Question about Boating
Cant find pictures of an Apelco 365 fishfinder? any body have an idea on where to look
Here is one on the cover from a VHS instructional tape showing the 265 and 365. Might be able to blow it up a bit and crop the 365 out....
http://ecx.images-amazon.com/images/I/51EAJS27Z5L._SL500_AA280_.jpg
And, you can go here:
http://www.raymarine.com/SubmittedFiles/Handbooks/Fishfinders/G627296www.pdf
for the 365 handbook to get some pretty fair drawings on the unit. I ran through the pages pretty fast and didn't see any photos but did run across a few drawings and illustrations.
Hope these help. If you can locate a former dealer for them, they might have some clip art from their coop advertising info.
Good Luck....
Posted on Apr 15, 2009
Somehow I have split the screen into two pictures of the same sonar reading. How do I get it back to only being shown on the one screen instead of being split into two.
Hi, press pages, then use the arrow up key to select sonar only page(it will show in upper left of screen the page you have selected.) Then press enter. Hope this helps, regards Phil.
Jul 20, 2011 | Lowrance HDS 5x Fishfinders HDS 5x...
Hi I have an Apelco 530 fishfinder/gps and need a through hull transducer kit. Apelco were taken out by Raymarine who advised me to contact Airmar who made the transducers. So far no answer but their...
Embedded
I was looking to see if I could find a replacement for the display and was able to confirm that the transducer is a single beam 120khz unit so I doubt that you've find a replacement for it ..as is .
The Airmar C-49 is the proper number for the connection line but like me I think your going to have to think about a whole new unit and or system . Been there already.
Best of luck.
Sir Isaac
Jun 22, 2009 | Raymarine Boating
I Have a Raymarine Radar RL70CRC HSB2 the
If both plotter works but they have no comunikation
RESET the RL 70 AND L760
This is how it works
press the powerbutton when you have picture press the menu bottom
than systemsetup and than four seconds the menu bottom.
Do this on both plotter normaly after this it works again
Jun 11, 2009 | Raymarine RL70CRC GPS Receiver
I require a Manual for a Apelco 365 fish Finder
Check out this site, on here they have a download for the manual you require,
www.retrevo.com/s/Raymarine-465-review-manual/id/556ci073/t/1-2/ - 52k - or go direct to www.raymarine.com
Regards
Alan Hood
ami-man
UK
Mar 12, 2009 | Boating
Raytheon --Apelco 365--fishfinder
For the information of future searchers, I add an OEM type repair that has just worked for me.
Go to the dollar store and pick up any audio lead that has a single narrow pin in the centre. Cut the plastic where the cable enters the plug to expose the end of the pin and wire connection. unsolder the plug and at the same time using the heat from the soldering iron, withdraw the pin from the plastic that is holding it in place. Now you have an unsoldered pin all on its own.
Remove the back from the Apelco 365 and unsolder the wire on the broken pin, (mine was just a push fit). Touch the broken pin with the soldering iron and withdraw it. Insert the new pin, heating it a little with the soldering iron. From the outside of the back case, check the alignment of the pin, making small alterations using a bit of heat. Once satisfied, apply a little dab of crazy glue to fill any gaps around the pin.
Job done. In future use a little Vaseline Petrolem Jelly on the female plug and make sure the plug is square to the back when you insert it, and lined up with the notch at the top.
Oct 15, 2008 | Boating
Apelco 365 fishfinder. Broken pin on power connector
i did the same damn thing and am amazed this question is on the net. i bought a new system but plan on taking it back. the 365 was a pretty nice model and i'm just going to splice it straight to the power supply. but i was lucky, the two pin connector is the damaged one so drilling it out and splicing it SHOULD be easy. well see. at this point i have nothing to lose.
hope this helps.
Jul 27, 2008 | Raymarine A65 Combo GPS...
Searching for wiring diagram
http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=420817e4b66b5093026515350edf12d2&q=Raymarine+Apelco+6760
heres the link to download manual it will have wireing diagram in it for you also i will be uploading the manual to fixya
May 20, 2008 | Computers & Internet
Problems with motorola e365
provide me with extra information about the download
i.e
r u using
a. bluetooth device
b.cable connection.
Feb 19, 2008 | Motorola Mobility E365 Cellular Phone
Boating Logo
262 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
