Question about Nokia 7373 Cellular Phone
Nokia 7373 problems with name directory
I have 50 name entries on my SIM card, but the phone tells me that there are 260 name entries and it`s full. I switched my SIM card with friend`s and the error is the same. How can I fix that? Thanks!
  • 89 Answers
First i want to tell you that there are two ways to store your name + number entries on the mobile phone 1 Sim memory 2 Phone memory in your case the number must be in phone memory you may be previously entered and i like you also have some memory patch on your phone these often cause such problems Solution note all you entries on a note book and delete all the contract and then reenter them again .. or else try format you mobile phone which is a bit annoying thing
Posted on Sep 14, 2007
SOURCE:
How to switch fixed dialling on nokia n73?
Press menu button and select Contacts > Options > SIM contacts > SIM directory to see the names and numbers stored on the SIM card. In the SIM directory you can add, edit, or copy numbers to contacts, and you can make calls. To view the list of fixed dialing numbers, select Options > SIM contacts > Fixed dialling contacts. This setting is only shown if supported by your SIM card.
Oct 17, 2009 | Nokia N73 Cellular Phone
Nokia 7373
I bought Nokia 7373 on ebay, not unlocked, my mistake! So after a lot of searching I found [email protected], PIN and PUK numbers usually come into play if you enter something the phone doesn't like, so I suggest you email them they charge £3.99, they need to know IMEI code and provider model and make, seems to me you have those, then £3.99 credit card or paypal and they unlock. If they cannot do this they refund your money. I discovered Nokia 7373 needs BB5 cable, but it may be different for you. Good luck
Apr 27, 2009 | Nokia 7373 Cellular Phone
Nokia 7373
Try a reset:
How to reformat your phone,
Take your SIM card out.
Make sure your phone battery is fully charged.
Press * 3 send at the same time and turn the phone on. Keep them pressed until the reset screen appears.
Give it time to reset.
Yes! I know. You need someone to press the ON button.
* is at the bottom left of the key pad.
3 is the number 3 on the key pad.
Send is the green button on the key pad.
Jan 03, 2009 | Nokia 7373 Cellular Phone
Contacts
If you have phone numbers stored on the SIM card, copy them to Contacts. Entries that are saved ONLY on the SIM card are not shown in the contacts directory. So for incoming calls and msgs, the phone cannot match the number to the name.
To copy individual names and numbers from a SIM card to your phone contacts:
Menu/Contacts/Options/SIM contacts/Sim directory. Select the names you want to copy and: Options/Copy to contacts.
Feb 08, 2008 | Nokia N70 Cellular Phone
My nokia 7373 is not working
there is a problem with the simcard or the software in your cell phone or format ur cell phone and change the sim card
Jan 29, 2008 | Nokia 7373 Cellular Phone
Nokia 6233
The problem is most likely because on your previous phone the names and numbers were stored on the phone memory and the sim card memory. Before removing your sim card from the old phone, you first need to copy all names and numbers from the phone memory to the sim memory and then when you transfer the sim card to the new phone you should have all the names and numbers as before. Just beware of a few potential problems. First, sim memory only generally allows entries of 14 characters and secondly there is often a limit to the overall capacity of names/numbers to 250 or maybe 300. So if you have a huge directory, you will in effect need to copy the data in blocks of say 250 entries from one phone memory to the other using the sim card as a portable memory device or else try a phone shop like Carphone Warehouse who might just do the whole job for you.
Jan 04, 2008 | Nokia 6230
Text messages
They stay on your phone but you will have to delete some eventually, otherwise your phone memory will be too full to operate.
Nov 12, 2007 | Nokia 7373 Cellular Phone
Wont make calls
Check your credit,
Check your service signal,
Check there's a SIM card in the phone on the correct network.
Nov 11, 2007 | Nokia 7373 Cellular Phone
Nokia 7373 memory card
the phone memory is full thats why you cant receive anythink.try to delate some messages and move some of your pictures,videos songs on your mmc.
Sep 05, 2007 | Nokia 7373 Cellular Phone
Nokia 7373 Cellular Phone Logo
66 people viewed this question
Top Nokia Cell Phones Experts
jonathan mariano
jonathan mariano
Ekse
