Question about Delstar DS 31024 MP3 Player
Cut driver opening package
I opened it with siccors and i cut the disc
  • Anonymous Dec 25, 2007
    Have delstar ds-31024. got it for x-mas but driver disc is damaged (cracked). Can i find a site where i can down load this.
Unless you are using windows 98 or ME you should not need the disc. It should recognize the device and install the correct driver on it own. The only other stuff on the disc is some mp3 utilities program which is crap anyway. I found nowhere to download anything for the player. Looks like Delstar has ZERO customer support.
Posted on Dec 26, 2007
SOURCE:
I cut the wire while trying to cut open the intense packaging to the headphone. How can I fix the wire?
Contact the maker of the headphones they might let you have a replacement if you explain why you damaged them.
Jul 22, 2011 | Skull Candy Audio Players & Recorders
PAG2200D angle grinder has 2 guards.One is a half guard,the other covers both sides of disc. Which one is used for grindins,which for cutting?
The double sided guard is the one for cutting and the single sided one is to allow you ot use the flat side of the disc for grinding. (Do not use cutting discs for grinding, on these discs use only the very edge of the disc and always wear protective eyewear and gloves. Never allow the stationary machine to rest on the disc, lay to rest with the disc facing upwards and disconnect the power lead when replacing discs etc. These are very dangerous power tools and should be treated extremely carefully).
May 26, 2011 | Saws
Invalid disc error
Most likely you need to replace the drive, they are very cheap on ebay. Here is how to replace it 1st power up and open tray then unplug. remove front of tray, it unclips at bottom, pull out and up then slides off. remove screws and take the entire drive out. Remove base plate of replacement drive and screw down into the two rear mountings. Remove facia of Recorder and cut out the three little pieces of moulding directly above where the tray drawer will be, this prevents the drive from being forced down at the front. With facia off fit the drive back onto the now screwed down base plate. Replace facia, connect drive power up and open drawer then unplug. On the drawer front cut off the centre small moulding because it doesn't line up with the cut outs in the drawer, the other two do, slide the front downwards onto the drawer then press at the bottom till it clips in. Job done. My 5005 now reads much faster and recognises all discs prior to this Invalid Disc on everything, cleaned lens and it would then only see pre-recorded films etc but no blank discs.
Mar 06, 2011 | Lite On LVW-5005 DVD Recorder
I cut the cd rom while opening the package how do I download the soft wear to use the product?
the software itself i don't know but the driver could be found here http://www.jascoproducts.com/support/software-downloads.asp and this will then allow the webcam to be used by most webcam using programs.
Mar 01, 2011 | GE EasyCam Webcam
Cut through DS Lite charger
Yes it's possible to sauder [if that's how you spell it lol] it back together, however there are many risks involved with a damaged wire -- electrical shock or damage to your DS Lite --the functionality of the charger is damaged at this point so it's not likely worth the try -- I would recommend returning it to the store.
Jun 26, 2009 | Nintendo DS Lite Console
DISC DRIVE KEEP OPENING
open our drie n u shuld ee a white bar at the front bottom of the drive just move it bak n forth a couple of timesthen put it back together n see if it works
Mar 23, 2009 | Microsoft Xbox 360 Console
Dishwasher door will not open.tried running it another cycle and still nothing.It is a GE profile with the latch that you just push in. The latch/handle seems stiff.
The plastic latch release inside the door handle is broken. Most likely one of the pins holding it in place has broken.
First go to your local dishwasher supplier and look at a similar brand (GE Profile in my case) and see how the mechanism works. Next, get a thin pair of siccors, pull the dishwasher handle down and slid the siccors into the opening above the handel and push the tab holding the door closed up so it will release.
Once the door is open, remove the inside of the door to get to the latch. Remove the plastic latch release and order a new one.
Sep 28, 2008 | Dishwashers
Dont know how to open my camera sd card and put pictures on disc
HAI, TO OPEN SD CARD DETAILS USE CARD READER , CARD INSERT IN TO CARD READER .OPEN MY COMPUTER AND THEN OPEN CARD DRIVER PROMPT.COPY OR CUT ALL PARTICULARLS IN TO YOUR COMPUTER .THIS PARTICULARLS ARE WRITE IN TO DISK THROUGH NERO OR ANY OTHER WRITING SOAFTWARES.
Jun 28, 2008 | Computers & Internet
Delstar DS 31024 MP3 Player Logo
Top Delstar Audio Players & Recorders Experts
Ekse
 Grubhead
Grubhead
Are you a Delstar Audio Player and Recorder Expert? Answer questions, earn points and help others
