Question about Music
Ibanez Weeping Demon WD7 Wah pedal is not working properly
The ''AUTO SW'' mode on my Ibanez Weeping Demon WD7 Wah pedal is not working. It is supposed to automatically turn on when the wah pedal is slightly depressed. When the pedal is released and goes back to the all the way up position, the effect turns off. Mine won't turn off anymore. It is on from the moment I move the lever to this mode. My ''FOOT SW'' mode works just fine but I prefer the ''AUTO SW'' mode. I've tried adjusting the ''Spring Tension Adjuster'' thinking maybe it wasn't returning the pedal to the all the way up position and thus not letting it turn off, but that didn't work. I'm on stage at least 4 to 5 times a month and practice and use it at least 3 or 4 times a week. l need help quick!!! Thanks!!
    Scholar:
  • 109 Answers
Sounds like a problem with the optical sensor. Your best bet would be to try to get a replacement from Ibanez or take it to a repairman. They are a resistor just like a pot but work by having an LED on one side and an optical "eye" on the other reading the amount of light passed thru transparent film. Morley has replacements for their wahs....not sure if its the same resistance. An audio repairman should hook you up.
Posted on Jun 18, 2009
Hi i have a slash crybaby wah pedal. every time i turn it on their is no signal the batteries are new and the cables and guitar and amplifier work it is just the pedal do you have any solutions on...
First thing is to verify that the in and out cable are to the correct side. These units will bypass in the wrong direction so the fact they pass when off does not guarantee they are cabled correctely. Other problems can include broken solder at the in or out connector. Dos the indicator light come on?
Sep 19, 2011 | Dunlop Manufacturing Dunlop SW-95 Crybaby...
Blue light Slash Wah pedal. After a few weeks the blue light has stopped coming on (I run it on official 18V adapter). Rest of pedal works fine, as before. Would love to have those blue lights working...
First thing to ty is to try it using two 9 volt batteries as a test to see if lights work.
I ASSUME that you are NOT trying to use the pedal in the external effects loop (send and return) as the levels are not compatible. The pedal must be between the guitar and the inout of the amp.
Beyond this I would open the unit and look for something loose or broken where the blue LED is located.
Sep 18, 2011 | Dunlop Manufacturing Dunlop SW-95 Crybaby...
I need parts for my 2002 clyde deluxe wah.....one knob for the side 3 tone mode and 2 feet with screws....can you help thanks Wayne 443-850-5240.....
You can get the feet at home depot in the hardware section. They should be in the specialty drawers.
you may be able get the knob there also. if not, Radioshack has a small selection of replacement knobs. Do you need the 3-way switch also?
Sep 13, 2011 | Fulltone Clyde Deluxe Wah Pedal Wah-wah...
Well I've bought the new Ibanez AF-2, and when I plugged into the FX Loop of my Peavey 5150 combo and tested the TakeOff mode, my amp for a bit don't blast my head off and destroyed the...
You put the pedal where???? The guitar goes through the pedal. This is NOT to be used in an external effects loop of an amp. The signal levels are wrong as the effects loop is LINE LEVEL and the pedal is for instrument signal levels. Move the pedal to before the inout of your amp as it is designed to be used.
Jul 19, 2011 | Ibanez AF2 Paul Gilbert Signature Airplane...
All lights on and no sound . Only work in bypass .
Make sure you have the in and output cable to the correct side. If backward it would act as yours does. If they are correct, time for servicing the unit.
Jun 05, 2011 | Dunlop Manufacturing Dunlop SW-95 Crybaby...
When i select the wah pedal funtion, it does not make the wah
You are apparently talking about an FX pedal with a built in wah function. Which pedal and model number? The Digitech RP350 for instance has a special procedure for initializing and recalibrating the pedal. Is that the problem or is it maybe the opto isolator ?
Jan 21, 2010 | Music
Weeping Demon pedal broke
Suspect that the circuit board may have cracked in the vicinity of the power jack. Also check for a switch under the pedal. SOme have them and it might be broken.
Sep 29, 2009 | Music
Music Logo
873 people viewed this question
Top Music Experts
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
