Question about Emerson Home
My dishwasher does not empty completely since I installed an Emerson E202 garbage disposal. I looked and it seems the spout where the dish washer connects to the disposal is not open. do i have to cut a hole in the opening?
  • 74 Answers
There is a knock-out plug inside of the disposal port.  A crewdriver, hammer and a few solid wacks should remove that completely.
If you already removed the plug, a piece may have been left in.
Posted on Apr 14, 2009
Garbage disposal quit working. Just stopped
Press reset button located on bottom of unit.
Use broomstick down inside disposal to make sure cutter disc rotates freely.
Copy following link for troubleshoot and illustrations:
http://waterheatertimer.org/How-to-repair-and-install-Garbage-disposal.html
Gene
h
Aug 19, 2013 | Emerson Evergrind E202 1/2 HP Garbage...
Leaking garbage disposal
1) Where is the leak coming from?
Copy following link for troubleshoot walk thru and replacement tips
2) Add a comment Feb 2013
Feb 10, 2013 | Emerson Evergrind E202 1/2 HP Garbage...
My dish washer leaks water
The hose from the air gap on top of your sink to the garbage disposer is plugged.or kinked probably.Unless you have a new garbage disposer and the plug wasn't knocked out at the dishwasher drain connection
Jun 23, 2010 | Whirlpool Gold 24 in. Built-In Dishwasher...
Dishwasher overflowed, garbage disposal still works. Ran the dishwasher and noticed food and debris shooting back into sink thru garbage disposal. Water was on floor. Upon completion of full cycle, water...
Before loading into the machine you have to remove food particles. Washer will wash the greasy surface. If particles are left in the dishes, the same will find entry to the drain system. Check the drain filter in your machine. Clean them. Mostly problem will be solved!
Apr 08, 2010 | GE 24 in. Profile PDW9880JSS Built-in...
New Garbage disposal, washing machine and dishwasher won't work.
Does not sound like these problems are directly related to the disposer. Grinding sound is most likely the impeller on the washer's pump. The washer gets to the first pump out and is unable to pump due to bad impeller or an obstruction. Bad impeller means replace pump motor. (not very hard) Check water supply to dishwasher. Valve turned off or line kinked? Filter screen at solonoid valve plugged?
Aug 15, 2008 | LG WD-3243RHD Front Load Washer / Dryer
Home Logo
353 people viewed this question
Top Emerson Home Experts
Donni Steen
Tom Chichester
Are you an Emerson Home Expert? Answer questions, earn points and help others
