Question about Cameras
N auto mode of shooting flash setting cant be changed in sony cyber shot model no dsc w-170
In auto mode of shooting flash setting cant be changed in sony cyber shot model no dsc w-170
  • 48 Answers
As long as you have a menu button on your camera you should be able to control these functions.turn the camera on in auto or manual. hit menu soon as the camera comes on,now you should be allowed to make any chages you choose.hope this helped.good luck
Posted on Apr 14, 2009
Sony Cyber-Shot DSC-P73 Digital Camera suddenly flash is not working
The flash may be broken.
If not these are the flash settings on the camera in case a different flash mode has been set accidently.
Set the mode dial to [camera icon], and press [up arrow] on the control button repeatedly to select a flash mode.
The flash mode has the following features.
No indicator (Auto):
The camera decides to use the flash based on lighting
conditions. The flash will be used when
there is not enough light or when shooting a
subject against a light source.
(Forced flash):
The flash will be used regardless of the amount of ambient light.
(Slow synchro):
light. In this mode, the shutter speed is
slower under dark conditions, so you can
clearly shoot a background that is out of the flash-lit area.
(No flash):
The flash will not be used.
Oct 18, 2014 | Sony Cyber-Shot DSC-P73 Digital Camera
Problem with the Sony Cyber-shot DSC-S730 Digital Camera Model DSC-S730 Camera flash is not working
You must verify how you set the flash: auto, on or off. Set it "on" and try it. If it not work so, it's out of service. In "auto" mode it's possible to not work sometimes because light sensor.
Apr 02, 2011 | Sony Cyber-shot DSC-S730 Digital Camera
How do i turn on the flash on the sony cyber-shot dsc t77
1. Touch the Flash (Auto) icon.
2. Select the desire option.
a. Flash Auto - auto flash when needed.
b. Flash ON - Flash always ON.
You can also refer the page # 12 and 23 of 108 in Instruction Manual of the Camera for detail information to turn on the Flash.
To download Instruction Manual check the link given below:
http://esupport.sony.com/US/perl/model-documents.pl?mdl=DSCT77
NOTE: You can not use the Flash when the Camera is set to Burst or Multi Burst mode. You can not use the Flash when the ISO or Twilight mode is selected in the Scene Selection. You can not use the Flash when mode dial is set to Movie also.
Good Luck!!!!!!!!!!!!!!!!!!!
Sep 06, 2009 | Sony Cyber-shot DSC-T77 Digital Camera
Sony cyber shot dsc-t70 unable to change flash setting
The Flash Off setting is fixed and cannot be changed if you are using one of the following modes:
  • High Sensitivity, Twilight or Fireworks Scene Selection
  • Burst or Exposure Bracket REC Mode
If you are using one of the above modes, change the setting to regain flash control.
NOTE: If using Scene Selection modes, the ISO setting is also fixed to ISO AUTO .
Aug 03, 2009 | Sony Cyber-shot DSC-T70 Digital Camera
Flash setting
On some shooting modes, you can not set the flash on. Try to change to other shooting modes, or just ATUO.
Jul 03, 2009 | Sony Cyber-shot DSC-W70 Digital Camera
My sony cyber super steadyshot model DSC-T70 flash does not work. Nosmile icon appears on the touch panel when shutter buton is pressed.
go into setup menu and turn on the smile detection. go to photo and press the right arrow should have a pict of flash icon . press until the flash says auto.
Jun 03, 2009 | Sony Cyber-shot DSC-T70 Digital Camera
Flash shows a triangle with an exclamation pnt "can not be chngd
the flash can not be forced on on some shooting modes, just try other modes(auto.etc)
Apr 10, 2009 | Sony Cyber-shot DSC-W80 Digital Camera
My DSC-T100 won't allow any changes to the flash setting.
The flash settings on the Sony Cyber-shot DSC-T100 are Auto, Forced Flash, Slow Syncro and No Flash, if it is not giving you a flash and wont allow you to change the setting you might have to talk to sony or the store you bought the camera from. One long shot would be that depending on what other features you are using on the camera, i could be set up to not allow you to change the flash settings in that "mode". Sorry if this is useless, but good luck and if all else fails use sony support! :)
http://esupport.sony.com/US/perl/select-system.pl?PRODTYPE=7
stupid hyperlink not working :(
Nov 21, 2008 | Sony Cyber-shot DSC-T100 Digital Camera
Sony cyber shot camera 2004
Perhaps you have set the camera to a record mode other than Auto. Twilight mode for example, does not activate flash so as to set the camera on a tripod and shoot dark landscapes.
Check your camera record mode, and use auto or portrait mode, which they usually activate flash when there is not enough light.
Hope this helps.
May 15, 2008 | Sony Cyber-Shot DSC-P92 Digital Camera
Flash problems
As you haven't said which shooting mode the problem occurs under (e.g. Auto, Scene etc) I can only suggest that you try different shooting modes to gain access to changing the Flash settings. Hope this helps.
Apr 29, 2008 | Sony Cyber-shot DSC-H9 Digital Camera
Cameras Logo
248 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
