Question about Kenmore Dishwashers
Kenmore Dishwaher 58715142400 leaking from round looking pump on bottom. It was not draining so i unclogged the hose and put it back on. now it is leaking from a pump or something where it doesn't look like water should be at all
    Sergeant:
  • 326 Answers
May be blocage in the exit pump
Posted on Apr 14, 2009
Dishwasher is leaking water on floor near unit.
Posted on Jul 07, 2011
My kenmore elite topload washer is leaking underneath washing machine leaving a puddle whats causing this?
depends. first and foremost, I would fill the unit up about halfway with water, with tub being empty of any clothing. Tilt the machine back where you can look underneath it real good. see if you see any leaks with it half full of water. If you don't see any leaks, put the unit back on all fours, and put it into drain/spin. After tub empties of water, tilt unit back again and check for leaks near the drain pump and hose. If you need any further assistance, look for me on 6ya
Nov 27, 2015 | Kenmore Washing Machines
Kenmore 417 97962705 Leaking below tub from transmission gasket
see this causes and fix it. God bless you
Try to identify roughly the area the leak is coming from. This will eleminate some of the following
Hose Connections
Check the rubber washers or replace if the hoses are leaking at the water inlet valve.
Door Seal
This is a common place for leaks. Carefully check by partially pulling seal inside out and check for punctures, pens, pencils... Additionaly if the door is not closing properly it may need a door adjustment. This can easily be done by loosening the hinge bolts on the front panel, adjusting and retighten. The seal is also known to get lightly snagged by zippers or rub by heavy items when close are being removed. This tends to cause the seal to get damaged at the six o'clock position. This is sometimes hardly noticeable but if it is leaking from the bottom of the door replace the door seal.
Water Inlet Valve
If the hose connections are good to the water inlet valve check that water is not leaking from the valve itself it is replace the water inlet valve.
Drain Pump
Check the drain pump housing and all hose connections. The drain pump is behind the lower panel, behind the back panel, and sometimes removal of the front panel. Hoses can be tightened. If hoses or pump housing is leaking replace the pump assembly.
Outer Drum
The outer drum is 2 halves bolted together some washers have a seal between others do not. If the washer is leaking between the seems disassembly of the washer will be necessary. The top panel, console, front panel, door seal, struts. Follow the video for the strut replacement and remove the top springs and the inner and outer drum will pull out the front.
Sep 28, 2012 | Kenmore 98702 Stacked Washer/Dryer
Kenmore HE2 - water leaking from bottom - almost like a garden hose? any ideas
remove panel on bottom usually three screws will remove panel then u can look inside to find leak.. check the drain pump for leaks or debri inside pump by removing cap u willl see down there... hope this helps
Feb 06, 2010 | Kenmore HE2 Plus Front Load Washer
First time using it and it doesn't drain properly
All the newer ons will leave a little water in them.
They will not drain all the water. It will leave the center part in the bottom with water. the reason is that when the pump cuts off the water that is in the line will come back to the washer.That is just the way they are. There is nothing wrong with it.HOPE this helps.
Sep 22, 2009 | Dishwashers
Kenmore washing machine series 90 is leaking
Hi MPT,
Don't take the back panel off!!!
Watch this video to learn how to access the machine.
Generally on a Whirlpool built Kenmore like yours, the drain pump has failed and now it's leaking. The pump is right there in front, the big round white thing. It's connected to the motor by 2 clips. It'll be one of two types of pump... this one or this one <----notice the difference in hose connections?
It's easy to replace, just make sure that the machine is completely empty when you remove the hose or have a shop-vac handy when you do.
And don't forget to rate my solution as "FixYa", deal?
SG
Apr 17, 2009 | Kenmore Washing Machines
Frozen water in bottom of freezer
Every ten to twelve hours your refrigerator activates a heating element around the evaporator to defrost the accumulation of frost that develops on the evaporator. Behind the back panel there is an evaporator pan it has a rubber grommet with a hole in it this is your defrost drain hose it is clogged. Unplug or switch refrigerator off at breaker panel, remove panel covering evaporator area (rear panel in freezer), use a hair dryer or hot water to unclog defrost drain a turkey baster works well to make sure the hose is unclogged.
the water that drains down this hose accumulates in the defrost drain pan in the base of the refrigerator under normal operation the heat from the refrigeration system evaporates this water. The drain pan has a limited capacity so do not poor more than 20-20oz of hot water down the hose after you unclog it. If you poor to much it wont hurt anything just make a mess youll have to clean up.
Apr 02, 2009 | Kenmore 62832 / 62834 / 62839 Bottom...
Won't drain all the way, 1/2 gallon water left in tub
do you have the drain line going to an airgap? if not try making a high loop with the drain line to see if that solves your problem.
Mar 19, 2009 | Kenmore Dishwashers
F 21 fault ?? on a kenmore mod 110.47512601
First if you have a wet vac pull the drain hose out of the drain spout and use the vac to pull the water out of the washer through the drain hose.If not you will need a pair of radiator hose clamps from the auto parts store. Pull the screws from the lower panel at the front of the washer and remove it.in side you will see a rubber hose coming down from the tub to the drain pump. Put the radiator hose clamp there if you didn't have a shop vac.On the front of the pump is a round part with a handle turn that and remove the pump filter .Clean any foreign objects out of the pump and look inside the pump to make sure no impeller blades are broken if any are you will have to replace the pump. put the filter back in and tighten it. If you had to use the hose clamp remove it now.reassemble and don't forget to give the tech his four boxes if this fixes it
Feb 17, 2008 | Kenmore 46462 Front Load Washer
Kenmore front loader washer
Jan 25, 2008 | Washing Machines
Water comes out the bottom of washer as fast as it goes in the top
hazy, it's possible it's running out your pump. You need to pull the cabinet off to get a real look at where the leak is coming from. Check out the pics...and post back.
Apr 23, 2007 | Kenmore Elite 20972
Dishwashers Logo
126 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
