Question about Dell Inspiron 6000 Notebook
Monitor problem I have a blue column that appears right down the middle of every screen. When I am on my startup page I don't see it cause it is also blue. The column is about 1 inch wide and runs right down the middle of the screen. Can this be fixed, repaired or do I have to buy another lap top
  • dansturm Sep 12, 2007
    Thank-you
    That what I was thinking.
    D
  • 42 Answers
I think you have dead pixels. You need to visit an electronics repair shop immediately to fix it. Replacement may be necessary. Good Luck.
Posted on Sep 12, 2007
SOURCE:
CAN ANYONE HELP ME WITH A COMPLETE LIST OF TROUBLE CODES AND MEANINGS FOR MY 1993 CADILLAC SEVILLE SLS WITH THE 4.9L V-8 AND THE VIN# HAS THE LETTER B IN IT. I WOULD REALLY APPRECIATE IT ALOT
go google and type in --- fault codes for 1993 cadillac seville--
the first site is cadillac OBD codes -- and if you click on that site you will find a page cadillac pages
page 2 in the middle column there is a section cadillac seville 1993-1995 4.6 L at the bottom of that column
click on it and the fault codes appear
if you right click on the screen , a print section should appear and you can take a snapshot of the screen and any screen page after that so that you can get a hard copy of the fault codes
Oct 19, 2015 | Cadillac Cars & Trucks
My toshiba laptop has a thick white line down the screen
The normal cause of lines across the LCD of a laptop is a damaged video cable. The unusual cause would be the video card itself.
To determine which item is at fault, you need only attach an external monitor to your laptop's video-out, and then swap your monitor view to 'both' or mirrored (usually just the function key (FN), plus one of the Fkeys...look for an off-blue picture of a monitor on the Fkeys).
If the lines across the screen also appear on an external monitor, then the video card is damaged.
If the lines only appear on the laptop's LCD, but not the external monitor, then just the laptop's internal video cable is damaged.
Hope this helps.
Aug 21, 2009 | Toshiba Satellite p105-S6114 Notebook
Line down middle of the screen-resolution is different on sides
Computer parts can sit in warehouses and be on trucks for a long period of time. Unfortunately that means things get banged around. Sometimes they don't even work when they come out of the factory. I suggest exchanging the monitor for another one. It could also be your video card. Easiest way is to exchange it and it's free to exchange.
Jul 07, 2009 | LG Computers & Internet
A gap appears as a column down the page
I would check for an actual foreign object in the carrier
Jun 07, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Convergence problem
http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
You can download the manual here. Insrtuctions for auomatic convergence are described. I copied the instructions below.
Automatic Convergence
Your HD Monitor’s picture tubes might have been disturbed during delivery or
after you moved the HD Monitor, causing the color in your HD Monitor to be
out of alignment. The colors adjust by starting auto convergence.
IMPORTANT: Auto convergence works best once the HD Monitor has
warmed up for at least an hour. If you've just unpacked your HD Monitor,
it's a good idea to repeat the Auto convergence function when the
HD Monitor's been running for at least an hour. See page 38 for more
information about Auto convergence.
1. Press OK to begin auto convergence.
2. When the auto convergence is complete, the Red center convergence menu
appears. The cross in the middle of the screen should be yellow. If it is not,
use the arrow buttons to move the red cross to overlap the green cross.
Press OK when adjustments are complete.
3. The Blue center convergence menu appears with a cyan cross in the middle
of the screen. If it is not, use the arrow
Sep 23, 2008 | RCA R52WM24 52" HDTV Projection Television
Red column down middle of screen
you will most likely need a new plasma panel
Sep 04, 2008 | Televison & Video
Flashing padlock icon in the middle of the screen
When the icon is in the unlock position, hold down the Menu key (the far left button in the lower righht hand corner) on your monitor. This should bring up the menu. From there, you can reset the factory settings.
Mar 16, 2008 | Dell E172FPt 17" TFT LCD Flat Panel...
Monitor control lock problem
Replace the small 78L05 regulator 5V supply to micro.
Jan 13, 2008 | Computers & Internet
LCD TV - Vertical Blue line
My Lcd monitor has blue line? How can I solve this problem?
Nov 14, 2007 | LG Flatron L1750S 17" LCD Monitor
Dell Inspiron 6000 Notebook Logo
96 people viewed this question
Ekse
Clive
Clive
