Question about Hotpoint Dryers
The Gas won't ignite! I've got this Hotpoint DLL2650BGlad Heavy Duty Dryer for over 20 years. The carbon igniter won't get red! Is it the fuse problem? All the other machanical functions are good.
  • dynamex_theo Apr 14, 2009
    The igniter is intact and functional.
  • dynamex_theo Apr 15, 2009
    Much thanks, 'seabreeze' & 'appliancepartspros'.
    I'm getting the serviceman. Laundry's piling up.
    One of those parts has to be replaced anyway.
  • Hotpoint Master
  • 4,655 Answers
Not the fuse I think. Get the multimeter and unplug the wires going to the igniter. Make sure power is off also before attempting to check igniter.
The igniter is fragile e glass and when testing with meter set on continuity should so no resistance.Just like touching the meter probes together. Below is my site link and email. I am not sure if this is the part number but enter both modl and this part number, WE4X444
email seabreezehvac@yahoo.com
http://servicepartstec.blogspot.com/
Posted on Apr 14, 2009
  • 2 more comments
  • John Tripp
    John Tripp Apr 14, 2009
    Here is a picturecture
  • John Tripp
    Yes, thermal fuse could be broken , the heat sensor for the flame, the temperature thermostat, all of those things need to be checked. I;m having a little trouble finding the diagram for this 20 year old dryer but until I do please keep me posted on what you want. If you have the tools, multimeter and time to disassemble I am here to go through the process.
  • John Tripp
    Thanks for your vote.
  • John Tripp
I have a Frigidaire gallery commercial heavy duty dryer model #GLGR331AS1 it just stopped heating turns on and runs but no heat. Could it be the solenoids or the igniter ?
If the igniter glows but it doesn't ignite, most of the time, it's the valve coils, most of the other times, it's the radiant sensor.
If the igniter doesn't glow, check your thermal fuse. If your thermal fuse is good, replace your igniter.
Oct 21, 2014 | Dryers
The unit just stopped heating and drying the clothes.The burner on my LP Kenmore dryer won't light, otherwise everything else works just fine. I've have taken everything apart and cleaned out all...
Generally, with a gas dryer, there is an ignition device that heats to a specific temperature and this causes the gas to ignite. When this electric ignition fails to work, the gas will not ignite and there will be no heat. I had this happen and had to call a professional. It was a simple matter of installing a new ignition device and it worked perfectly for years. I hope this helps! If it is a new dryer, check to see if this part might be covered under warranty
Jul 28, 2011 | Kenmore Dryers
I have a kenmore heavy duty 70 series gas. not heating up. were is the heating element. could you send a technical manual.
Your dryer does not have a element. The problem is either with the igniter, or the gas valve coils. I would replace both of them. I think they would run about $35.00 for both. Here is a link to the parts.
http://www.appliancepartspros.com/Appliance-Parts/Dryer-Parts/Dryer-Igniters-and-Gas-Valve-Coils/index.aspx
Nov 22, 2010 | Dryers
Dryer runs fine but heating unit will not ignite
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Jul 11, 2010 | Kenmore 77632 Gas Dryer
Hotpoint aquarius ctd00 does not blow hot air
If gas, check the following.
1. Gas valve coils
Igniter glows, then shuts off without igniting gas - the problem is probably with defective coils (black, located on top of the gas valve). It is recommended to replace all coils (usually two or three) if found defective.
Note: Sometimes the whole gas valve may be defective, thus not letting the gas out. However, this problem is not common.
2. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
3. Igniter
Igniter may burn out or break. Replace the igniter if found defective.
Note: Igniters are very fragile and break easily. It is recommended to handle the igniter only touching the ceramic part of it (usually white in color).
4. Flame sensor (or radiant heat sensor)
Replace the sensor (located near the igniter) if found defective.
If electric, check the following.
1. No power to the dryer
Make sure there's power getting to the dryer. Check for tripped circuit breakers or blown fuses. An electric dryer uses two circuit breakers or fuses, and if only one of two is tripped or blown, the dryer might still run but not heat. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Heating element
A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
3. Thermal fuse
Jul 09, 2009 | Hotpoint Dryers
THE DRYER STOPPED PRODUCEING HEAT.
Check the following to address the non heating issue
1. Gas valve coils
2. Thermal fuse
3. Igniter
Jun 01, 2009 | Kenmore 73952 Gas Dryer
Gas Dryer blowing cool air and will not heat up.
Look inside door and get the model number for me. Could be igniter, gas solenoids or temp control switch inside. Let me know, Thanks Sea Breeze
Mar 19, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
No heat, clothes do not dry
the model number that comes up is DLL2650BPL you could have a bad igniter,gas coils or sensor but the only way to tell is by reading them out with a meter the igniter part number is WE4X444 gas coils are part 5303931775 and the sensor is part WE4X448 you can go here to see parts
https://www.repairclinic.com/Shop-For-Parts/a8b95d49280/Model-DLL2650BPL-Hotpoint-Dryer-Parts
if you have heat at the beginning and then no heat it will be the gas coils but one of the coils still could be bad and not work at all but check all parts with meter before you start ordering parts you don't want to change out good parts.
Feb 09, 2018 | Hotpoint Dryers
Kenmore 110 gas clothes dryer heats for 20 min then needs to rest for 20 mins before heating again
Cause 1Thermal Fuse
The thermal fuse is a safety device designed to protect the dryer from overheating. The fuse is located on the blower housing or at the dryer's heat source such as the heating element on electric dryers or at the burner on gas models. The fuse should be closed for continuity meaning it has a continuous electrical path through it when good. If overheated the fuse will have no continuity meaning the electrical path is broken and the fuse has blown. A multimeter can be used to test it for continuity. Be aware that a blown thermal fuse is an indication of a restricted exhaust vent from the dryer to the outside. Always check the dryer venting when replacing a blown thermal fuse.
Parts Cause 2Gas Valve Solenoid
Gas dryers have two or more gas valve solenoid coils. The gas valve solenoids open the gas valve ports to allow gas to flow into the burner assembly. If a gas valve solenoid fails, the dryer won't heat. To determine if one or more of the gas valve solenoids has failed, check the igniter. If the igniter glows and goes out but does not ignite the gas, the gas valve solenoid is defective. If one or more of the gas valve coils are defective, we recommend that you replace them as a set.
Parts Cause 3Igniter
The igniter uses heat to ignite the gas in the burner assembly. If the igniter is not working, the gas will not ignite, preventing the dryer from heating. To determine if the igniter has burned out, use a multimeter to test the igniter for continuity. If the igniter does not have continuity, replace it.
Feb 16, 2018 | Dryers
Dryers Logo
164 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
