Question about Toshiba 43H70 43" Rear Projection Television
43H70 has sound by no picture
Hello all. I do build, repair and upgrade computers. Not like in the old days now. No more soldering cpu's and other componets anymore. : ) When I bought this tv, I already knew about the convergence problems some have. Been lucky for the last 5 going on 6 years with mine. I replaced my convergence IC's when last month, my tv would sometimes just shut down. It would come back on after it cooled off. Now it will only play sound with no picture. After about 2 minutes, there is a click sound and the sound goes off and the power led starts to blink slowly. Press the power on button again and the power led starts to blink rapidly. Figure maybe a fuse(s) went with the convergence IC's? I have no clue. Any help would be greatly appreciated. Have no manual for values for the works of this tv. Thanks Sam
  • 1 more comment
  • SSims921 Sep 13, 2007
    Thanks Srtech.
    Will check and get back.
    Sam
  • SSims921 Sep 16, 2007
    Hey SrTech.
    Again, thanks for your input. I do think you meant transfomer? No short there at the horizonal O/P transfomer. I did find a couple of bad looking solder joints and redid them. Haven't done any other trouble shooting yet, but now the set comes on with sound ( still no picture ) and stays on! No more blinking led. Guess the fail safe system was working well. Now to figure why the crt's are not kicking in!
    Sam
  • ljsomeday May 14, 2008
    I have sound but no picture, the light blinks. Never fixed a tv before. Last time I had it fixed the part was $5.00 and the bill was $500.00. Any help as to how i can fix this myself
    Thanks
    Lori
    Sergeant:
    Champion:
  • 375 Answers
Also check the horizontal o/p transistor for short if ok ,look on the deflection board and see if there are any b+ voltage markings and test with meter for b+.
Posted on Sep 12, 2007
SOURCE:
Want to upgrade the cpu if possable
Hello:
You cannot upgrade the CPU in a Sony laptop. It's soldered to the motherboard with over 200 pins you'd have to desolder and then re-solder to install the new CPU. But the main problem is that the motherboard is wired for the current CPU only.
Apr 05, 2011 | Sony Computers & Internet
Hello again.I have an old home pc and I want to upgrade the cpu processor without changing motherboard.Wich is my best options?I want to know if I can to upgrade to PENTIUM 4 3.00 GHz.Also I want to put...
If new processor supports your old motherboard then you will upgrade system with your old motherboard.
If its not supported to new mother board then you have to buy new motherboard to upgrade your system.
Thanks.
Happy to help you.
Apr 30, 2010 | Intel CPU
Same problem--AOC monitor "goes to sleep" after an hour online
It sounds like you have a monitor with a common problem. After a few years some LCD monitors will blow a power supply. The problem is caused by parts called capacitors overheating in the confined space of the monitor. If you are good at electronics repair/soldering you can usually fix the problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htm You can take the back cover off your monitor and look for the bad parts,replace any that look like the pictures and your monitor should work fine. The capacitors do need to be installed with the correct + and - connections, note the stripe on the old one and insert the new one the same way. If you can't do the repair we offer a repair service, contact us for more details.
I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Over 21 years of computer and printer support/repair
Aug 09, 2009 | AOC 19LVWK LCD Monitor
Samsung 953BW blue power lights just flashes when turned on nothing visible on screen with no computer connected
It sounds like you have a monitor with a common problem. After a few years some LCD monitors will blow a power supply. The problem is caused by parts called capacitors overheating in the confined space of the monitor. If you are good at electronics repair/soldering you can usually fix the problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htm You can take the back cover off your monitor and look for the bad parts,replace any that look like the pictures and your monitor should work fine. The capacitors do need to be installed with the correct + and - connections, note the stripe on the old one and insert the new one the same way. If you don't want to try the repair yourself we offer a repair service for $35 plus shipping.
Buddy
Corporate Computer
www.ccl-la.com
Jul 31, 2009 | Samsung 953BW LCD Monitor
Monitor shuts off of the computer then stays on then goes off .
Does it shut off with absolutely no warning sounds whatsoever?
Do you ever hear a faint PC beeper alarm that kinda sounds like a ambulance siren (you know... kinda like a WEEEE. ORRRRR... WEEEE... ORRRR)
My main suspect at this stage is OVERTEMP (you are overheating the CPU).
Possible Causes: Recently UPGRADED components (especially VIDEO)
Build up of dust in Case and CPU heatsink and GPU heatsink or CPU fan has failed or one or some case fans have failed.
Do you know how to check your CPU temp in BIOS? If it happens again check it out.... greater than 90 degrees is usually bad.
Check all your fans are spinning, check you don't have 'caked up' dust on your heatsinks.
If you have recently upgraded a major component that is dumping heat into you case... investigate a new case fan to extract this heat (cheapest option) or you may want to pick up an aftermarket CPU heatsink and fan (Thermalright FTW!!!!!!!)
Mar 22, 2009 | Computers & Internet
CPU upgrade problem
Hi there
what are your pc specs , like ram ect. So we can find out what is wrong. please check your cpu settings and reset the pc bios to see if that hasnt solved the problem
thanks
roger
Nov 12, 2008 | AOpen AK77-8XN Motherboard
Replaced convergence amps, no pic
Go over your soldering and make sure none of the pins are connected by a solder splash.and that all plugs are seated and that no picos are open...
Oct 19, 2008 | Toshiba 43H71 43" Rear Projection...
43H70 has sound, no picture.
look in by your convergence ic's for load resistors to feed b+ to the ic;s see if any are opened there usually about 2,2 ohms 2watt
Sep 12, 2007 | Toshiba 43H70 43" Rear Projection...
43H70 picture wobbling
possibly leaky cap in power supply,look for a 1000mfd/16v cap in on near the b+ supply and also cold solder connections.
Aug 06, 2007 | Toshiba 43H70 43" Rear Projection...
Toshiba 43h70
how old is this unit look on thr rear panel for mfg. date,possoble clod solder connections in deflection circuit and power supply if unit is more than 3yrs old.
May 31, 2007 | Toshiba 43H70 43" Rear Projection...
Toshiba 43H70 43" Rear Projection Television Logo
67 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
