Question about Kenmore 44042 Front Load Washer
Does not drain & makes a loud buzzing sound(KENMORE 44042)
While i was doing a load of laundry i heard a sudden loud clanging/scratching sound coming from my laundry room. i ran in to see what it was but by the time i got there the sound had stopped so i thought nothing of it other than a possible zipper getting wrangled in the dryer. when my laundry was done i noticed that my clothes were still drenched in water.took out my clothes to see a pool of water in the drum that had not drained. i took the drain hose and put it over a bucket where the water then proceeded to drain out, thereby emptying the drum. i then ran my washer w/o clothes in it to test the cycle and see if it still did not drain. IT DID NOT DRAIN. while observing the whole cycle running,i noticed that it would at times make a loud buzzing noise that it never used to make. it seems that the times when water was supposed to be draining were the times that the buzzing sound would occur. what could be the problem and can i fix it w/o calling in a repairman? if i do call a repairman, can you guesstimate how much it would cost?
  • hartheaded Feb 01, 2008
    we used the washer for three months and the pump got plug with lint
    how can i prevent this from happening. we never touch anything because
    it was new and has warranty.
  • 21 Answers
When you get the buzzing try pressing the door hard when it is closed. Open the door and slam it shut hard. Examine the black projection on the door and the mechanism it fits into to see if anything is broken or it does not close well onto it.
Posted on Sep 13, 2007
  • 209 Answers
This sounds like something has gone into the pump, coins or whatever, the objects need to be removed, also check the hoses, remove the plug to work on any appliance the buzzing is the pump trying to work but unable to go round, start there and see how you go if i have helped rate me please
Posted on Sep 12, 2007
Lost user manuel. The washing machine (44042
bad news,mostlikely it's the spider gear and that means new washer time.using to much soap does this.it eats at the rear bearing and actually breaks it off and that's the sound you're hearing the basket has no rear bearing to ride on any more.you can first check to see if the shocks are broken,but most of the time the shocks break because the rear bearing is gone but check that first,i've found some with just a broken shock from overloading the washer.good luck and sorry to give you the bad news,the spider gear costs around 450 to 500 hundred bucks
Jul 25, 2010 | Kenmore 44042 Front Load Washer
Loud jet noise in spin cycle on Kenmore stackable top load washer
it is the drum bearing seal and it has gone out and ruined the bearings,you would need a lip seal kit and appropriate bearings for that particular unit,i do a lot of maytag front loads and it can take anywhere from 2 hours up to 8 hours depending how the old bearings come out and the damage to the bearing and seal surfaces,the sooner you get to it the less chance of severe damage it will cause,because water will kep on destroying bearings till they lock up and destroy the drive pulley
Mar 05, 2010 | Kenmore 44042 Front Load Washer
MY WASHER WILL NOT SPIN. iT MAKES A LOUD BUZZING
Sounds like a broken motor coupler for sure, the motor shaft will still spin the drain pump, but drive between the motor and transmission is lost. Part# 285753A. Have fun. If you need breakdown info let me know.
Dec 30, 2009 | Kenmore 22422 Top Load Washer
The machine is not spinning or tumbling, i went through the diagnostic test and that was the only thing it did not do. my understanding is that it is a belt that should be the problem how do i get at it?
I have the same washer and problem. I've had mine for just over five years with no problems, but I've had other top loading washers for as many as 12 years. I solved the problem with the Kenmore 44042 as follows:
1. Remove the washer from the laundry room and move it to the garage.
2. Go to Lowe's and purchase a Roper top loading washer for $300.
3. Install the new Roper in place of the Kenmore 44042.
4. Create and sign an agreement with yourself to never purchase another Kenmore product.
Sep 26, 2009 | Kenmore 44042 Front Load Washer
Dryer was running with full load of clothes. Heard a loud pop twice, ran back to the laundry room and smelled like something burning. Turned dryer off, and now it won't start back. Also, the very top of...
Well it sounds like a sound I have heard... forgetting that I had a cigarette lighter in my pocket and having it explode from the heat in the dryer. But you say you heard two loud pops?
Once everything cools down, check again and report back... does the dryer not turn on at all? Does the light come on when you open the door? Does it buzz when you push the start button? Stuff like that.
Jul 27, 2009 | GE DBXR463EDWW Electric Dryer
Top load washer machine will not agitate
Hi There,
Check to see that the belt is being driven by the motor when it goes into the wash cycle. Let me know if this helps and thank you for using FixYa!
Mar 10, 2009 | Kenmore 24902 Top Load Washer
KitchenAid washer Model#KAWS700jqsr fills but won't agitate
if it's making a loud buzzing noise while its suppose to be agitating or spinning its the motor coupling
Dec 20, 2008 | KitchenAid KAWS700L Top Load Washer
Washer not spinning or draining. Making LOUD grinding noise.
i started a load it aggetates but when it gets to next cycle it does nothing . i can hear timer switch to next cycle but it doesnt soin or drain .what can it be?
Nov 19, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Front loading wash machine
It sound like door lock unit is broken or removed from the door. Good luck !
Jun 17, 2007 | Kenmore 44042 Front Load Washer
Microwave makes loud buzzing sound when on and no heat
Have you tried putting a cup of water in it and cooking on a low power level? If it buzzes only when it is on the cook cycle, that would narrow it down. More detals might help us help you, including the model number.
Mar 20, 2007 | Kenmore 62622 Microwave Oven
Kenmore 44042 Front Load Washer Logo
316 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
