Question about Toymax Magnavox 37MF331D 37 in. LCD TV
Magnavox 37mf321D HDTV won't turn on
I have a tv that's three years old here that's been having problems turning on for the last month, month and a half. it takes multiple pushes of the power button to get it to turn on, w/ the remote and the power button on the tv. It's been getting worse and I'm sure here soon it's going to stop working all together. I'm thinking it's the power supply but it would be easier and maybe even more possible if i could find a specific component that was giving me the problem. Any help would be appreciated including sites that are best for parts. thanks
  • B-rock32 Apr 15, 2009
    i actually figured it out if anyone wanted to know. it was a 2200uF capacitor that was bulging on the power supply. i got the capacitor on radioshack the voltage 50 instead of 25 what it was but i took a chance and threw it in and it's working now. the fix only took me a hour or so to finish.
It may be touching in the back of the tv on a power point. Yours is doing the same thing mine did before it finely all most burnt up it self and my house The metal casting that the tv mounts on in the tv ,does not have enough room in it. the metal casing touches one of the power supplys in the back and shorts out. If its like my 32'' magnavox flat panel
Posted on Nov 11, 2009
37mf321d won't turn on- no busted capacitors
Hey Superdave,
Does the whole tv turns off when the picture turns off ??? What you're describing sound like a defective CCFL backlight. This would make since why someone threw it out because the repair estimates of replacing the bulbs would knock your socks off. Most will suggest ordering a new LCD panel assembly which would cost way more than what the set is worth. On some sets, when a CCFL is out, the screen will come on for a few seconds then go out. On other sets, after so many "lamp failures" logged in memory, the set will not power up at all and just flash trouble codes through the power indicator.
May 07, 2012 | Philips 37MF321D 37 in. LCD Television
37MF321D/37 TV turned off last night. This morn, won't turn on
Please read these replies to the same problem. A new power board costs around $284.00..
http://www.fixya.com/support/t465280-magnavox_37mf321d_37
Jan 01, 2010 | Philips Magnavox 42MF521D/37 Television
My magnavox 52' hdtv won't turn on when you first
replace your STK ICs they are big black ICs will have part # on them call Mats 1-800-628-1118
Sep 19, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Magnavox LCD HDTV starts on its own since last few months and sometimes it changes channel on its own. This problem happens intermittently and really apprecaite fix for this. This TV is 15 months old.
it either needs new front switch panel or new signal module, turn the tv on and disconnect the front switch board if it quits doing things on it's own you need a new front switch panel, if it still does functions on it's own you need a new signal board.
Sep 08, 2009 | Philips Magnavox 15MF400T 15 in. LCD...
Tv went off and won' come back on.
Most likely you will have to replace the power supply. It is a very common problem especially in newer electronics. You can test it with voltmeter or multi-tester. They tend to get worn capacitor inside the power supply due to cheaper parts
Aug 24, 2009 | SNK Magnavox 32MD357B_37 32 in. LCD...
My magnavox 37MF321D/37 will not turn on. It
I had the same problem with the blinking green light. These are the parts one the power supply I replace to repair it. note: If the power supply is repaired you will get a solid green light and the backlight will light up almost immediately.
Aug 01, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
No video output from Magnavox VCR (MDV560VR)
You need to tune a chanel on your tv to the vcr signal, using an RF cable (aerial cable between vcr and tv). That is if your tv has an analogue tuner.
May 09, 2009 | Philips Magnavox DVD/VCR Dual Player
Magnavox 37mf321d/37 TV has no audio or video . Green light comes on but then goes out . Kind of like it want boot up.TV is 2yr old and last 10 times it took a long time to come on .I have onyko surround...
This is a internal problem,,,You need a repair
Please don't forget to rate me "FIXYA"...thank you!
Mar 04, 2009 | Televison & Video
14 MONTH OLD TOSHIBA TURNS OFF BY ITSELF
I repair a lot of these and a average tv lasts like 3 years . It is not like the old days. I suspect the lamp or fans or therm protector.
I would call a local tv shop see what they charge for estimate it might be worth his estimate to find out what it is.
Thanks doctor video
May 27, 2008 | Toshiba 52HM95 52" HDTV Projection...
Toymax Magnavox 37MF331D 37 in. LCD TV Logo
1,027 people viewed this question
Top Toymax Televison & Video Experts
matt martin
matt martin
CoppellTVRepair.com
Are you a Toymax Televison and Video Expert? Answer questions, earn points and help others
