Question about Craftsman 21 Hp 42" Deck, Ys 4500 Lawn Tractor
17.5 h.p. b/s craftsman tractor oil pushes into carb. smokes bad!
Runs about 15 min. before prob starts. smokes so bad you have to think its gonna blow-up! oil runs out of filter assy.
  • 28 Answers
Make sure it's not overfilled with oil.
if this is not the case, then you have excessive blowby, which is what blows past your rings when the air/fuel mixture ignites. there is only one explanation for this, faulty rings, and that's what it sounds like to me. the blowby forces the oil into the vent leading to the filter, and back into the cylinder, where it burns, creating blue smoke.
Posted on Apr 14, 2009
Craftman 917.270.711
check to see if the oil smells like gas the needle valve in the carb doesn't seat and gas drains into the engine the oil gets thin and burns it fast
May 30, 2012 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
2010 model 20 hp Briggs motor. Fuel going through fuel line, but not going into carberator. Motor runs good for about 15 min, but after heating up this fuel problem starts. After cooling down for an...
Two things:
1 Is fuel coming out of the fuel line. Older mowers have old fuel lines and they tend to get weak and collapse went they warm up with engine heat. Replace the old fuel line.
2 deposits in the carb. take off the air cleaner, start it up and spray a good carb cleaner in the carb until the engine dies. Put some 'seafoam' in the gas and a little in the oil and put the air cleaner back on and start the mower and mow on FULL THROTTLE. this should claen out the carb. Yes the mower will run rough for awhile.
these two cheap fixes will solve 85 % of carb problems. GOOD LUCK
Jul 17, 2011 | Craftsman 20 Hp 42" Deck Lawn Tractor
My Craftsman 15 HP Lawn tractor is spewing white smoke. When I removed the air filter, I noticed there was oil all over the inside of the air filter and at the bottom of the air filter. When I run the...
I could be caused by a couple things, the most common is overfilling with oil, running on too great of angle and flooding the valve stem area or really bad valve stem seals.
Jun 01, 2010 | Craftsman 20 Hp 42" Deck Lawn Tractor
Craftsman 16.5hp 42 in. Mower runs for about
mine always starts-- and won't start again if I turn it off- going to try the flywheel key replacement-- which affects the timing-- otherwise-- let me know what you find out as a solution
May 24, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I have a Craftsman Riding mower 17 HP, 42"cut. It runs for ~30 minutes then shuts off like it's out of gas, but it's not. Won't restart for ~30 min. Can anyone help
check for fire to the plug after it dies....if there is no fire then its possible that the coil is breaking down and needs to be replaced.
Nov 21, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I have a Craftsman 16hp B&S, 42 tractor. engine surges, blows oil
SOUNDS LIKE YOU HAVE A AIR LEAK AND SOME BAD GAS AND YOU MAY WANT TO CHANG THE OIL 1 MORE TIME LETME KNOW IF THIS HELPS IF NOT ILL DIG IN TO IT WITH YA
Oct 08, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman riding mower starts, then runs for 30 seconds, then pours out white tons of white smoke and sputters and dies. It will then re-start and repeat the same. The amount of smoke is tremendous. It...
The smoke is oil going in to the combustion chamber, will have to check for broken rings or piston. also if the tractor was stored in a position that the oil would run to the combustion chamber it will do that untill all the oil is burn
Mar 22, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Hard starting loading up with gas in cylinders when it does start it blowes white smoke runs a couple min. than dies wont start for at least 15min.
float valve in carb is leaking fuel into engine. It ususally gets in the oil,too, when this happens. clean float valve and change the oil. Or put a shutoff valve in the fuel line and close it everytiime you park it (not a good solution but it works.)
Mar 11, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 21 Hp 42" Deck, Ys 4500 Lawn Tractor Logo
523 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
