Question about LG DLG5932W Gas Dryer
Did you resolve your dryer / noise?
I've got the same dryer also about 3 yrs old that's never been moved but it makes the same loud thump each time the drum makes a rotation. Have you found out what may be causing this yet?
Regards.
v-tch@hotmail.com We have the same problem, our LG gas dryer is less than 2 years old and we just figured out the the Drum is cracking at the seam.  It just started making a thumping noise like it is off balance.  This is a design flaw.  A $1000.00 dry should last a lot longer than 2 years!  I am upset.
  • Anonymous Apr 22, 2009
    Our LG dryer drum is also cracking at the seam and LG will not cover the repiar. Has anyone had any luck with LG covering the repair??? The dryer is less than 2 years old, but no longer under warranty. The repair estimate is $400. A thousand dollar dryer that is less than 2 years old should not need a $400 dollar repair! Am am so upset about this.
  • Anonymous May 01, 2009
    I have a just over 2 year old LG Tromm model DLE8377NM that is making horrible noise each time it makes a rotation also. It still works...just sounds bad so far...but started making somewhat of a metal on metal sound now too. Where do you look to find cracks? Why would it cause a thumping noise? I thought one of the rollers may be bad...anyone else got any ideas?
  • LG Master
  • 43,501 Answers
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
7687t
Posted on Sep 30, 2010
Dryer is making loud grinding noise when in use. The sound is more prominent when loaded. Model # LDE9304ACE, well over 10 yrs old. Is this noise my motor or my pulley?
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Feb 01, 2011 | Maytag Dryers
Dryer drum coming apart (tore some of my clothes). Loud thump, thump for several weeks, now it won't even turn. It is only about 3 yrs old, should never have done this and it is not under warrenty that I...
heatman101
Dec 16, 2010 | Samsung Dryers
New dryer makes a loud thumping full or
I hope he did nt charge you. Because of the seam in a dryer drum, they do make a slight thumping noise but it should not be real loud. I hope the tech took the dryer apart and checked the rollers. One of them may have a flat spot.
I would ask for a factory represent ive to come out and see if they think they would want a dryer in there home that make that much noise.
Please rate solution
Sep 03, 2009 | Dryers
Dryer has thumping noise.
Yes that is what most likely is the problem to begin with. The drum usually never goes out of round . Replace bearing best choice
Aug 28, 2009 | Dryers
Frigidaire Dryer making loud thumping noise in back.
Some things to check.
Worn rear drum rollers, idler pulley, or drum front slide kit.
Click here for illustrations.
Hope this helps.
Aug 12, 2009 | Frigidaire GLEQ2152ES Electric Dryer
GE Clothes dryer squeaks
My ge electricryer sqeaks very loud and makes a thumping noise. it just started a cuouple of weeks ago.
Jun 19, 2009 | GE DWXR483EBCC Electric Dryer
Kenmore heavy duty
I can only assume by rollers you mean bearings were replaced. Unless your dad measured both the ID Fit of the bearing and the OD fit [ inside diameter and outside diameter of the shaft and housings] new bearings could be on the small side of their tolerance, [new bearings are made to be within a certain amount of "slop" if the new bearing was on the outside tolerance, and the shaft or housing was on the large side of the tolerance, the bearings are still allowing the drum to move, and thump.
OR if belt driven, the alignment of the belt is important, if one pulley is out, and the other in, one shaft will be pulling and the other pushing, again a thump.
Something in the bearing/pulley setup has not been discovered bad yet, it takes micrometers and some knowledge of bearing tolerances to resolve this kind of problem.
Think about it, what can thump in a dryer? The tumbler cage. It is most likely that the journal or housings are wore, second the motor may have a front or rear bearing/ housing the same thing, gone bad,
This machine is old enough I would expect to find a worn housing or shaft, either drum or motor,most likely drum, check the alignment of the belt also, but most likely the thump is not cost effective to repair, plus Dad's time which is invaluable.
Start searching the sale sheets, and reading consumer reports, time for a new energy easy dryer anyway.
Will
Sep 16, 2008 | Kenmore 63942 Dryer
Noisy drum
You may have a rear drum support issue. There are 2 rollers,(supports), 1 at 4 o'clock and 1 at 7 o'clock. If the bushing in the roller becomes elongated,(elliptical), it will give a thumping noise, as you describe.
Below is a link with exploded diagrams and parts help.
http://www.repairclinic.com/0100_14.asp
Please rate my answer on how helpful it was in resolving your issue.
Thank you,
Dave E. (Illeagle)
Jun 16, 2008 | Whirlpool Dryers
You have a problem with your dryer drum.  The seam weld has cracked and the drum needs to be replaced.  You will need to call a qualified LG technician to resolve this issue.
Apr 15, 2008 | LG DLE2532W Electric Dryer
LG DLG5932W Gas Dryer Logo
375 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
