Question about Lands Phones
Uniden fp205 I have just purchased a fp205 corded home phone. I have connected it all correctly but for some reason there is a bit of static on the line. None of my other two phones have this problem. Is there any way to try and diminish the noise? Natasha Emery
shaggyrat
  • 1224 Answers
SOURCE: our 5.8gh uniden phones all have static one land phone 3 extension.
your phone is picking up frequency of something around house or outside close to power lines also known as interference
move phone to different location in house see if the static disapates
also it can be in the houses wireing and not just the phone service provider will have to come out and check your phone lines for you
also a failing battery can cause static in the phone goto closes radio shack and pick up new battery and see if this clears up your problem
Posted on Jun 01, 2008
playaway
  • 18 Answers
SOURCE: I need to reactivate my
This should get the job done for you!
To re-register DXA14588-2 handsets:
  1. Pick up the handset from the base. Press and hold [find handset] on the base.
  2. While holding [find handset], place the handset in the base. The charge/in use LED on the base begins to flash, indicating the base is registering the handset. Wait for at least five seconds.
  3. Pick up the handset from the base and press [talk/flash]. If the display shows TALK, the handset is registered. If not, place the handset in the base to try again.
  4. Press [end].
  5. Place the next handset in the base and wait for at least five seconds. No need to hold [find handset] this time.
  6. Repeat steps 3 - with any other handsets you have.
Please let me know if you have any further questions.
Good Luck!
Posted on Aug 12, 2008
  • 8 Answers
SOURCE: Static on my pair of Uniden cordless phones (Model DECT1560)
Is your base near a computer or other electronics? Also, make sure your microwave is not on. I get static if I do any of those things.
Posted on Jun 20, 2009
BillB-SA
  • 2761 Answers
SOURCE: i have a Uniden dect6.0 cordless phone, when I
When the "check phone line" message appears, it is referring to telephone service and not the wire. It appears that your phone jack is "dead" or that there is no working service in the home. Do you have another phone that you can use to check the jack? Is there another jack that you can plug the phone into for a test?
Posted on Nov 21, 2009
SOURCE: No dial tone on Uniden Dect 6.0 land line and portable phone
We've had the same problem with our new Uniden phone. Sounds like someone's on the other line - no dial tone and answering machine doesn't work. The telephone line works though because we plugged our old phone in and it works fine. Any solutions anyone?
Posted on Feb 05, 2011
All phones have static called at AT & T and no success clearing static
The most common cause of static on the line in your home is a bad or loose wire. If all your phones are experiencing the static, it would indicate that the bad wiring is before the first phone. Check the network interface device (NID) on the outside of your home first. If you are able you could bring one of your phone outside and listen to the static as you move wires around inside the NID. Make sure they are all tight and no bare wires are touching or shorting. If you don't find the problem there check as much wiring as you can get to. If you move or affect the problem you should be able to hear it in a handset. Then check all of the phone cords especially handset cords and phone cords on the floor. I hope this helps you solve the problem. Have a wonderfull day
Sep 06, 2011 | Uniden DECT 6.0 Cordless Telephone...
I have just installed my Uniden UDW20553 Video Surveillance System. I was under the impression that I would have remote access to view my cameras from anywhere in the world on my laptop. Have looked high...
The only solution I have found is using Remote Desktop Connection and running the Uniden application. On my Iphone I found that using Pocket Cloud Remote Desktop (RDP Itunes download application) works best. You must also download a free application named "Pocket Cloud Companion" on the PC your Uniden software is running. Pocket Cloud Companion must be running for connection to made through 3G, Edge or Wifi networks. Also, you have to configure your remote connections by using your PC's IP address rather then the name of your pc, particularly if making connection on 3G network.
Feb 12, 2011 | Uniden Wireless Security Surveillance...
FP205 CANT DIAL OUT
I have the same issue, did you manage to find a solution?
Apr 19, 2010 | Uniden EXS 9910 Phone (EXS9910-R)
What is wrong when the phone says Check tel line?
The telephone cord may not be connected correctly.
  1. Unplug both ends of the cord connecting the wall jack to the telephone base.
  2. Insert one end of the cord to the TEL LINE jack on the base.
  3. Make sure that the cord is inserted correctly in the TEL LINE jack on the phone.
  4. When you insert the cord you should hear a click.
  5. Insert the other end of the cord to the wall jack.
  6. Make sure cord is inserted correctly.
  7. You should hear a click.
Feb 02, 2010 | Uniden DECT 6.0 Cordless Phone ID
Why do 2 of my phones have static to bad I cant
Either the cord has a short or you need to select a different channel
Jul 10, 2009 | Uniden TRU9280-3 Trio Phone
Static on line
Make sure the connections between the base station and the wall socket is really clean. If the little brass pins get tarnished (green) then you will get problems like this.
If that does not help then use the divide by two rule.
Start swapping things out until the problem goes away.
Try connecting a boring old corded phone to the same wall socket.
If the problem persists then there may be a problem with the wiring in your house or with your connection to the telco.
Good luck.
Jul 08, 2009 | Uniden Cordless Phone
Jun 20, 2009 | Uniden Cordless Phone
I have the Uniden DSS7955 + 2 - it it on the same line as my broadband computer line and am getting constant static. When I disconnect the broadband line, the static disappears. I had an older model Uniden...
You will need to get a DSL filter to separate the DSL(broadband) from the talk line. These can be purchased at any store that supports computers.
Apr 16, 2009 | Lands Phones
Lands Phones Logo
97 people viewed this question
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
