Question about Refrigerators
How do i level my Kenmore refrigerator model number 25374824406??
  • Refrigerators Master
  • 4,655 Answers
You should level the refrigerator on left and right side and the front door side the top leaning just a little to the wall behind the refrigerator. This keep the doors from swinging out or not closing well. Never level a refrigerator all the way around, Thanks, Sea Breeze
Posted on Apr 14, 2009
How to make the freezer door on a kenmore elite 74033 tilt
Refrig of the year: Kenmore Elite 74033 Refrigerator
Consumer Reports Rated: Excellent
Hello Charles,
Just when I'm thinking Sears SERVICE is NOT some sort
of sad/bad joke... you put in a Kenmore Elite Model number...
continued search found your Owners Manual... Pages 10 & 16 are what you want
The front should be slightly higher than the rear to aid in door closing... (page 10)
Your refrigerator has two front leveling legs-one on the right and one on the left. Adjust the legs to alter the tilt from front-to-back or side-to-side. If your refrigerator seems unsteady, or you want the doors to close more easily, adjust the refrigerator's tilt using the instructions below: NOTE: Tools Required: 11/16" wrench or flat blade screwdriver.
1. Turn the leveling leg to the left to raise that side of the refrigerator or to the right to lower it. It may take several turns of the leveling leg to adjust the tilt of the refrigerator.
NOTE: Having someone push backward against the top of the refrigerator takes some weight off of the leveling legs. This makes it easier to adjust the legs.
2. Open both doors again and check to make sure that they close easily. If the doors do not close easily, tilt the refrigerator slightly more to the rear by turning both leveling legs to the left. It may take several more turns, and you should turn both leveling legs the same amount... (page 16)
`` After that...
All you have to do to maximize that efficiency is keep the closure area free of pizza boxes, ice cubes or errant frozen food bags.
Hope this was helpful...
Kenmore Elite 74033 Refrigerator Review Kenmore com
Feb 12, 2016 | Kenmore Refrigerators
Tip
Kenmore (Sears) model number to real manufacturer decoder ring
This job aid will decode who manufactures the Sears Kenmore appliances. Write down the entire model number and point your web browser this die-rec-shun...
http://www.appliance411.com/parts/sears.shtml
This tool works for all Kenmore products, not just refrigerators.
on Apr 13, 2009 | Kenmore 73503 Stainless Steel Bottom...
How do i adjust the doors so that they are level?
What is the model Number on the tag of the refrigerator.
Feb 13, 2014 | Kenmore Side by Side Refrigerator
How to level refrigerator
Try Sears Direct with model number 10656249400
Jan 07, 2014 | Kenmore Refrigerators
Where can I locate the model number? It is no
Is the refrigerator a Kenmore? Some have model numbers located on the wall between the fresh food section door and the kick plate. Most have the model number around the fresh food compartment door frame Kenmore model numbers look like this=> 321.45678 I am here if you have questions or comments, Sea Breeze
Aug 21, 2013 | Kenmore Refrigerators
Maytag refrigerator
ea5703cb-9dae-46dc-802e-aff05e1adbe2.jpgYou may have defrost component failure. What is the model number of your Maytag? Sea Breeze
Apr 23, 2013 | Kenmore 50522 / 50524 Side by Side...
My Kenmore refrigerator makes a clicking and clacking sound
Sounds Like the overload and start relay, yet I need a little more information to get the part number. See these notes> Sears buys all their products from someone else like Whirlpool, Maytag, GE and the list goes on and on. Then Sears calls their model number Kenmore Model Number=> Kenmore Model Number Locator's and the first three numbers are the models maker or who originally made the appliance Click Here for examples=> Kenmore Appliance Model Number Prefix's or Click=> Here once you have the correct Kenmore Model Number once you have that then you can find the parts for your dispenser. Your number will look like this for example only 363.235698 then go to Parts Direct or Repair Clinic and enter the correct Kenmore appliance model number and then search dispenser parts for that model numbers parts number. Hope I made this simple enough so if you need assistance I will be here to help you find that one small part you are searching for, Thanks, for understanding, Sea Breeze -->
May 01, 2011 | Kenmore 53693 Side by Side Refrigerator
My kemore side by side is luke warm as of this morning.
Sears gives their models different numbers for example 198.215478
Look for the number so I will be on the correct model and help you better.
55c7687.jpg Thanks, Sea Breeze
http://servicepartstec.blogspot.com/
Apr 24, 2009 | Kenmore 57029 Side by Side Refrigerator
Noisy Evaporator Fan on a Kenmore model 596.76579600 refrigerator
The replacement evaporator fan for your model is a part number 12002744
Mar 15, 2009 | Kenmore 24.8 cu. ft. TRIO Bottom Freezer...
Freezer section of Kenmore Self Defrost Refrigerator Mfg. 4/07
What you have found as a model number may in fact, be a part number for the inner lining.
Check your owner's manual for the model number.
Check to see if your unit is equipped with a setting for humid/dry climates and if it is present, it should be set to correspond to yours.
The defrost cycle melts concealed, built-up frost, with an internal heating element.
That produces water that should normally drain through a hidden path down to the evaporation tray at floor level under your unit.
If the path is blocked, the water will find its way into the interior and refreeze wherever it lands.
Gaining access to the element and the drainage path can be a real pain in some refrigerators and requires removal of the liner of the freezer for access.
Good luck.
Jun 15, 2008 | Refrigerators
Refrigerators Logo
348 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
