Question about Acer APFV MT (APFVUP5152) PC Desktop
Moniter flicker Recently my monitor started to constantly flicker with little dots. The dots are only in a spefic part of my screen (a band of around about 2 inches on the right hand side of the monitor). I've looked on numerous blogs,and changing the refresh rate seems to be a good start but the only rate it allows is 60 hertz. Also I have an S3 VIA chrome9 HC IGP video card. In the settings it only recognises a CRT moniter but it's an LCD. Any help appreciated.
  • jon98 Sep 13, 2007
    I've checked the driver, and it is the correct one...
    Then i tried your second solution, but the only mode it allows (which isn't rediculously large or fussy is 1024 x 768 32 bit 60 hertz.
    Also, it was strange because at some stage the standard resolution options available changed form allowing only 3 diffrent modes, to all modes, and previously i was able to change the refresh rate to 75 (which solved the flicker) but now there is no option until the advanced tab, where it tells me it isn't compatable.
    Any other suggestions?
    Thanks again for your time.
    Problem Solver:
  • 9 Answers
Check whether there is any magnetic material near to the monitor(Speakers, Adaptor, UPS etc). Try again after removing it.
Posted on Nov 12, 2008
    Scholar:
  • 33 Answers
Any monitor flickers at 60 hertz. The usual reason for being unable to use faster refresh frequencies is that the correct video card driver and/or monitor driver are not installed. Another possibility is that the resolution is set too high. Assuming Windows XP, right click on the background, choose "properties", settings tab, advanced button. Check to make sure your video card is named - the monitor is not as important but would certainly be helpful. If not, did out the CD's that came with them or download drivers from the manufacturer's website. On the other possibility, on the adapter tab, there ought to be a "list all modes" button so you can choose resolution and refresh rate at the same time. Your LCD monitor will be fussy about the resolution, so you may need several tries to get something that looks good and doesn't flicker.
Posted on Sep 12, 2007
Dotted lines across the top of the screen and flicker in other video ports.
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Mar 05, 2017 | Westinghouse LVM-42w2 Television
The moniter blacked out, blue light is saying the moniter is still on, but screen looks like there is no power. When you turn on the moniter, the screen shows up for a few seconds, then blacks out again!...
Unplug power. Unplug VGA cable. Remove back of monitor. (four small Philips headed screws along the bottom rear. Remove screws attaching Monitor to it's base. Carefully, lean the screen away from back of case. Gently unplug 25 pin cable from the screen.
Connect AC power.
Screen should power on Gray to White. Ble light comes on Blue.Flickers then changes to Amber.
Reconnect VGA cable. Monitor should work.
Close up the monitor in reverse order to opening it.
If these steps don't solve your monitor, consider replacing as cost of repairs may shock you.
Sep 09, 2010 | Proview PL926WBi 19" LCD Monitor
White static flickering on Viewsonic VA1912wb
Please check the line voltage 220V AC and check the earthing voltage 3V AC..
Jul 09, 2009 | ViewSonic VA1912wb 19" LCD Monitor
Monitor flickering
Hi
Change the power cable if that does not work the power connector on the monitor may be faulty, Test the moniter on a different computer
Mar 28, 2009 | Acer Aspire 4315 Notebook
My LG Flatron L1515S Lcd moniter is Flickering
i am having also same problem...
Reddy - 9700704407
Aug 14, 2008 | LG Flatron L1515S 15" LCD Monitor
Laptop malfunctioning
Connect any Desktop monitor to the Laptop and check whether the Display. if the display is fine on the Desktop monitor screen then it can be identified as the Laptop screen malfunctioning.
And if the Display has the same issue that on the Laptop screen
then it can be treated as the Display card issue.
However, it seems to be Harwre related issue. Get the laptop veriufied under Technical supervision to repair the Laptop's display card or the Laptop screen to be replaced if the display is fine on the Externally connectd Monitor.
Aug 04, 2008 | IBM ThinkPad T40 2373 Notebook
Screen Shaking
make sure your pins on your mail connecter are 100% ok,then u
UPS of that system place far from the moniter .Insert VGA driver cd into drive and driver update via device manager and restart u r
system.In case ur graphics card damaged the moniter normaly
work as u describe.
Jul 17, 2008 | Samsung SyncMaster 753S 17" CRT Monitor
I have noticed recently that the screen words flicker.
If the monitor is less than a year only, then your best bet is contact the manufacturer for warranty support.
http://www.acerpanam.com/synapse/forms/webpage.cfm?siteid=7117&areaid=2&website=AcerPanAm.com
Jun 14, 2008 | Acer AL2017 20" LCD Monitor
Moniter back on whack!
sound like you have bad solder connections, sometimes the break is so small they can be hard to find. Unplug the unit for a short while & take it apart to look for bad connections, most likely they will be on the main board. Monitors have more shielding ( to remove interfearance) so it typically is a little harded to repair a monitor than a tv. good luck
Nov 20, 2006 | LG Studioworks 57M Monitor
Acer APFV MT (APFVUP5152) PC Desktop Logo
188 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
