Question about Refrigerators
Whirlpool ed22tqxfw00...Ice maker not getting water to make ice... valves have been checked and are working, ice maker has been replaced with a new unit and is operating. All water supply lines checked and are clear of any blockage. Water supply is running to Valves. freezer is at a good operating temperature to make ice. I'm out of ideas other than trying to find electrical schematics for a possible bad connection?
  • 90 Answers
SOURCE: maytag mzd2766gew icemaker
Sounds like you have a bad motor module on the icemaker. Part # is W10122536
Posted on Jan 05, 2008
SOURCE: Ice maker not working
I replaced both silinoids and the ice maker. The ice maker will freeze water but not fill with water. My refridgeratoor is an a Amana
Posted on Mar 08, 2008
  • 1073 Answers
SOURCE: Ice from Ice maker smells
if the ice has been in the freezer ice bin for a couple of weeks or if you added any food to the freezer that is not totaly frozen before adding then the ice will absorbe the odor of the food added, also the defrost of the evaperator will also add to bad ice taste
a new filter for the ice maker is maybe needed, depending on how long it has been since it was changed
if it has been changed, youcan try this whirlpool tip
put a small pie pan in the freezer and one in the fresh food section
add 1/2 inch of fresh coffee not coffee grounds to each pan
leave in for 24 hrs
dump out coffee in the sink drain
repeat the process
dump coffee in 24 hrs
odor GONE
Posted on Apr 17, 2008
I have a whilpool Model # ED5FHXC001A side by side Energy Saver refridgerator. It was purchased late in 2006. It's not making and dropping ice. Any ideas what the problem may be? Thanks
Posted on Jun 28, 2008
  • 1122 Answers
SOURCE: Admiral Refrigerator Ice Maker
pull your icemaker tube out and see if it is frozen with ice,let me know-mike
Posted on Sep 22, 2008
Whirlpool ice maker will not fill with water
1st check to see if fill tube is frozen that goes through back freezer wall to feed water to ice maker. If it is, thaw it and replace water valve. If not frozen, then you must determine if water valve or ice maker is bad. You must determine if Ice maker is sending voltage to valve. If it is, replace valve. If it's not, replace ice maker.
Sep 03, 2017 | Whirlpool Refrigerators
Whirlpool ED5VHEXVQ03 side by side. Ice maker is not making ice. Checked water line - okay. Checked water valve - okay. Water filling tray - okay.
Whirlpool Ice Makers are about the hardest working part on your refrigerator and their average life is about five years. You can fill the tray with tap water if the ice slots are already empty and let the water freeze. If after the water freezes and the ice drops to ice bin then the water control valve.
Click Here=> 4389177 Water Inlet Valve will need replaced. You mentioned the water is filling the tray OK then my focus would be on the ice maker.
Click Here=> W10190965 Ice Maker Assembly
Most times it is less expensive to just replace the ice maker module. Here is a helpful video that helps explain everything about the Whirlpool Ice Maker below. If you find this solution helpful please rate my solution, Thanks Sea Breeze
Jun 29, 2011 | Whirlpool Refrigerators
Replace water inlet valve for ice dispenser with new. When icemaker cycles it dispenses through the water dispenser instead of tube going to ice maker. I have switch lines around but can only get water...
The ice maker is what tells the water control valve to open so it may be correct now and the thermostat in ice maker may be defective. Part 27 or 627985 down below where it says Whirlpool Ice Maker Parts Breakdown and in that photo is the ice maker thermostat. If your ice maker has been used for many years the complete ice maker may be better to replace. Ice maker Model=> 4317943
Or click here=>Point and Click Then enter model or part number into search feature. If you have questions please ask, Thanks, Sea Breeze
Whirlpool Model ED5GTFXKQ02 Ice Maker Parts Breakdown
Dec 17, 2010 | Whirlpool Refrigerators
Whirlpool refriigerator ice maker not working
With ice makers it is almost always one of two things. The ice maker itself, or the water valve. Figuring out which one is easy, and I will help explain.
First thing is the frig has to be cold enough for the ice maker to even start working. I'm assuming we have the cold part taken care of. Next, the machine will start a cycle and ask for water. Here is where the valve comes in. The ice maker energizes the valve and it opens allowing water to rush up the back of the frig and into the ice maker. After the ice freezes the ice maker goes into harvest and dumps the ice.
In conclusion, you either have an ice maker that stalled at some point during that cycle (in which case you need a new ice maker). Or the water valve is not opening, thus no water enters the ice maker and you get zero ice.
If you have ice in the ice maker and it is not dumping, you need a new ice maker. If it is empty, you have to either wait for it to ask for water or manually advance the ice maker into cycle so you do not have to wait.
At this point you will hear the water valve energize or not. If it never energizes, the ice maker is not working right, if it energizes and you get squat, the valve needs to be replaced.
If you have experience with a multimeter you could detach the harness going to the ice maker and simply hook up your leads. When the ice maker asks for water, you should get 110v reading on the meter. If you do, the valve is bad and needs to be replaced.
If I can be of any further assistance please let me know. good luck!
Oh, and the valve probably sells for between $50 and $100 depending on where you buy it. The ice maker should run between $100 and $180.
May 29, 2010 | Whirlpool GS5SHAXN Side by Side...
Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker stopped making ice
With ice makers it is almost always one of two things. The ice maker itself, or the water valve (valve is located on the backside of the frig, bottom right hand side almost 100% of the time). Figuring out which one is easy, and I will help explain.
P.S. There is a remote chance the filter needs to be replaced. An old filter can cause water pressure issues and you may not get enough water into the ice maker.
May 29, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
My kenmore side by side ice maker stopped working
Quick facts: If you have ice in the ice maker and it is not dumping, you need a new ice maker. If it is empty, you have to either wait for it to ask for water or manually advance the ice maker into cycle so you do not have to wait.
P.S. There is a remote chance the filter needs to be replaced. An old filter can cause water pressure issues and you may not get enough water into the ice maker. However, if you still get water through a dispenser (if you have one) then this cannot be the case.
May 26, 2010 | Whirlpool ED2FHEXN Side by Side...
Ice maKer is not getting water but the water side works.
Your refrig water valve , has 2 coils on one valve . One is for the water dispensor , and one is for the ice maker . So even if you get water thru the dispensor , the other coil ( for the ice maker ) could be bad . The fill tube from inside the freezer to the ice maker , could be frozen solid , keeping the water from entering the ice maker . This frozen tube , would be caused be the water valve " seeping " , which means , it isn't closing completely , and drips freezing inside the tube . indicating a bad water valve . Pour about 2/3 cup of water into the ice maker . If it dumps , but doesn't refill with water , replace the water valve but also check this tube . If the ice maker does not dump the frozen cubes , replace the ice maker , but also check the coils under the refrig , for dust , lint , etc , needing to be cleaned off . The ice maker needs to be 5 degrees to operate , and dirty coils can keep the freezer at 6 degrees or above .
Sep 15, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Probably the dual water valve (that opens when the ice maker needs water ) is leaking and the filling tube gets clogh with ice , or the valve doesn't work ,in both cases it has to be replace.
Aug 17, 2009 | Whirlpool Freezers
Overfilling ice tray with water
Does the water eventually stop flowing? If not, your solenoid valve is sticking open and defective. If you also have ice and water through the door, this is a dual solenoid valve. If it does eventually stop, your ice maker could be sticking in fill mode. Either way this could be a potential for a flood. I would recommend replacing both.
Dec 01, 2008 | Whirlpool ED2FHSS Side by Side...
Whirlpool gold ice maker problem
  • The refrigerator has a duel water valve, one for the ice-maker and one for the water dispenser (if equipped). The valve that the ice-maker relies on may be bad, or it could be the ice-maker itself.
  • Another thing that could cause it would be the temperatures in the freezer. The ice-maker will not call for water until it reaches under 15 degrees.
  • In addition, check the water tube behind the ice-maker to make sure it is not frozen, blocking more water from entering.
  • note: The water does not go to the ice-maker or thru the filter unless the ice-maker turns on the water valve.
Jul 05, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Refrigerators Logo
315 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
