Question about Dryers
Will turn but will not give off any heat.
My clothes dryer won't give heat but it turns and clothes will not dry.
  • 686 Answers
POST THE MODEL NUMBER AS SHOWN ON DRYER PLEASE
Posted on Apr 14, 2009
Dryer won't dry clothes
Heating element faulty not giving as much heat as it should
Nov 14, 2015 | Dryers
the heating unit must have been broken. go to near by mechanic shop.
Jan 31, 2013 | Dryers
First check and see if your heating element is working by holding down the dryer door switch and turning on the dryer too see if you get a glowing from the rear inside of the drum. If it does glow then check to see if you have a kink in your dryer line or check to see if you have a clogged vent outside the vent to the dryer. Also you may want to try resetting your power to the dryer by unplugging the dryer and turning off and then backb on the breaker to the dryer then plug the dryer back in and see if that works.
Nov 09, 2012 | Dryers
Kenmore dryer 110.86864100 - Where is the moisture sensor?
Ain't no moisture sensor. This is is not an electronic sensing machine. It uses another method to determine dryness. An orange wire connects to the base of the heating element. The timer motor is driven by power from it in auto dry. The timer motor is VERY slow. Slower than most dryer timer motors.As the clothes get dryer the heat is not needed so the element is turned off by the control thermostat which is mounted next to the skinny white fuse on the blower housing. This allows for the turtle like motor on the timer to advance. Once the clothes get to the point of dryness the heater stays off way longer and the timer motor advances on over to the cool down and carry on over to the end of cycle. So the clothes won't always be dry due to factors like lint buildup in the blower housing, venting to outside and so forth. having said that my mom bought a brand new Kenmore dryer and I set it on 55 minutes timed drying. At the end of that them clothes is still damp. I then set it to auto dry high heat and that usually gets em dry. I think the main probo with this dryer is the thermostat ain't set as high as older models to keep the heat at a moderate temp so that the limits won't blow on models in apts and such. Just a theory.
Sep 16, 2012 | Kenmore 659 Electric Dryer
My dryer won't dry my clothes
clean out lint filter check the vent hose make sure you are getting a air flow out your vent hose if not its blocked inside no air no dry it need air to dry cloths heat only will not dry plenty of air heat quicker drying
Nov 27, 2011 | Whirlpool Dryers
Clothes won't dry in oasis gas clothes dryer. Heats up but no air comes out exhaust. lint screen is clean
If your dryer is not drying like it once did or if you just have nottaken the time to give yourself a clean dryer in a long time then youneed to do that. At least once a year the dryer cleaning should takeplace. Lint build up in the dryer duct is one of the main causesfor your dryer to fail.
Here is the rest of this tip about DryerMaintenance
heatman101
Aug 19, 2011 | Dryers
My dryer takes longer to dry my clothes than normal and after 2 drying cycles it hesitates to turn on or won't turn on at all for about 20 minutes, then it will turn on.
heatman101
May 23, 2011 | LG DLE2514 Electric Dryer
Clothes not dry but dryer turning. cleaned out
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Jul 09, 2010 | Roper RGX4634KQ Gas Dryer
The dryer runs fine but the clothes are not getting dry....we have to turn it back around 4 times to get them dry which is tough on the power bill....another thing..lint is not collecting on one half of...
heatman101
May 20, 2010 | LG DLE0442 Electric Dryer
LG TROMM Front Load Dryer / Not drying clothes
check the vent or condensor depending on what type of dryer.
Sep 28, 2009 | Dryers
Dryers Logo
62 people viewed this question
Top Dryers Experts
