts.The board where the power ac cord plug into it.That ur power supply board.Check all around the power supply board and it supporting boards for these dead parts call capacitors,they're alway bulges up on it tops or puff up on it tops,u know basic electronic's and do soldering replaced those dead bulges or puff up on it tops capacitors.Or tries websites like Shopjimmy.com,Ebay.com to buy a refurbishes power supply board and it supporting boards that have dead leakage capacitors.Ur tv should have power stable and work again.
Jun 10, 2010 | Panasonic Viera TH-46PZ85U Plasma TV
The power went off at my house due to an overload and when the breaker was turned back on, the tv had no power, no green or orange light. I unplugged the power cord and plugged it in later and the tv...
The power supply board is dead,that the board where the power cord plug into it.Take ur tv aparts,replaced the power supply board,ur tv should work again.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
May 23, 2010 | Vizio L32 32 in. LCD HDTV
MY TV HAS NO POWER I CHECKED THE FUSE IT SEEMS
hello have you checked the glass fuse inside the tv it will be in the power supply beware if replace the and blows again the you have a dead short circuit
regards
shaun
Apr 09, 2010 | Samsung HCN4226W 42" Rear Projection...
My panasonic rear projection tv will not power on and no lights turn on. Any suggestions?
Please plug TV in another power source and turn it ON,
if still does not turn ON, unplug AC wire of TV, take off back cover and follow AC cord f TV that will take you in power supply board, find fuse nearby and check is it blew off? if yes, replace it with same ratings written on it.
Plug TV in AC wall socket and turn ON, if fuse blow again that means power supply section in TV got problem and need qualified tech to find out and replace components or power board.
Thanks.
Sep 18, 2009 | Panasonic PT-56WX53 53" Rear Projection...
Turn headlight arm off and buzzing sound under the hood
change the part that its not comfortable in yore buzzer
May 02, 2009 | 1993 Honda Accord
Sony 46" lcd turns off by itself and will not power up again.
if your tv unit is still under warranty, first you better bring it back again to the store you just bought it for warranty purposes, your tv has an internal problem, maybe manufacturer defect. Usually the cause of that is a shorted electronics component, say for ex, a mosfet transistor that is located at the power section, or maybe a capacitor that is leaky, and also an open resistor. if you don't know how to troubleshoot this problem, you better have your tv unit repaired by a professional tv technician.
Good luck
Jan 22, 2009 | Sony KDL-46S4100 46 in. LCD TV
TV seems to be dead
Yes with an LCD it can be dead. The life of LCD is not nearly that of a tube TV. It depends on the hours of use. Most likely time to replace it.
Good luck,
Lee
Jun 16, 2008 | Televison & Video
Tv screen goes black
No, if the picture of your tv screen is clear when when you watching. the troble of your tv is looseboard, and you replace your CRT socket too.
Apr 16, 2008 | Sony KV-35V35 TV
Toshiba Satellite A15-S129 PC Notebook will not turn on
I have the same problem. What I have found with mine is that if I can get the battery to take just a little charge then I can get it up and running. Here is how I do it. Disconnect AC power leave the battery in and start the laptop. As soon as thing start to run I plug the AC back in and it works fine from there on. Now mine is flashing as well now and I have a dead battery and it will not restart. Something I have noticed thought is it appears that the yellow light is blinking a code. This is what I have come up with. I appears to be flashing 323 as the code or could be 2 shorts 1 long then 2 shorts and then 3 shorts.
Anyone know where to find info on these flashing codes.
Thanks
Oct 30, 2007 | Toshiba Satellite A15-S129 Notebook
Memorex MLT3221 32 in. LCD TV Logo
1,380 people viewed this question
Top Memorex Televison & Video Experts
 Grubhead
Grubhead
Radames Pagan
Radames Pagan
Are you a Memorex Televison and Video Expert? Answer questions, earn points and help others
