Question about Vantec NexStar-3 External 3.5inch SATA&USB2.0 Hard Drive Enclosure (Black) (NEWITEM58149860) Drive Case
My computer doesn't recognize my Nexstar 3 external hard drive?
I'm on Windows Xp and before it worked fine, I plugged it in and right away it would show up in My Computer as E: and F: drives and "autoplay" would come up. Now when I plug it in, my computer shows the notification like it is plugged in, but doesn't show anything in My Computer, doesn't let me run the drives, and they don't show up in Disc Management.
Any help would be greatly appreciated as it is my backup drive with everything important on it.
3 Suggested Answers
fire sine
  • 382 Answers
SOURCE: Nexstar External drive
If neither computers detect it, which is a good form of process of elimination, I would test the cable with a known working. I would then extract the drive from the enclosure. And try mounting into a desktop machine as a slave, or find another enclosure.
Posted on Oct 22, 2007
wuntwowun
SOURCE: Computer not detecting NexStar 3 USB 2.0 External hard drive
I'm not a computer expert so I won't use too much tech language but after months of dissapointment, I finally got my NexStar 3 to work and it was actually easy!
At first I thought it was a driver problem so I tried to find a driver on line or in the disc provided (it wasn't neccessary as I run windows XP).
Then I actually opened the disc provided and found the PDF manual and opened that for a read (maybe the answer was in there?) Yep!! It has the answer you are looking for. Part of this manual 5.2 describes that "a partition is required" if the hard drive does not appear under My Computer.
To do this you:
Right click on your "My Computer" icon and choose "Manage",
Under "Storage" on the LEFT pane, select "Disc Management",
Find the drive (mine was around 300GB so I knew it was the one) at the bottom Left and "Initialize" the disc by clicking on "not initialized",
Then in the bottom RIGHT Pane, where the status bar is, Right click and choose New Partition,
Follow the directions from the Wizard. (Recommended partition type is "Primary" and file type "NTFS".
When this is done you should see your drive under My Computer.
NOTE: This formatted around 23GB on the newly created "E" drive I selected.
After this, by Right clicking the other unallocated area of the drive I went on to format the rest of the drive as a "F" drive which contains the other 256GB.
Hope this helps!
Keith in South Australia.
Posted on Sep 20, 2008
Vantec Nexstar 3 driver download
Vantec Nexstar 3 drivers can be found at driverupdate us.Take a look, and enjoy
Apr 04, 2010 | Vantec NexStar-3 External 3.5inch...
I have a NexStar 3 external hard drive that is not being recognized by my computer. It used to work now it gives an unknown device message
remove the hard drive restart your computer the plug the hard drive back into your usb port this should come up with new hard ware found and install the driver If not try a different usb port or your sata drive
Mar 30, 2010 | Vantec NexStar-3 External 3.5inch...
Windows 7 NexStar drivers and installation needed
No device-drivers are needed. Just connect this USB device, and Windows will recognize it. If there is a "one-touch-backup" button, it won't work, but you can still use drag-and-drop to copy files from your internal disk-drive to this external disk-drive.
Jan 01, 2010 | Vantec NexStar-3 External 3.5inch...
Can my Vantec NexStar 3 Hard drive SAVE?
You might want to take the drive out of the case and use and external drive connector to see if the drive still works.
https://www.amazon.com/Drive-Adapter-Converter-Optical-External/dp/B002OV1VJW
Sep 02, 2017 | Vantec 1 Bay NexStar 3 USB 2.0 External...
Nexstar.3 Sata external drive woun't start
I also have the same problem. I bought a 500gb WD HDD and it worked great via USB for about 4 days, not the computer does not have it. i am running windows xp home. i can also hear the drive working and the blue light comes on, but it is delayed. When it was working correctly it came on instantly and the computer found it instantly.
May 19, 2008 | Vantec NexStar-3 External 3.5inch...
Nexstar IDE to USB, Will Not Show Up
Hello
Have a look at the link below, it should be of help.
Click HERE to navigate.
Please feel free to let me know of you have any further questions.
Kind regards
Lock123
Apr 06, 2008 | Vantec 1 Bay NexStar 3 USB 2.0 External...
Oct 04, 2007 | Vantec 1 Bay NexStar 3 USB 2.0 External...
Sounds to me like driver related problem. Download this tool: Driver Update and update the drivers. Have a nice day
Tom
Sep 27, 2007 | Vantec 1 Bay NexStar 3 USB 2.0 External...
Computer not recognizing it
if as you say its working fine is pc accessing drive via usb and have you set the jumper to master as most external enclosures work on the device being master if you can see the hdd on pc then the laptop needs to have windows re-installed but if the pc is not showing hdd then goto control pannel and Administrative Tools and Computer Management and then Disk Management if showing here then select unallacated drive and properties and set active. then turn of drive then turn back on and see if comes up in my computer. only do laptop if pc has hdd viewing in my computer. hope all goes well
Apr 08, 2007 | Vantec 1 Bay NexStar 3 USB 2.0 External...
Vantec NexStar-3 External 3.5inch SATA&USB2.0 Hard Drive Enclosure (Black) (NEWITEM58149860) Drive Case Logo
710 people viewed this question
Top Vantec Computers & Internet Experts
Arora Singh
Arora Singh
Willem.
Willem.
Piyal Perera
Piyal Perera
Are you a Vantec Computer and Internet Expert? Answer questions, earn points and help others
