Question about Lexmark All-in-One Printer with PictBridge
Allignment is off on a lexmark x6150
The paper keeps getting jammed when going through the feeder.
  • Lexmark Expert
  • 228 Answers
Most of the Lexmark printers (including the Z- and X- series) pull the paper down on one side slightly faster than the other. The printer hardware should even this out when printing. You should also ensure the paper meets the automatic feeder requirements of the printer.
If printing is skewed, feeding multiple pages or jamming, please follow these instructions (use a regular letter size paper to test after doing the steps given below):
Please check to ensure there is nothing obstructing the paper feed mechanism down inside the printer where it is not easily seen. If there is nothing obvious, unplug the printer and remove the paper. Open the front cover and look above the steel rod. You should see a conveyor belt with rubber teeth on it, like a fan belt. Take the bottom part of that belt and move it gently to the left. The cartridges should come out with it. Make sure the cartridges can move fully from one side of the printer to the other. Check also the output rollers on the bottom of the printer for any blockage. If it is jamming under the carrier assembly, you may be able to fix it using the manual feed slot. Turn the printer off. Next take a #10 envelope and feed it through the left side of the paper feed slot (The manual paper feed slot is preferred, but the automatic feed will do if there is no manual paper feed for this printer) until it comes completely through the printer to the back of the exit rollers. Move it up and down and slowly move it over to the right side. If something is stuck under the black guide plate this may work it loose or you may have to feed the envelope through the front rollers and push your way backward (please be careful here).
Next, take a damp warm cloth and clean the rubber rollers in the automatic sheet feeder. Dust may be coating the rollers there and as they become less tacky, they cannot feed paper correctly.
Then plug the printer back up, take your paper out and replace it with a fresh, small stack (about 5 pages) of paper. Quickly bend the stack in an 'S' shape a few times to separate pages. Make sure it is lined up on the right side of the paper feed and the paper guide on the left is snug on the left side of the paper. Then try to form feed again. If that works, then try to print the self test page.
Please follow the steps given below to perform the self-test:
1. Press the "Options" button 9 times. "Maintenance/Align" should now appear in the display screen.
2. Press the "Right Arrow (+)" until "Test" appears.
3. Press "Select."
You should see text followed by a thick 1-inch black bar. Under this bar, should be a process gray bar about a 1/2-inch thick. Below this line should be a set of railroad like bars of cyan, magenta, and yellow.
Should this test fail, try it again without cartridges installed. If the self-test still fails to take paper in and make sounds like the carrier is moving across the paper, this is a hardware issue, and the printer will require service. If the self-test completes without any cartridges installed, run the self-test again with only the color cartridge installed. (If you have both black and color cartridges, after this test, run the test again with just the black cartridge installed.) If you find that either cartridge causes the self-test to fail, please let us know.
If the self-test prints, but has lines or smudges or other print quality issues, please let us know. This includes any print quality issues, we need to know if the problems you have with your black or color are based in the printer, or communications with your computer, or the computer's software.
If the self-test prints your test bar(s) clearly, the printer hardware is not at fault.
Posted on Apr 14, 2009
Fix paper feeder that keeps jamming. How to clear jam and fix on-going jamming problem
What thickness of paper are you using? Also is the paper new/fresh or are you re-using paper that has gone through the printer already?
Mar 03, 2015 | Lexmark X4550 Wireless All-in-One Photo...
How to open x6150 for paper jam.
support lexmark com
Try this link for assistance. It has good images on how to open the printer.
Sep 21, 2014 | Lexmark X6150 All-In-One InkJet Printer
Ok i have a problem. my lexmark x6150 won't take in paper right. it only takes it in on the right side. what is wrong?
Did this start with a paper jam? There could be a piece of paper(ripped corner) binding up the wheel on the left side.
Nov 05, 2009 | Lexmark X6150 All-In-One InkJet Printer
My lexmark x4650 keeps on getting paper jams and i think its something to do with the roller so any info please help :D
The unit may have a paper jam or stuck object inside, if you have experience a paper jam error before, check the printer for any object or paper stuck inside, clean roller.
Some error like this can be a problem on the feeder sensor and by this time you may need to replace and repair the unit.
Hope this initial info helps
Sep 13, 2009 | Lexmark X4650 InkJet Printer
Canon iP 1300 keeps coming up with Paper Jam
this problem may be due to many reason.
first due to moisture in paper. try some good one and rey paper.
second due to dirty paper feed roller problem. clean the roller with moist cotton using cleaning liquid such as spirit, petrol or nail polish remover.
and last may be due to mis allignment of paper feeder assembly contact any printer specialist.
Aug 21, 2009 | Canon PIXMA iP1300 Printer
Hi I get this 250.07 paper jam check mp feeder on Lexmark t644
Please try this
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Jun 09, 2009 | Lexmark T644 Laser Printer
Jamimg paper
your printers paper feeder is jammed.needs quick printer servicing to solve this problem.
Dec 28, 2008 | Lexmark X6170 All-In-One InkJet Printer
Unable to print properly keeps printing on one line
Sounds like there is something jammed in the paper feeder, or maby its the paper feeder itself. Check to see if the path the paper follows through the feeder is completely clear. Sometimes paper is left in the feeder from previous paper jams.
Aug 07, 2007 | Lexmark X73 All-In-One InkJet Printer
Printer pulling on paper
My husband took the top cover off the printer and took a good look inside with a flashlight. He found a hot pink crayon stuck where the paper feeds through. I guess I should have had a better look initially, since the paper never made it all the way through the printer. Works like a charm now!!
Feb 23, 2007 | Lexmark X6150 All-In-One InkJet Printer
Lexmark All-in-One Printer with PictBridge Logo
199 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
