My picture is cut off at the top, how do i shrink it horizontally.?
  • 35 Answers
Depending on the television
inside the TV
there might be vertilce center adjust, and or a verticle height adjust pot
if not an advance engineering technician could modify a fixed resistor and or capacitor in the vertil scan ic circuit.
also the deflection coil could be pushed up against the back of the CRT more tightly.
the H and V deflection fields change their focal distance ... and if the coils are slid back away from the crt face, the top and sides get cut off..
only and expert should ever consider such adjustments and anyone going inside of a tv should take great caution, as there a hihg voltages present that can kill.
Ed
Posted on Apr 14, 2009
Picture cut off on sides, how do i shrink picture to screen?
If model listed is correct the problem is in power supply or vertical or horizontal circuits.
If cut off on sides (horizontal) and bowed on sides it is a pincussion problem. IF short top and bottom a vertical issue--if both it is in the power supply.
Model listed is rather old and parts may not be available for it.
May 30, 2012 | GE 35GT740 35" TV
Panasonic TX-68PS12A Picture shrinks in vertical direction at top and bottom over period of 15 minutes until vertically compressed picture occupies approx 1/3 of the screen in a central band
Ur Vertical/Horizontal ic is cold solders,U know how to solders?Take the tv aparts use a back handle of the screw driver tabs around find out where V/H the cause resolder that.
Oct 22, 2009 | Televison & Video
Pictures shrinks.. Panasonic TC-20LM Television
Shrinking picture is a voltage regulation problem in the switch mode power supply, Possibly a cap used in the feedback circuit. Or an over current condition on the B+. This is a very tech intense repair because there is no magic bullet. If it is shrinking on bright scenes then you can bet it is a regulation problem, bright scenes draw more current from the power supply causing this effect. I would not suspect the horiz output because the regulation for this circuit usually comes from the main switch mode power supply. One diagnostic is to monitor the B+ going to the horizontal output and see if it fluctuates. If so you can bet it is a cap or optical coupler in the switch mode circuit.
Oct 10, 2009 | Panasonic Televison & Video
My picture shrinks
resolder the vertical deflection i.c. also replace elecrolytic capacitor in the vertical circuit.
Sep 28, 2009 | Hitachi 50UX57B 50" Rear Projection...
No picture, has sound
This problem usually lies on the horizontal output transistor, try to check also for shorted diode. you can buy ftom any electronic parts dealer or radio shacks stores
Jul 27, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Picture shrinks horizontally every few seconds.
You are changing parts in the wrong circuit. The problem is in the vertical circuit. Look for the vertical IC and resolder the pins first. It should be an LA7837 or something similar. Also, check the 100ufd and 47ufd caps in the same circuit.
Keep us posted.
Dan
Jan 19, 2009 | Panasonic CT-20G11 TV
RCA tv model F32649 white horizontal lines
the problem of your tv is in vertical section, to be sure change all the capacitor in vertical section.
Sep 27, 2008 | RCA F32649 32" TV
GE 31
check electrolitc capacitors in horizontal circuit
May 09, 2008 | GE 31GT659 31" TV
Shrinking picture
All symptoms indicate a problem in the vertical circuit,the first thing to look for will be loose conection on the vertical output IC,sometimes this IC goes bad completly and it needs to be replaced.If you are familiar with soldering electronics you can take care of it but if you are not too familiar you can play it safe and take it to a servicer ,it will be a lot less expensive than if they come to your house.Let Us know how it goes or if you need more information.
Oct 26, 2006 | Quasar SP-2722 27" TV
Picture Shrinks
It is in the power supply or I would guess most likly in the horizontal sweep section of the tV set. MOST of the time, if the power supply is going lower in voltage, the set will shrink in width,BUT will also shrink in vertical size. If this is not happening, then I would say it is in the horizontal drive circuit. This is not a circuit a user should be experimenting with, as this is the HIGH VOLTAGE circuit and can pack a mean punch! Please if the sets less the 4 to 5 years old you may want to concider an estimate or replacing the set. Its all up to you. GOOD LUCK
Oct 07, 2006 | Philips 8P6034 TV
Televison & Video Logo
131 people viewed this question
Top Televison & Video Experts
Electro Med Services...
