NO BLOWER NO AC AND HEAT - Heating & Cooling
    Guru:
  • 587 Answers
Check to see if there’s power to the unit,if none, check the breakers and fuses,
if there is power, check the wiring and connections.
Posted on Apr 25, 2009
I have 2008 captiva... My ac blor is not working..
HVAC climate contol , Heat an A/C blower motor not working ! The blower motor works for both heat an A/C . Manual or automatic climate control ? Blower motor is bad or blower motor control module is . videos on youtube on testing blower motor electrical circuits .
Mar 26, 2017 | AC Cars & Trucks
The Front Heat / Ac Work's ! ! ! ...When It Wants TOO
there is a blower relay circuit board located right by the blower motor which sounds like your problem to me i've worked on several that had the same type problem and thats what it was. the two blower motor wires will plug into it and there are two screws that hold it on
Apr 23, 2014 | 1996 GMC Safari
1999 VW Passat AC/heat doesn't work? The belt broke this summer? I was told should still blow heat even if no belt?
If you are talking about the belt for the ac compressor, yes the heater should still work.
If the blower is not working, you will need to have the blower motor checked for voltage and ground.
Dec 18, 2012 | 1999 Volkswagen Passat
I don't have a condenser in my pick-up trunk, so I don't have AC, is this also why I don't have heat or heat/AC fan does not come on
checked the fuse for the blower motor. if the fuse is good check for power at the motor. the blower motor is behind the golve box.
Apr 26, 2012 | 1998 Chevrolet K1500
'94 Cadillac DeVille Concourse. My winsdhield
Follow the wires from the blower motor back to the blower motor resistor, normally only a few inches away and held in by a 7 mm screw. Replace it
May 13, 2010 | 1998 Cadillac DeVille
1998 BMW 328i heater/AC blower is not running
You have clean the blower unit , may be its dirty then . and then check the blower resistor unit for malfunction.
Aug 04, 2009 | BMW 328 Cars & Trucks
Blower for ac/heat only work on lower 3 levels.
Check the blower motor resitor. Use a 12v test light at the switch and notice the bulb brightness change as you switch settings.. Probably have a bad blower resiter.
Jul 07, 2009 | Chevrolet Blazer Cars & Trucks
Blower for Heat/AC
blower motor resistor is in the front (right?) wheel well.
Oct 12, 2008 | 1987 Subaru Gl 4WD
Heating & Cooling Logo
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
