Question about Kenmore 24 in. 17512 Built-in Dishwasher
Trouble removing filter
I own a Kenmore Ultra Wash Dishwasher, Model 17512. I suspect the filter/grinder may be clogged, as there is a black residue continually on the tub. The dishes are clean, but the black oily residue returns on the tub walls after cleaning. I have removed the spray arm. Found 3 torque screws, there is one screw I cant reach as it is located under a plastic. Is this one screw my problem? Should I force the filter to rotate?
4 Suggested Answers
aborcass
  • 2651 Answers
SOURCE: trying to take apart a Kenmore Ultra Wash 665
normal threading on the screw, trick is totry to hold the impellar, while trying to loosenthe bolt, sometine placing a screwdriver in form the side, allows you to hold it
Posted on Mar 07, 2009
  • 3 Answers
SOURCE: Kenmore 655 Ultra Wash- dishes not getting clean
Does the dishwasher drain the water properly at the end of the rinse cycle. Meaning, is there any leftover water at the bottom of the dishwasher.
Posted on Sep 20, 2009
SOURCE: dishwasher not cleaning - want to clean drain
We have a Kenmore 665.17702k600 Portable dishwasher with a similar problem. What we did was pop off the drain cover (turns out the one screw wasn't doing anything and just pushed down into the unit when screwdriver was applied). We popped it off by shimmying a screwdriver under the panel, and applying torque on the long end. It just popped right off. Then there was this nasty stale water, and not much obvious debri. We used a wet vac to slurp all that up. So that's the solution we took -- haven't tried it yet, so not sure if it will actually fix the problem...
Posted on Jan 23, 2010
Kenmore ultra wash dishwasher odor
Is the drain line going over an upper edge before connecting to the sink drain line? Also try to make a rinse with white vinegar.
Jul 06, 2015 | Kenmore Dishwashers
Kenmore model 665
Power off, check for clogs and if water supply to arm ok. Remove any build ups and reconnect. Good Luck.
Jul 23, 2013 | Dishwashers
MY DISHWASHER DOES NOT APPEAR TO BE CLEANING MY DISHES
Your sprayer arms may be clogged.
The upper arm attaches to a tube in the back of the dishwasher. If the support clamps come loose, the upper spray tube will not be flush with the tube and can't carry water to the sprayer arms. Also the sprayer arms can become clogged with paper remnants, bone fragments, or pieces of peeling. You'll need to remove the sprayer arm and flush it at your sink. If there is a jet that is clogged, tweezers will help remove the residue.
Finally, the bottom of the door INSIDE the washer often get covered with gunk. Be sure and gently wash the bottom of the door INSIDE. You can open the door, spray some window cleaner on the bottom and then gently brush away the 'gunk.' Rinse with hot water from a pitcher or your sink sprayer and this can eliminate some of the residue that is showing on your dishes.
I hope this helps. If it does, please come back to Fixya and rate my answer
Jun 11, 2011 | Kenmore PRO 24 in BuiltIn Dishwasher with...
I have a Kenmore Ultra wash 665.16522. The water won't drain completely. About 2 or 3 inches of water will stay at the bottom. I wonder if there is a food catcher, and if so, how do I clean it? JSBravo
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump. Also, check for any food pieces stuck near the pump impeller. Hope this helps... Please post back for any further assistance.
Dan
Mar 16, 2011 | Kenmore 16522 Built-in Dishwasher
Kenmore Ultra Wash dishwasher leaves spots on ALL dishes, top and bottom. Changed detergent, same problem.
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Feb 24, 2011 | Kenmore Dishwashers
We have a Kenmore Ultra Wash Dishwasher Model 15955781. We are now getting a white film on glasses and dishes are not cleaning. What is the problem?
heatman101
Dec 27, 2010 | Kenmore 24 in. 16352 / 16354 / 16359...
Residue on dishes and glass has cloudy film on Kenmore Ultra Wash dishwasher
The problem is hard water. www.dishwasherfilter.com has a product to solve this problem once and for all. It filters the water going into your dishwasher and removes the hard minerals that leave those spots. It is very affordable and even has a money back guarantee. You will love the way your dishes look with this product.
Aug 24, 2010 | Kenmore 24 in. 15932 Built-in Dishwasher
My Kenmore Ultra Wash II fills with water but doesn't spray.
i would suspect water mains problem, not enough water getting to the machine sometimes inlet get clogged with lime.adrian,,,,
Jul 13, 2010 | Kenmore 17024 Built-in Dishwasher
White film/residue left on dishes
This problem occurs due to excessive calcium build up inside the dishwasher. Try cleaning you dishwasher using a dishwasher cleaner. Dishwasher Magic is a good choice. works great.
Jun 18, 2009 | Kenmore Dishwashers
Kenmore 24 in. 17512 Built-in Dishwasher Logo
62 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
