Question about Sharp Remote Control
My friend picked up the remote and it was hot. He took the batteries out and they exploded in his face and eyes. Battery acid went in his eyes and on his face.
  • 153 Answers
Need ice
and doctor
Posted on Jul 21, 2009
Lug on hot wire to starter broke off. where does it feed to?
If your ref to the battery hot wire, that goes to the starter
Nov 22, 2015 | 1999 Jeep Grand Cherokee
Changing a battery in a 2003 montana
Removal Procedure
Caution: Unless directed otherwise, the ignition and start switch must be in the OFF or LOCK position, and all electrical loads must be OFF before servicing any electrical component. Disconnect the negative battery cable to prevent an electrical spark should a tool or equipment come in contact with an exposed electrical terminal. Failure to follow these precautions may result in personal injury and/or damage to the vehicle or its components.
Caution: Batteries generate hydrogen gas, which is extremely flammable and may explode violently if ignited by a spark or a flame. Battery acid is extremely corrosive and causes severe personal injury if the acid comes into contact with the skin, and blindness if the acid comes into contact with the eyes. In order to avoid severe personal injury, use extreme caution when servicing the battery or battery-related components.
  1. Remove and reposition the underhood electrical center. Refer to Underhood Electrical Center or Junction Block Replacement in Wiring Systems.
  2. Remove the front end sheet metal diagonal brace. Refer to Front End Sheet Metal Diagonal Brace Replacement - Right Side in Body Front End.
  3. Remove the battery ground (negative) cable from the battery. Refer to Battery Negative Cable Disconnection and Connection .
  4. Remove the battery positive cable from the battery.
25455701-qhvfhjzcogsgbgv0osazuufu-1-0.png Remove the battery hold down retainer.
Important: Do not tip the battery more than 40 degrees.
Remove the battery insulator from the battery.
Remove the battery.
Feb 20, 2015 | 2003 Pontiac Montana
Altenator not getting power
if you mean alternator is not charging battery
a device called a voltmeter is needed to diagnose this problem
Jump start vehicle , disconnect jumpers from other car , use a voltmeter on the battery terminals to measure (red lead on + or plus and black lead on - or gnd ) have a friend rev engine slighty if voltmeter rises it's reading to 13.8 and stays there no higher you just have a bad battery you'll need to replace it but if reading moves all about your regulator is bad that will need to be replaced (usually ruins battery as well) and lastly if reading stays low and does not move up but goes down your alternator is bad that will need to be replaced
Note : when dealing with batttery on car allways shield your eyes just in case there is a fault and battery explodes , acid in your eyes is no good
Nov 12, 2013 | 1987 Ford Ranger
Can batterys be hooked together , 2 or more 12 volts and still be 12 volts.
I assume that you are talking about car or truck (vehicle) batteries or lead-acid accumulators. If so, yes, usually temporarily, when you need to boost a dead battery with a strong one, either for start-up or for charging purposes. The procedure is simple, but can be dangerous if an error occurs. A lead-acid battery contains dilute suphuric acid which can cause severe burns if it comes in contact with the skin or clothes (though some types of fabric are resistant to its effects). If fact, it can cause blindness if it explodes into you face. So beware. If in doubt, let a qualified auto-electrician do the job instead. Would you want to venture it yourself, so I can outline the procedure?
Oct 22, 2013 | 1997 Mercury Cougar XR7
I have a 1988 Honda CRV. I just put in a new alternator but forgot to take the battery cables off and blew the inline fuse. When I replaced the fuse it blows again when the battery hooks up to the...
big error that, can throw acid in the eyes, as battery explodes, if you do it wrong, so easy, lucky you did it on the safe side of fuse.?
pure random luck that, next time read the FSM before working electrics. every page tells you to pull then NEG battery lug first.
and the answer is, its shorted.
you never said the exact fuse, so i guess.
88 is very very old car,... docs hard to find.
here is the rules on electrics.
1: the fuse has a hot side, (Battery plus)
2: the fuse has a load side, (only you know this) and is shorted.
that's it, find the short by disconnecting the loads,
the fuse is expensive so I disonnect them all then add them back 1 by one till boom.
only takes 2 fuse, 1 to find it and 1 to drive after fixed.
do not fall trap to the dark side, of the force and use a jumper
for a fuse or you will have a fire, or battery acid in you face.
seen both so many times, as I yell to the guy, hey dont do that.... oops too late. NOOBS do get hurt all the time. even when warned
the battery is to be respected.
it can produces about 5000 watts of energy.
never ever, short this battery,
next post a , schematic, (close)
to post.
Sep 08, 2013 | Honda Cars & Trucks
When i turn the key it clicks once and i loose all power
Michael, either one or both negative and positive battery terminals are barely making connection OR you may have a broken battery post down inside the battery. That can be dangerous. I had one like that once. A friend sat inside while I fiddled with the connections. He switched on the headlights just before I pressed down on the terminals. A spark was created inside the battery (where hydrogen gas is) and the battery exploded in my face, partially blowing the top off if it. I quickly went inside and got into the shower full clothed so I could wash the battery acid off of me and my clothes. I was OK and lucky.
Dec 23, 2011 | 1991 Honda Accord
Turned key heard pop interior light flashed car went dead think battery exploded can it mess up other things in car
Yes it will the acid from the battery will eat stuff. Take baking soda and water mix and poor it where the acid went. this will neutralize the acid. 1 box of baking soda per 5 gallons of water or so. do this as soon as you can and you wont have a problem.
Jun 07, 2011 | 2002 Chevrolet Impala
Can i jump start an audi a6 2005
On the 2005 Audi A6 3.2 (6 cylinder) the battery is stored in the right rear trunk, under the trunk floor lid. Note: To jump start the car, you simply raise the engine hood, and look in the upper left corner of the engine compartment, just slightly below the plastic cover. There you will see connections that lead to the battery and are specifically designed for jumping (or charging) the battery. You will need to lift up gently on a reddish brown cover which is protecting the positive terminal. The negative terminal (black) is not covered.
Under no circumstances should you attempt to jump the battery directly. The battery could explode and you could get sulfuric acid on your face and in your eyes, which would be bad. Very bad.
May 16, 2010 | 2005 Audi A6
95 jeep cherokee wont start
1.Loose Battery cable. Very common thing for a side post battery.
Solution: Tighten both battery clamps as needed.
2.Corroded connections for battery cable ends. The cable ends that connect to the battery.
(A side post battery was a bad idea IMHO.
When a battery is made the posts come up through a plastic case. There is a seal around the post, under the plastic case that you cannot see.
This seal allows battery acid to eventually leak out.
It was bad enough for a Top post battery, but seems like a ridiculous idea placing the posts on the side!
The idea was implemented to save space, so that cars could be made smaller)
Solution: Clean battery clamps, and side post area on battery.
SAFETY ADVICE!!
Hand Protection:
Gloves should be worn when working with a Battery.
Dishwashing gloves would work, but be sure to replace them, if a hole is torn while you're working.
Thin leather gloves are preferred.
Clothing:
Use old clothes that you do not care about, and may be thrown away if needed.
Eye Protection:
Safety glasses, or goggles should be worn. If safety glasses are not available, at least wear some sort of eye protection.
As said, battery acid does leak out. Usually a tiny amount, and not always seen. Even if dried, it is still potent.
This is Sulfuric Acid.
It will eat holes in your clothes. You won't notice it until you go to wash your clothes.
It will burn your skin, and eyes. DO NOT touch your face until the gloves are removed, and you have thoroughly washed your hands.
Use cold water first. Warm water will open the pores of your skin.
After using cold water, and thoroughly cleaning your hands, then you can use warm water.
When disconnecting a Battery, ALWAYS disconnect the Negative terminal first! Positive terminal last.
When connecting, Positive terminal First, Negative terminal last.
You can use a solution of Baking Soda, and water to clean the battery clamps.
Two tablespoons of Baking Soda to a 12 ounce glass of warm water thoroughly mixed. (It won't mix all the way. Squish it around in the glass as you are using it)
You Cannot use this mixture on the Battery. There is a chance it could go through the seal/s, and will nullify the battery acid inside, ruining the battery.
A wire brush is used for this application. (One of the reasons the eye protection is imperative. The wire brush bristles could sling dried battery acid up in your eyes)
3.Bad battery:
Could be the battery is at, or near the end of it's 'Lifetime'.
4.Bad Alternator:
The alternator isn't working, therefore isn't charging the battery.
5.Loose or Worn Alternator belt:
The belt/s are worn allowing the belt to slip on the Alternator pulley.
Dec 20, 2009 | 1995 Jeep Grand Cherokee
2006 Chevrolet Equinox LS 3.4L battery exploded
First, I hope you diluted the battery acid with a little water. Most batteries create explosvie gas (hydrogen). If it isn't vented well, the gas could build up and a spark from even a dirty terminal can set off the gas. Are you saying that you've determined that Chevy Equinox cars are prone to explode their batteries? A sealed battery, such as the Optima, releases no vapors. Such a battery would probably solve your problem.
May 26, 2009 | Chevrolet Equinox Cars & Trucks
Televison & Video Logo
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
