Question about Sanyo DP42746 42 in. Plasma Television
Remote control codes required
NEED THE REMOTE CODES FOR THE REMOTE SO I CAN USE MY BELL EXPRESS VU REMOTE TO CONTROL BOTH THE TV AND SATELLITE. PLEASE HELP.
  • 24 Answers
Hold The Clear Tv buttom until all 4 light flash red , then press code search at the bottom right , then the up arrow until ur tv goes off and finally record , after that u only need to press the red tv buttom to open it or close , If it doesnt open it back its because u press the up arrow after the tv was shut off so do the same thing be using the down arrow .
Posted on May 03, 2009
2 Suggested Answers
  • 24 Answers
SOURCE: bell express vu remote codes for soyo tv
1 - Hold the clear tv buttom until all 4 light flash red
2- Press the red tv buttom
3- Press the amount of time needed on the up cursor ( around select buttom) until your tv shut down
4-When the tv goes off press the search buttom ( at the end on the right side )
5-Press record
Then u can use the red tv buttom to control ur tv and u can control the volume on satelitte mode without going back to tv mode , if u press too much time while searching the code and the tv wont light back , do the same thing but instead pressing the up cursor press the down one to go back on the code it will be faster .
Posted on Feb 25, 2009
I have RCA RLDED5099 Tv, but can't program it to work with my Bell satellite remote so I can then work My JVC THA35 home theatre..
Bell Satellite remote codes for RCA TVs: : 001,005,006,008,012,014,015,018,023,
025,035,066,077,085,121,124,131,133,135,
144,148,150,151,152,155,160,167,190,194,
222,223,225,227,232,236,245,248,268,269,
282,288,289,317,431,486, 492
Instructions for when the code for your device is not listed. Use this procedure to scan the remote control’s memory for the device code
1. Turn the device on (TV).
2. Press and hold the mode button until all the other mode buttons light up, and then let go of the button. The mode button flashes.
3. Press POWER.
4. Press the UP or DOWN ARROW repeatedly until the device turns off.
5. Press POUND (#).
6 .Turn the device back on and try some other buttons to make sure they work
7. If necessary, repeat this procedure
How to program my Bell Satellite TV remote control
Apr 09, 2015 | RCA Televison & Video
I need a code number for a DAENYX TV ihave a remote philips brand number sru5107/27 All so will the remote for bell expressvu work for for HD expressvu the remote belongs to model 3200 express vu
I have provided instructions on programming the remote to your Dynex TV. I have included the codes for your TV. We do not have codes for the Universal remote. You need to contact Phillips to see if they have codes that you can use. I hope this helps.
Address remote to TV:
Remotes: Basic (Television Only)
  1. Turn the Television On.
  2. Press and hold the TV Power button for three seconds until the LED flashes.
  3. Enter the three-digit code using the buttons on the number pad.
  4. Press OK. Note: The LED will flash three times.
  5. Test functionality with the TV.
  6. Return to Step 2 if the remote is not able to turn the TV On/Off, change the volume and mute the television.
Remote codes: 720, 115, 969, 111
Ray Calo
DISH Network
Apr 12, 2011 | DISH Network IR Remote Control
I need 3 digit code for my Prima tv to program bell express vu
Programming an Expressvu remote control can be frustrating. There are two basic ways of doing in it. The first one involves knowing both your TV brand name and also knowing the proper code to input in your remote. The second method is doing an automatic search. The following is a step by step procedure in how to program your dish network or Expressvu remote.
1)Make sure your TV and Satellite Receiver is ON.
2)Press and hold TV button until all lights on the side of it flashes. The TV button is the second button on the Top left hand side corner of the remote control.
3) Release that button, then press & release RED Button. You will notice TV button is stays on. If, it doesn't stay ON, you must repeat step 2 & 3. Otherwise, your batteries are low, you MUST change then.
4)Press and release the UP Arrow Key on the remote until TV turns off. Notice the UP arrow key button is the button below the volume keys (Stop button for VCR.)
5)Make sure you are aiming remote control to TV while pressing and releasing UP arrow key button. When you find the right code, the TV will turn OFF.
6) Immediately after, TV turns off, press # key.
Dec 16, 2009 | Prima C2012 TV
I need remote codes for express vu remote fo my Hisense 22' TV
Try the following remote codes:
748
759
178
10019
505
627
Mar 21, 2009 | Bell Televison & Video
Programm bell expressvu 4100 remote control
I had the same problem. I used the code 660 and that works fine for power, volume, and stations for my Insignia with the bell remote. Hold tv button till all 4 lights light up and then press 660 # and everything (minus the menu option) should work. I also tried these insignia codes (which might work if this dont.) 659, 573, 570, 405, 245, 456.
Mar 09, 2009 | Insignia 19 in. Widescreen Flat-Panel LCD...
Need codes for bell express vu satellite for innovage products jumbo remote
Press and hold tv until red light flash , press code search , press channel up until the tv goes off , then press record and your done
Feb 10, 2009 | Big Button TV Universal Remote
Bell express vu remote codes for soyo tv
5-Press record
Jan 02, 2009 | Soyo Crystal DYLT032B 32 in. LCD...
Need codes for jumbo universal remote for phillips tv and bell express vu
Press the tv and hold it until the red light flash , then press code search , press channel up until your tv goes off , press record and that it your done . Will work for your tv but maybe not for the express vu receiver , this way of finding code makes the remote trying them all so if it dont work on your express vu remote , no other codes will .
Dec 08, 2008 | 2006 Honda ANF125 Innova
Jensen JR400 remote codes
My sheet says the code for a Sony TV is:0000
What an interesting number... Hope it works for you. :)
Apr 12, 2008 | Jensen JR400 Remote Control
Sanyo DP42746 42 in. Plasma Television Logo
255 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
