Question about Toshiba Wireless Mouse PA3205U-1ETC
BATTERIES??? ARE THERE BATTERIES AND IF SO HOW DO I REPLACE IT/THEM???
    Novelist:
  • 177 Answers
Yes, There are always batteries in a wireless mouse. Always.
Somewhere on the mouse (usually on bottom, underneath) is a release button to peel the mouse open. you will find it rather quickly how to do this.
Posted on Apr 20, 2009
My cart has 6 8volt batteries that are dead my manual shows 4 12 volt batteries should I replace the 6 8 volt with 4 12 volt batteries
make sure that they are in fact 8 volt batteries
You can replace them with 6 by 12 volt batteries as the end voltage (48 volts ) is the same
Mar 22, 2016 | Golf
Where is the power strip on the Kwikset power bolt?
8. Replacing the batteries: - please follow these instructions to replace the batteries on your Powerbolt 1000 unit:
Remove inner cover plate located above the thumb turn on the inside of the door. Click here to view instructions on how to remove cover.
Replace all 4 batteries with quality alkaline AA batteries. (Do not use rechargeable batteries.)
Ensure that the batteries are correctly oriented or unit will not function properly.
Apr 21, 2015 | Kwikset Locks & Locksmithing
Do you have to change batteries on clock inside house along with outside batteries to get correct outside temperature
My most consistent (best, repeatable) results with this process are to replace both sets of batteries, both in the clock and in the outside temperature sensing unit. Start by removing all batteries out of everything. Now replace the batteries in the outdoor unit, then (within 30 seconds) replace the clock batteries. The temp unit should begin communicating normally within 5 minutes (or less) and yes, you will have to reset the clock,
Nov 01, 2014 | Lacrosse La Crosse Technology Wt-5220u-it...
How do I replace the 2 AA batteries on the ML1W2AAE flashlight?
Unscrew the base counterclock wise until it comes off. Remove the old batteries, and insert the new batteries making sure that you insert both batteries positive (+) end in first. Replace base cap.
Aug 12, 2014 | Energizer ML1W2AAE 1 Watt Led Metal...
Replacing batteries on Energizer Hard Case Lantern
If you have the Energizer Hard Case Lantern TUF4D1, simply grasp the whole front of the lamp piece (including the rubber cover), and twist in a counter-clockwise direction to remove. Then squeeze together the two black tabs and pull the battery compartment out to replace the batteries.
Jul 05, 2010 | Energizer Eveready TUF4D1E 4D Cell Lantern
Camera says replace batteries even when fresh ones are installed
Sir/Maam,
Have you tried using new batteries? How long have you been using the old batteries? As far as i know, the longer you use a rechargeable batteries, the shorter its life(compared to the first time you used it).
Try using new batteries, if the problem is still there, the camera my have the problem. But if the camera works fine, then your old battery is defective.
Keep me update, hope i helped you. Thanks.
Feb 27, 2010 | Canon PowerShot S3 IS Digital Camera
Error says replace w high capacity battery have new batteries in
Buy Energizer electronics batteries or Rechargable NImH batteries. These are better for high drain devices such as digital cameras
Dec 22, 2009 | Samsung S860 Digital Camera
Camera says "change batteries" even with new batteries
Hi, Has anyone resolved this issue yet, I have a powershot s2 IS with the same issue - i replace the batteries with brand new duracell's and it says replace batteries i reseat the batteries and it works for a few pics if im lucky then says replace batteries again - any help would be appreciated - Canon offers no solution.
Oct 13, 2009 | Canon PowerShot A720 IS Digital Camera
How long do batteries last? How do you replace batteries?
Why don't you just replace the batteries yourself now and then you'll know when they were put in. The cost of 4 x AA batteries is pretty cheap for peace of mind.
Oct 07, 2009 | Safe International Digital Electronic Safe...
Printer will not charge camera batteries. camera screen said to go on line and look for m627-435
Did you go online and look up this troubleshooting tip from HP?  Did you make sure the batteries are rechargeable and in the correct orientation ( + and - )? Here is the results from looking up the error code M627-435 at the HP website:
Solution
  1. Ensure that the batteries are rechargeable. If the batteries are not rechargeable, replace them with rechargeable batteries.
  2. If the batteries are rechargeable, take them out and check for obvious physical damage. If the batteries are damaged, replace the batteries with rechargeable batteries in good physical condition.
  3. If the batteries are in good condition, charge the batteries using the external charger that shipped with the camera before using them in the camera for the first time.
  4. If you have tried each of the steps above and the status message still displays when you try to charge the batteries, replace the batteries.
Cause The Batteries cannot be charged status message is usually caused by one of the following:
  • When first connected to an optional HP AC power adapter or placed on an optional dock, the camera performs a test to determine if the batteries are rechargeable. If the test determines that the batteries are non-rechargeable, an status message displays in the LCD.
  • If the battery charge falls below 1.1 volts, the camera cannot detect that the batteries are rechargeable. The camera does not charge batteries below a 1.1-volt threshold to prevent charging non-rechargeable batteries. Rechargeable batteries discharged below 1.1 volts can be charged in an external charger.
    Apparently, your batteries are either seriously discharged where you need to use an external AC charger to recharge the batteries or their damagaed and need replacing. Hope this helps.
Oct 31, 2008 | HP Cameras
Toshiba Wireless Mouse PA3205U-1ETC Logo
80 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
