Question about IBM Computers & Internet
Doesn't detecting ram
I have two rams of 128 mb.when i connect the ram my computer shows 256 mb but when i turn off my computer and turn it on again after some time, it shows only 128 mb.when i disconnect ram and again connect it then it shows 256 mb. but after trning computer off and again turning it on after some time, it again shows 128 mb. what is the problem? pleas help me to solve this problem.
thankyou
i have
DMI System Product 81751GQ
DMI System Version ThinkCentre A50
DMI Motherboard Product D865GKD
Motherboard Chipset Intel Morgan Hill i865GV
    President:
  • 948 Answers
The problem is either:
The ram is not compatible with your system
The ram is faulty
The motherboard is faulty
The power supply is faulty
I suggest that you try the following:
Blow the computer out with canned air, especially the ram slots
Try different ram.
Posted on Apr 14, 2009
Will a Samsung 256MB DDR PC2700 CL2.5 184 PIN work
No that memory is not compatible. The Precision 350 uses memory called RDRAM aka RAMBUS.
Here are the speeds and sizes that are supported.
Memory modules supported PC800-40: 64-, 128-, 256-, 512-MB, non-ECC or ECC
PC1066-32P: 128-, 256-, 512-MB, ECC and 64-, 128-
,256-,512-MB, non-ECC
Minimum memory PC800-40: 128 MB non-ECC and ECC
PC1066-32P: 128 MB non-ECC and 256 MB ECC
Maximum memory PC800-40: 2 GB non-ECC and ECC
PC1066-32P: 1.5 GB non-ECC and ECC
Sep 27, 2014 | Computers & Internet
Ram 256 MB but show 128 MB pls send solution
If you have an existing 128Mb RAM module and inserted another 128Mb to give you a total of 256Mb and it stills shows 128Mb. Then the second RAM module may not be compatible or the second RAM module is faulty.
Try and use the same make and type RAM module as the original or insert a 512Mb RAM module instead of two 128Mb RAM modules. There is not much price gap between 512 and 256 Mb RAM.
Nov 01, 2010 | Intel D845GLLY Motherboard
I have an Acer TravelMate 514T PC Notebook running with only 64MB RAM, and I want to put in a 256 MB RAM. How do I make the notebook recognize the 256 MB RAM card?
Mostly what I came across this models they only can detect until 128 mb and they do run a little faster than having 64 mb.And see if the card is pc100. and it is also dependent on what is your operating system is.If your notebook memory slot is two get two 128mb and you'll have 256mb.
Oct 31, 2010 | Acer TravelMate 514T Notebook
I have intel 845 glly desktop board with 256 mb SDR. When I added 128 mb SDR in the second slot it is not recognising it. How to add 128 mb SDR with 256 mb SDR. When I fix 128 mb ram in first slot and...
1st try to exchange the cards in the slot.
2nd try another card
3rd ur RAM slot may not be ok
4th ur RAMs may not be compatible
5th ur new RAM card may not be ok
use same type of RAMs, and same size...
if u have 256, add 256
if u ahve 128 add 128
if u have SDR then dont add DDR
getting compatibility is little difficult...
some times no combinations can work...
note...technology keeps changing...so a old RAM card that was bought years ago may not be compatible with a new RAM card....
even i got all my old RAM cards(256+128) removed and got 2 - 512mb of the same type fixed...even i had issues with my RAMs for 6 months...
Dec 27, 2009 | Intel D845GLLY Motherboard
I want my Laptop Dell Latitude C800 physical memory upgraded to 128 mb to 256 mb I myself already installed 256 mb Ram but it still showing 128 mb of memory...can I get help in this regard ?
I assume you installed another 128Mb of RAM to give you a total of 256Mb.
It is most likely the 2nd RAM module is not compatible with the other RAM module. Try using the same make.
OR
Purchase and install a single RAM module 256Mb or 512Mb these are not expensive.
Dec 20, 2009 | Dell PowerEdge 2600 Server
My System is not showing correct RAM, i.e.,128 MB instead of 256
the ram you've purchased is high density ram, not supported by your motherboard....sorry :(
I suggest www.crucial.com to make sure you get the right type for your system.....
Apr 10, 2009 | Computers & Internet
RAM cuantity
The motherboard you mentioned supports DDR1 RAM.
For windows xp and general application 512 MB is enough.
But if you use memory intensive applications like image/video editing then you can opt for 1-2 GB RAM.
Nov 24, 2008 | Intel D845EPI (INTELKD845EPILPAK10)...
Ram when i upgrade 128 sdram to 256 sdram in intel 845glly it shows spd
It is not seieng the ram, try swapping the ram around or leave out the 128MB, just put in 256MB, if no boot then the ram is not compatible or faulty, not all ram sticks work in all motherboards.
Sep 08, 2008 | Intel D845GLLY Motherboard
Ram
Check the configuration of your system, it probably supports 128 MB of RAM at max.
Jul 16, 2008 | Compaq Presario 5000 PC Desktop
Computers & Internet Logo
128 people viewed this question
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
