Question about Dryers
The belt has come off. How do I put it back on?
My Neptune dryer, model #MDG3000AWW has come off. How do I fix it? It looks so complicated, but I need to try to fix it myself. Budget.
  • 686 Answers
IF IT HAS JUST COME OFF OF THE MOTOR THERE IS ONLY ONE WAY IT CAN GO BACK ONTO THE MOTOR AND TENSIONER BUT I CAN TELL YOU MUCH IT HAS GROVES ON ONE SIDE, MAKE SURE THAT THE GROOVES ARE FACING OUTWARD SO THAT WHEN THE BELT IS ON THE DRUM ITSELF THE SMOOTH SIDE IS WHAT RIDES ON IT. REPOST IF YOU DON'T UNDERSTAND OR CALL ME JIM 417-926-0106.
Posted on Apr 14, 2009
Neptune dryer not starting
Yes, I recommend you type in "Sears Parts Direct" to your computer search engine.
Put in your model number in the box, and you will see schematics that will answer your questions.
God bless your efforts.
Feb 26, 2016 | Maytag Dryers
Maytag neptune dryer belt off and loose
If belt is not broken, then the tensioner is not routed properly. Generally belt comes around drum, then around tensioner pulley then on motor pulley. Tensioner is spring loaded, so you need to pull up on tensioner to get belt around motor. Good luck.
May 05, 2017 | Maytag MDE9700AYW Neptune 174 Electric...
My mytag Neptune Model MDG3000AWW dryer is having starting problems. When I put the same amount of wet towles in for drying as I have allways done. and push the start button it just humms like it wants to...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 06, 2011 | Dryers
I have a Maytag neptune model mdg3000aww, and the spin cycle is not working. I have replaced the control board, yes the r11 resitor was burnt, the wax motor, yes the door lock light comes on now, and...
Did you check the out of balance switch on the bottom.I FIXED ONE LAST WEEK. All I did was push it a couple of times real hard until I heard it click. You can activate the diagnostic mode & see if the out of balance switch is activated. That is what I did after I found out the out of balance switch was activated & stuck on, I pushed it twice & it deactivated & spun out fine.
Sep 29, 2010 | Maytag Neptune MAH5500B Front Load Washer
Neptune mdg3000aww starts heating and runs fine but stops heating shortly after start up can restart heater starts again and shuts down
If the machine keeps running but just not heating you have a thermostat issue. It could be the operating therm. or the high temp limit therm malfunctioning, shutting off the element.
If the machine stops running completely, check the door switch.
Jul 09, 2009 | Maytag Neptune MDE5500AY Electric Dryer
My maytag neptune gas dryer model #MDG3000AWW When I push the start button on my maytag neptune dryer it sounds like it wants to start but doesn't and then it gets this smell like something is burning?...
It sounds like the drum bearings are seizing up preventing the drum from rolling easily, and when the motor runs, it can't pull the drum belt around the drum that won't turn, so starts squealing and burning the belt.
You need to lubricate/replace the drum bearings, and replace the belt.
Jan 29, 2009 | Dryers
Maytag gas dryer runs, doesn't dry
Check in the hole where the screen goes for blockage. Many times debries falls in there when removing screen. It cant make it out of the vent so it builds up and clogs the vent.
Dec 01, 2008 | Maytag Neptune MCG8000AW Gas Dryer
Dryer belt off
found a site for you to look at.http://www.repairclinic.com/0047_8.asp .Let me know if this is the right dryer and we can go from there..*****
Nov 01, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Maytag MDG3000AWW drum moving slowly
If the belt looks worn you should replace it. But it sounds like the idler pulley has gone out of position or possibly broken. The idler pulley adds tension to the belt and keeps it from spinning on the drum surface. Check the path of the belt on the bottom of the dryer. That is where the idler pulley is.
Feb 01, 2008 | Dryers
DRYER WON'T HEAT.
ok facing the drier front open thee door and remove the bolts around the door panel there are four of them two on each side then grasp the front about 3 inches down on either side to disengage the side retain clips tilt the panel back toward you and lift it up to disengage the bottom clips remove the front panel and if you need to lift the top remove the screws on the hooks on either side at the top and take the hooks off then you can lift the top that should give you plenty of access to do what you need to do
Jan 20, 2008 | Maytag Neptune MDG5500AW Gas Dryer
Dryers Logo
103 people viewed this question
Top Dryers Experts
