Question about Coleman Mach III Air Conditioner
I have a coleman mach roof top ac unit (8000 series)and the thermostat that came with it is a electronic single stage heat/cool thermostat. I am wondering if the atwood excalibur thermostat can replace the one i have now? it looks like the atwood excalibur will automatically turn the fan on the ac unit to circulate air when i set the thermostat temp, right?
    Brigadier General:
  • 3,614 Answers
it is possible to replace it with the same model and part# to meet the compatibility of the unit..
Posted on Apr 14, 2009
Btu of coleman 7830-901
That should be a 30,000 Btu unit. Its been a while since I worked on them. The 78 is the series or model, the 30 is the capacity or btu's and the 901 indicates it is a Copeland compressor.
Jun 09, 2014 | Coleman Air Conditioner Shroud Rv Roof Top...
Coleman 8000 fan works not cooling or heating
sounds like the compressor is not running. the controller (thermostat) may be at fault, or there may be a wiring problem, either in the lower unit or probably in the upper section.
May 13, 2014 | Coleman Mach 15 Air Conditioner
Coleman mach rv roof ac, the fan comes on but the compressor doesn't, i've replaced all capacitors and stll is not comming on, how do i check voltage to the compressor to maske sure i have pow
At the compressor connectors you have a live and a neutral phase. The live usually goes to a ptc relay starting mechanism which you can test with a meter. If you can disconnect the relay and check the windings of the compressor from one pin to the other two it will tell you if the compressor is open circuit. It is more often than not an overload fault.
Apr 23, 2012 | Coleman Heating & Cooling
Coleman roof top a/c, is the heat controlled by thermostat
hi
on the new colman units (trane) the heat is control only from the t-stat.
i will reccomand a programble t-stat for the new unit.
thanks
Nov 02, 2009 | Coleman Mach III Air Conditioner
My coleman 13,500 roof a/c year 2000 does not blow as cold as used to. I have cleaned the top condenser coils, with no help. It also at times will seem to pull a heavy load when I assume the compressor...
if the compressor started and stoped means
1 thermostat need settings
2 compressor over heated due to low suction pressure need to check and repair the leak then charge the freon
Sep 14, 2009 | Coleman Mach III Air Conditioner
COLEMAN MACH 3 MOUNTING ON INSIDE OF CAMPER NOT ALIGNING WITH MY
Did you purchase a new Ducted Ceiling Unit with the Upper Unit air conditioner? If you are replacing an older mach 3, the ducted ceiling packs are not compatible and you will need to purchase the ceiling pack as well. The ducted ceiling pack part number for the 8333 series Mach III AC is below.
1. Heat/Cool Air Distribution Box - 8330B735
2. Cool only ADB - 8330A733
3. Wall Thermostat (if needed) - 7330G3351
Hope this helps.
Jul 01, 2009 | Coleman Heating & Cooling
Coleman Mach III Air Conditioner Logo
117 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
paulcarew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
