Question about Dell E173FP 17" LCD Monitor
Replacing the Logic board
How do I get into the monitor without destroying it?
  • 42 Answers
OK. Start by remiving the cover, fan, adaptor card and power supply. Remove from the logic board: The hard drive power cable, hard drive data cable and the floppy drive cable. with the rear of the case facing you, release the two tabs with your forefingers while at the same time as pushing on the 120-pin connector with your right thumb. Slide the logic board to the front of the case until it stops. Caution: Be sure the power on/off button clears the rear panel before you lift the logic board out of the case. While lifting the board, do not touch connector J19 or J20. (The oil from your skin harms the connectors.) Gently lift the board out of the case. Replacement Note: Remove the SIMMs from the defective logic board and install them on the replacement logic board. I really hope this helps because it is correct information. If you want to be extra cautious, visit a repair shop instead. Good Luck!
Posted on Sep 12, 2007
SOURCE:
After replacing a logic board on tallygenicom,it desplays the error "sucurity violation" how do i resolve that problem
Security lock was installed in the previous logic board remove the security lock and install it in the new logic board.
Feb 28, 2013 | TallyGenicom Office Equipment & Supplies
CM 7000 will not boot up
On all units that I repair, I replace all nine of the power supply board capacitors regardless of the voltages. There are poor quality capacitors and are going to fail at some time in the future.
The logic board caps are the same through hole type as the power supply. Yes there are many surface mount capacitors but none of these have need to be replaced. Replacing the logic board caps are very difficult because of the inner plane layer that acts like a giant heat sink. I use a desoldering station that has a suction pump and set the temperature to 850 degrees F. First I unsolder the square pad lead as this one is easy. The other lead requires more time, I hold the iron on until I can move the capacitor lead and turn on the suction as I pull the part out of the hole. Even with this process the holes do not always come clean and require additional work. Without the desoldering station it is very difficult and I would not recommend attempting it.
Nov 18, 2011 | Televison & Video
Samsung 204b white screen after replacing capacitors
Check the connector/cable between the logic board and the T-CON board on the LCD panel, also check the fuse on the T-CON board, it may not be receiving the 12/5vdc for for the VCC.
http://s807.photobucket.com/albums/yy352/budm/LCD%20panel/
Sep 10, 2010 | Samsung SyncMaster 204B 20.1" LCD Monitor
Screen went white
The white glow with no picture means that either the ribbon cable connection between the logic board and the monitor has come lose or dirty contacts, or the LCD Controller (T-CON) board (part of the LCD panel is not getting 5v or 12v depend on LCD panel from the logic board or the LCD controller board has blown fuse, see pictures here for guide (note pin on the LCD board with arrow mark is pin 1 and is the incoming DC power supply line): http://s807.photobucket.com/albums/yy352/budm/LCD%20panel/?action=view&current=DSCF0881.jpg
You may also want to look for bad caps (bulging top) on the logic board. There should be 5vdc feeding the logic board also.
Mar 31, 2010 | Envision G918W1 Monitor
Monitor comes on,then goes off after a couple of seconds.Checked the circuit board but found no problem,feel that the screen might be faulty,please help.
This could indicate some component overheating/damaged. I haven't worked on a monitor like yours, but on several occassions I noticed that the problem was caused by blown capacitors. This can usually be spotted if you inspect the capacitors on the logic board carefully. If they are bulging or you can see black goo "leaking" from them then they need replacing. Other than that, troubleshooting of other components on the logic board is far too complicated to describe here.
Hope this helps,
Raf
Nov 13, 2009 | Soyo Dymond DYLM017A 17" LCD Monitor
I have a dell monitor E172FPb monitor and all it will do is the power button flashies green. I have read forums that refer to replacing the four transisters on the logic board but state that is no...
We repair these all the time. Check our web site at: www.ccl-la.com/monitor_repair.htm The repair is very simple, just replace the 4 transistors and you should be back going.
If you need additional info just requhat.
Buddy
Corporate Computer
Jul 28, 2009 | Dell E153FP 15" LCD Monitor
Flat screen monitor comes up with No Signal
If it goes to NO signal again, its not necessarily the whole Flat screen that is dead. Just replace the Video logic board with a known good one and it should work
Most monitors only have 2 or 3 boards
Logic board, Inverter, Power supply
or Logic video ,and a power supply board with an embedded inverter.
You have to open the monitor and replace.
Sep 13, 2008 | Computers & Internet
19 inch star logic monitor
bad vga board however you can open it up and see if the capactors are blown replacing them may solve this problem however when an LCD monitor goes white typically it is the microchip that has gone bad so I sell the monitor for parts and buy a new one.
Aug 18, 2008 | Star Logic 17" LCD Monitor
Monitor just stopped working, screen is white.
The totally white screen and no On Screen Display / Menu indicates your monitor is definitely faulty. Unfortunately the only solution is to have the monitor repaired, or buy a new monitor. If the monitor is still under warranty, the manufacturer should replace or repair it. Sorry to be the bearer of bad news :(
If you know someone that is technically experienced and is willing to try, replacing the logic board is fairly simple assuming you can find an exact replacement. I suggest searching google for AL1916W video board or logic board, you might find an electronics store that carries the part, or you might find one on eBay.
Jun 10, 2008 | Acer AL1916W 19" LCD Monitor
Dell E173FP 17" LCD Monitor Logo
219 people viewed this question
Ekse
Clive
Clive
