Question about LG LFX25971ST Bottom Freezer French Door Refrigerator
Condensation and ice buildup
Our LG fridge, Model # LFX25971ST, has recently started to have excessive condensation around the ice dispenser. Additionally, every time we open the fridge door, there are drops of water. Those aren't the only problems including ice/frost buildup inside the fridge where the ice maker makes contact and the light switch in the freezer freezing in the up position and ice building up on it.
  • 183 Answers
SOURCE: Frost buildup on ice/water dispenser
Your problem is definatly caused by air entering freezer either from the ice shute flap or door not sealing correctly, try putting a bright torch in frezzer and closing door look for light escaping around edge of door, if you can see the light then change door seal, the fault cannot be anything else. Regards Advisor
Posted on Aug 30, 2007
applianceboy
  • 77 Answers
SOURCE: condensation problem hotpoint mistral 8596
if the door seals are both ok, check and see if she has any open containers in the fridge juice ect that may be allowing moisture to escape. a model number and serial nuber off the sticker in the fridge would help me with more ideas.
Posted on Sep 26, 2007
gaeb7
  • 25 Answers
SOURCE: Frost build up in the freezer section of my side by side Kenmore
Replace the defrost clock.
Posted on Feb 25, 2009
  • 28 Answers
SOURCE: Fridge Condensation
Check the seal of the rubber gasket, if there are improper seal of the magnet, pour hot water along it to soften the rubber. (be careful when handling hot water). When the rubber is soften, try to stretch it a little by pulling it. close the door and the magnet will keep the seal in place.
Posted on May 09, 2009
Sea Breeze
  • 4655 Answers
SOURCE: Condensation on the outside of the ice/water dispenser on freezer side.
Turn the water supply off to the back of refrigerator and take the line feeding the supply to the water control valves off and then put the line into a pan to purge any trash that may have collected before entering control valve. It is very possible that a piece of rust or a piece of plastic is holding the control valve open slightly. The continuous dripping of the chilled water is what I suspect is causing the condensate. On bottom of the refrigerator Sears uses a number like this example. You may find the number behind the cold food section door near floor. I will need that to help you better. Example 215.22897
Sears always gives their models a different number than the same models that GE, Whirlpool, Westinghouse and on and on. When you are able to see if the valve is stuck and need to clean or replace it we will need your model like in the example to find the correct part, Let me know, Thanks, Sea Breeze
Posted on May 16, 2009
What would cause my fridgidaire fridge to leak water
Condensation from ice buildup. Unplug fridge open door drop towels. Clean fridge completely. When no ice left plug I and resume. If it has water feed check for leaks
May 31, 2015 | Refrigerators
Why Samsung fridge has condensation around water/ice dispenser and drips every few hours?
Usually due to CONDENSATION due to bad door seals or a plugged evaporator drain line? Can use a soft flexable tubing and very hot water to clean it out. Bad door seals usually need replacement, but u can use a blow dryer and something to pry it closer to the door wall while blowing hot air on to it. To create a seal, to test for bad door seals place a dollar bill in between the door and wall of fridge where it closes. Then slide out the dollar bill with door closed. It should offer some resistance and not be easy to pull out.
Most all fridges have a drain. Look inside your fridge for a "V" shaped channel with a small hole. This hole leads to a tube and a small pan which sits on top of your refrigerator's compressor. The defrost cycle causes water to run into the channel, down the tube, and then it generally evaporates with the heat of the hot condenser/compressor.
However, if that tube is clogged with food crumbs, particles , debris etc, you will have to clear it to get back to a normal mode of operation. A toothpick, pipecleaner, straw or a cotton bud can often do the trick.
Even a frost free freezer will still ice up at times in the areas away from the heated defrost area and the drain line can freeze. This icing causes the pipe work to the compressor to ice over or sweat and cause a puddle. Or if the drainage has frozen over, it will need to be de-iced. ( usually the line is under the freezer bottom plate covering. Towards the back of the unit) And there is another inside the fridge area also.
Give the freezer a good overnight defrost until it's totally clear of ice in addition to making sure the drain is clear to the pan at the back and then
Jul 16, 2014 | Samsung 25 Cu Ft Capacity Stainless Steel...
Fridge leaking intermittently from the bottom
Sounds like your gasket may be going out. Consider replacing the gasket on the doors. Look for signs like small lines of frozen water that lead to the door or unexplainable excess ice in the bottom of the freezer.
I would also check for excess water in the condensation catcher tray, which may very well be located in the same spot under the ice maker. Depending on where you live (southeast, coastal, etc...) can have a strong contributing factor of having excess condensation, which will cause the tray to overflow.
Apr 25, 2017 | Kenmore Refrigerators
My refrigerator and freezer smells like chemicals
Your problem might be something caught in the water hoses going into your fridge and condensation is freezing around it
Apr 03, 2012 | Whirlpool Refrigerators
Frost buildup around icemaker, what cause this?
Either the auto-defrost timer is not working properly or there is a lot of moisture and condensation that is building up due to humidity.
Sep 22, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Leaks water in the refrigerator down the back under
Hello, this sounds like you have a blockage in the drain tube, remove panel back/bottom of freezer..you may see ice build up...melt ice with hair dryer/heat gun...you will see a pan below evaporator...melt ice in pan...dry water up in pan with paper towel...now you should see a hole in pan that leads to drain tube...pour some hot water in pan..wait a couple minutes..mop up water and repeat this step 2-3 times....once you have done this find some flexible curtain wire or electrical wire..poke down the hole until you see the water drain..now it is clear..put back panel back and you are good to go. The reason you see water in the fridge is because the water has been leaking into the freezer and down the vent into the fridge instead of running into the drain hole...Please feel free to comment again if you need any further assistance. Mike
Sep 15, 2009 | Hotpoint 18.2 cu. ft. Top Freezer No-Frost...
Fridge Condensation
May 09, 2009 | LG LRFC25750 Refrigerator French Door
LG LFX25971ST Bottom Freezer French Door Refrigerator Logo
300 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
