Question about Jabra Bluetooth Headset with Adjustable Ear-Hook Headset
Light stays on when i turn it on, cannot connect
Unplugged from charger and cannot connect to cell because blue light stays on
    President:
  • 2,923 Answers
For this headset, the Blue light should blink before you can connect it via Bluetooth.
Have you tried holding down the multi-function button of it for 7 seconds and then release it? If not, try that until the Blue light flashes. If it will not work, refer to the user manual of the headset or this could be a defective one.
Posted on Apr 14, 2009
Will not turn on unless plugged up to charger
Your built-in rechargeable batteries are perhaps defective and do not hold charge.
Hope yours is not a clone.
Mar 28, 2016 | LG Electronics HBS 800 Bluetooth Headset
I have a Samsung Galaxy S5, fairly new less than one year. If I take it off the charger, it just turns itself on and off repeatedly and will not stay on. The only way I can use the phone is if it is on the...
Take it in for service or replacement. Its acting like the connection to the charger is bad and when it is unplugged it acts like it has a bad connection.
Dec 27, 2014 | Samsung Cell Phones
When I put the battery on the charger the light on the charger stays on for little awhile the it starts to blink, but when I try to use the battery it is not charged. So I am not sure if I need a new
Hi there! It sounds like you have our Linx stick vacuum or hand vacuum model. Plug only the charger into an outlet, the blue light on the charger should flash once. If the light on the charger flashes once then the charger is fine. Try resetting the battery by following these quick steps below.
1. Remove the battery from charger or cleaner
2. Unplug the charger
3. Insert the battery into the vacuum and turn the unit on for 30 seconds (even if it has no power)
4. Remove the battery
5. Plug the charger into an outlet, make sure the light on charger blinks blue once.
6. Insert battery into charger
The light should be a solid blue, indicating the battery reset worked. If so, allow the battery to charge for 3-4 hours, completely deplete battery on your next use and re-charge. If the light on the charger is still blinking, your battery will need to be replaced. I have included a link where you may go to purchase a replacement battery if needed. Hope this helps!
Search Results
Sep 21, 2014 | Hoover Floormate H3000 Upright Wet/Dry...
Why doesn't my battery charge? Why doesn't the charger's light come on?
Hi Suzanne! Follow these steps to check that your charger and battery are working properly.
1. Unplug the charger for at least 30 seconds.
2. Plug the charger back in. The blue light on the charger should flash once.
If the blue light flashes once this is an indication that the charger is still functioning properly. If the blue light does not flash, the charger will need to be replaced. Follow this link to order a replacement charger. LiNX Battery Charger
3. Place the battery in the vacuum and turn it on for 30 seconds. (even if it does not turn on or powers off)
4. Turn the vacuum off.
5. Remove the battery and place it in the charger.
If the light on the charger is solid blue this is an indication that the battery has been reset. Allow 3-4 hours for the battery to fully charge. The blue light will start to blink slowly to indicate the battery is fully charged.
If the light on the charger is flashing blue or there is no light at all this can mean that your battery needs to be replaced. Follow the link to order a replacement battery. LiNX Lithium Ion Battery
Hope this helps!
Jul 28, 2014 | Hoover Platinum LiNX Cordless Stick Vacuum
Red blinking light
Hi, Ephraim. The flashing red light indicates that the device is showing "low battery". It could be that the LG phone charger fits the charging port on your bluetooth headset but it is not compatible with your device. In order for you to know that it is charging, the device should show a steady red light(means charging).
Please take a look at the table reference below.
•With the Charger Plugged In
______________________________________________________________________
•Headset Indicator Headset Status
Red-----------------------------------------------Charging (battery level less than 50% charge)
Yellow-------------------------------------------Charging (battery level more than 50% charge)
Green--------------------------------------------Charging complete
With No Charger Plugged In
Off ---------------------------------------------Power off
Three blue flashes------------------------Powering on/off
Steady blue --------------------------------Pairing/connect mode
Rapid blue/purple flashes -------------Connection successful
Quick blue flash --------------------------Incoming/outgoing call
Slow blue pulse --------------------------Connected (on a call)
Slow blue flash ---------------------------Standby (not on a call)
Slow red flash ----------------------------Idle (not connected to phone)
Slow purple pulse -----------------------Connected call muted
Steady red ---------------------------------Attempting to connect
Quick red flash ----------------------------Low battery
Note: After 20 minutes on a call or of inactivity, the light stops flashing to conserve power, but the headset remains on
Hope that'll help you in some way.
**Please rate my post and/or leave a comment** ...Thanks...
Sep 25, 2013 | Motorola Mobility H560 Bluetooth Headset
My sony erisson c902 is not on i think it is freeze only blue light on the sreen is light up....what to do please help me:(
Unplug the battery, wait for 20 seconds, then turn the phon? on as usual.
If the phone won't turn on, connect it to the charger.
Sep 08, 2011 | Sony Ericsson Cyber-shot C902 Cellular...
When I plug in the adapter the blue light on the charger goes out immediately and does not charge the battery. I bought a new charger and it does the same thing. I've had both chargers checked and they are...
A bad battery is a definite possibility. Shorted cells are one of the ways they can fail, and then they put too much of a drain on the charger. Take the battery out of the laptop and see if the charger light stays on. This will eliminate the computer itself as the cause. Then you'll know you need to shop for a replacement battery. Replacement batteries are available from many sources online.
Mar 23, 2010 | Dell Studio 1737 Laptop
Wii console not working correctly
When you connect to the internet wirelessly and Wii Connect24 your Wii will stay connected and recieve messages, updates, etc. That is why the disk area stays blue and the amber light stays on. Sometimes this will create a power failure. Just unplug your Wii from the wall and let it rest for a few minutes and plug it back in. The problem should be solved.
Feb 22, 2010 | Nintendo Wii Console
Battery has gone dead. When I plug the A/C cord in the light on the charger immediately goes out and won't charge battery.
try connecting ac adapter alone without the laptop, check if ac adapter light will stay green or blue.
try another power outlet using the ac adapter alone without the laptop check if the ac adapter light will stay as green or blue. if all fails replace ac adapter.
if ac adapter stays green or blue try connecting to the laptop without the batt, check if the ac adapter light will stay on, if yes then try connecting ac adapter to laptop with the batt plugin check if the light stays green. if not update the BIOS. if fails replace motherboard.
Oct 12, 2009 | Dell Latitude D610 Notebook
S9 HD GREENLIGHT
The Headphones suffered a short, likely when you were plugging them in or off the charger. The easiest fix is to connect the headphones to your charger cable and then flicker the power...
so if you plug them into a usb charger cable to your pc, then quickly disconnect and reconnect the cable from your pc's usb port... this might not work due to the slowness of recognising the drivers.
if you have a wall charger for this unit, connect it up and then unplug it and replug it @ the wall multiple times. Or use a switched outlet/power strip to cycle the power to the charger quickly...
Worked perfectly for me!
Sep 20, 2009 | Motorola Mobility MOTOROKR S9 Wireless...
Jabra Bluetooth Headset with Adjustable Ear-Hook Headset Logo
359 people viewed this question
Top Jabra Radio Communications Experts
Jerry Greenberg
Jerry Greenberg
Mohammad Nawaid...
Level 1 Expert
Michial Gueffroy
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
