Question about Nokia 9500 Communicator
Though it shows network signal excellent does not to the net wort
Sir, nokia 9500 setup to connect to internet through the wlan netgear. It recevies signall excellently and even from some other's distant wlan also thogh poorly but fail to establish connection even with strong signal from router.
  • 1 more comment
  • vpsarma Apr 14, 2009
    Sir,
    Nokia 9500 communicator got internet setup with security modes 1) None 2) WEP 3) WPA 4) EPA
    NETGEAR router(WGR614-V9) I am using has got all the above security modes. I tried with none and wep and the rest two I feel complicated and cumbersome. Kindly suggest me based on this information. It shows signal strength as excellent but does not rcognise and connect. When I move far out of house it shows descriptively fall in the signal strength and even picks up another signal of another network in the neighbourhood.
    Thank you and Fixia
    vpsarma@yahoo.co.uk
  • vpsarma Apr 15, 2009
    Dear sir,
    Neither my nokia 9500 communicator nor my NETGEAR router had any security mode WEP4. I only serially numbered the security modes available in those unts. You must seen a space between WEP and 4) which is order of WPA
    Dear sir,
    Sofar I have not used either WPA or EPA modes while setting up the NETGEAR router. Wi-Fi is part of WPA mode in the units I use. About entering security code the router generated entering in the phone when asked while trying to connect to Internet, the phone is immediately showing error for writing any worng letter entry. so it is functioning on being it is guarding the security. So problem of security is not there, When no security is set on none that is securitity is not selected at the router then also the phone is not picking the net work. So far I had 3 or 4 times setup router and phone. Once I formatted the pbone memory also.
    President:
  • Nokia Master
  • 762 Answers
How is your router set up? Are you using WPA or WEP security? WEP is the newer encryption and I'm affraid 9500 doesn't support this. Would try update firmware and hope that Nokia integrated fix for this in to the update.
Rate me if it helped. Thanks.
Posted on Apr 14, 2009
  • 270rexton
    270rexton Apr 14, 2009
    Well WEP4 ...I've never heard. But can you delete all partnership(wifi connection) and start again connection with your router? If it give you choice you will be asked type of connection and password. If you can, choose WEP or WPA(WPA2) and type your password (key string) . Both connection should support wifi b/g (11/54MBs).When you type your password save it so you wont need type anymore.
  • 270rexton
    270rexton Apr 15, 2009
    Ok, try this : delete all existing pairing in your device. then go to your Netgear webpage (should be numbers :http://192.161etc) log on and check what encryption you have. Could be WEP or WPA. then write down password. On your Nokia go to SEARCH WIFI and when your router is located choose that encryption which is on Netgears setting and type password.
Mywifiext net
Have you first established the connection between the Router and the Extender?
If so, have you connected e.g. a laptop to the Extender?
So if your WLAN networks SSID is NETGEAR, the WLAN network of the Extender is NETGEAR_EXT and you have to connect the laptop to NETGEAR_EXT.
Then you have to open your favorit internet browser and have to type in www.mywifiext.net, which I guess is a buildin Setup-Assistant.If this doesn't work, make sure, your laptop is configured, to get an ip address automatically via DHCP.
Or read http://kb.netgear.com/app/answers/detail/a_id/20912
Apr 26, 2013 | NETGEAR CONSUMER New - Netgear Wn3000rp...
Nokia 9500 network signal is not working
If the 9500 cannot communicate via WLAN but is getting a connection - do the following:
1 - set up a new Internet Access Point in control panel
2 - use the SSID (WLAN Name) to identify the network
3 - set 'Automatic IP address' to NO (Advanced Settings)
4 - give the device an IP address from the range being used on that network
5 - set 'Automatic DNS' to NO
6 - enter a pair of DNS server IP addresses (from your ISP)
7 - back up the phone settings so you never have to do this again
May 29, 2012 | Nokia 9500 Communicator
I just installed a netgear router and I installed a netgear adapter on my other computer. Everything says it is working, but it will not let me connect to the internet. My signals shows...
always connect to your router with a wire to get it setup. You will have to configure the wireless before it will accept connections. This can be done through the routers web interface one you are connected to it with a network/cat5 cable. the web interface can be reached typically at 192.168.0.1 or 192.168.1.1 instead of typing www type the numbers.
Aug 27, 2010 | NetGear : WG111 54 Mbps Wireless USB 2.0...
I have a netgear rangemax due wireless n router. I had a friend, who is good with computers, set it up for me last april. he set it up through my desktop, which is connected directly to my broadband,...
These are some reasons why your new Hp laptop can't connect through your Netgear Router is because your Router has a security that used a password to connect to your router or the ip address of your desktop and Dell laptop is already setup to the router to work with internet.
You can learn how to setup your router easily.
Smart Wizard:
http://syndicate.sellpoint.net/Netgear__Inc_/90983/16285-8W6DBC-28-player-T1_MP/MPPlayer/MPPlayer.html?Master=Self&PlayerTitle=&ShoppingCart=http%3A%2F%2Fsyndicate.sellpoint.net%2FNetgear__Inc_%2F90983%2F__buybutton__.html&LVerify=Syn-WMP2YD-90987&Width=536&Height=525&ParentUrl=http%3A%2F%2Fwww.netgear.com%2FProducts%2FRoutersandGateways%2FWirelessNRoutersandGateways%2FWNDR3300.aspx
Netgear Data Sheet:
http://www.netgear.com/upload/product/wndr3300/wndr3300_ds_25sep09.pdf
Here's the instruction how to access your Netgear Router (to change the settings and to allow your new Hp laptop to connect to the internet)
http://www.ultimateone.co.uk/article/netgearrouteripaddress
I suggest to use a password security, for easy connection of your computers
Jan 18, 2010 | NetGear WNDR3300 - RangeMax Dual Band...
How to connect my nokia n95 to wifi
Sir,Your required Wifi Connection to access internet OR you can access internet using GPRS service Nokia N95 you.For-you require Wifi router then your mobile will detect that wifi connection and you will be able to access internet on your mobile phone.
Dec 10, 2009 | Nokia N95 Cellular Phone
Nokia 9500 get restart when click Internet Broser / WLAN setting
Your firmware is ANCIENT. If you have installed Nokia PC suite in your PC connect your (fully charged) phone and click on Software update. If don't have it, then go to Nokia web and download it. YOU NEED FIRMWARE UPDATE.
Oct 16, 2009 | Nokia 9500 Communicator
Wep key for nokia 9500 communicator
wep key is the password you give when you own the connection, so that not everyone can connect to the net and do nefarious acts on the net and get you caught. so, for wep key, you must ask the owner/administrator of the connection/phone that has the WLAN.
Aug 30, 2009 | Nokia Cell Phones
Nokia E61 Wifi connection
setup Internet access point for WLAN menu>tool>settings>connections>access points select options>new access points Enter Connection name Data bearer: select Wireless LAN WLAN network name: select search wlan to select wlan in range. network status: select "public" if you can see wlan in range WLAN network mode: select infrs or adhoc WLAN security mode: select same settings used by WLAN access point WLAN security settings: Homepage: select the homepage you want
now you can connect & browse the internet. hope this helps
Jul 08, 2009 | Nokia E61 Smartphone
Connecting to the internet
Hi
Tap Start>Settings go to Connections then tap on the Advanced tab at the bottom. Tap the "Select Networks" button. Select your wireless network that you have created for the internet connection instead of the mobile internet connection.
Thanks
C
Apr 04, 2009 | HTC Touch Diamond Smartphone
Nokia 9500 Communicator Logo
303 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
