Question about NetGear WGR614 Wireless Router
No disc for setup
I lost my disc 2 my wgr614 router. I am trying to set it up on a different computer. How can i go about doing this without a disc?
  • 854 Answers
Here are some troubleshooting steps that I suggest you try:
1. Check physical connections.
a. Connect the modem to the Internet port of the router. The Internet “i” LED on the front of the router should light up.
b. Connect the computer to one of the four LAN ports (i.e port 1, 2, 3 or 4) on the back of the router. The corresponding port light where you connected the computer should be lit up.
2. Access the router's web-based utility.
a. Please open any web browser like Internet Explorer or Netscape Navigator.
b. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field and click Enter or Return key.
c. A window will prompt for a user name and password. By default, the user name is "admin" and the password is "password".
Note: If you were unable to access the router's web-based utility, you may reset the router to restore the settings to factory default.
To reset the router:
a. Please push the reset button at the back of the router and release after 30 seconds.
b. Unplug the power adapter for 10 seconds and then plug it back in.
3. Configure the router.
If your Internet Service Provider is using a cable connection, please follow the steps below:
a. Click on Basic Settings under Setup tab.
b. Select No for Does Your Internet Connection Require A Login?.
c. Scroll down on the center page and look for the Router MAC Address section. Set it to Use computer MAC address and click on the Apply button.
If your Internet Service Provider is using a DSL connection, please follow the steps below:
a. Click on Basic Settings.
b. Select Yes for Does Your Internet Connection Require A Login?.
c. Select Other on the Internet Service Provider drop down box.
d. Enter your ISP's username (username@ISPdomain) and password. Then, click on Apply.
4. Configure the wireless settings.
a. Click on the Wireless Settings under Setup.
b. Change the SSID to any unique name.
c. Scroll down, look for the Security Options settings and select WEP (Wired Equivalent Privacy).
d. Set the Authentication type to "Automatic" and the Encryption Strength to "64bit".
e. Leave the Passphrase field blank, select Key 1 and enter a 10-digit number.
Note: The 10-digit number you typed in the key 1 will be the password or network key for the wireless connection.
f. Click Apply button to save the changes.
g. Go to Router Status under Maintenance tab and check if there is an IP address under Internet port. If it's 0.0.0.0, do a power cycle.
5. Power cycle.
a. Power off the modem, router and computers.
b. Turn on the power of the modem first and wait for it to initialize, the lights to stop blinking.
c. Power back the router and the computers. Check if it will be able to get online.
If you have wireless computers, you can connect them wireless to the router. Kindly follow the instructions below:
6. Connect wireless computer to the router.
If you are using Windows XP with Service Pack 1, please follow the steps below:
a. Please right click on the Wireless icon on the right lower end portion of your computer.
b. Then click on View Available Wireless Networks.
c. Click on the Advanced tab.
d. Please delete all the preferred networks then click on OK.
e. Right click on the Wireless icon again and click on View Available Wireless Network. Please select your network and click on Connect. It will ask you for the network key.
f. Please type in the network key and then confirm it. Network key is the password you type on the key 1 of the wireless settings of the router.
g. Make sure not to enable IEEE and then click on Connect.
If you are using Windows XP with Service Pack 2, please follow the steps below:
c. Click on the Change Advanced Settings.
d. Click on the Wireless Networks tab remove all the preferred networks then click on OK.
e. Right click on the Wireless icon then click on View Available Wireless Networks.
f. Select your network and click on Connect.
g. It will ask you for the network key. Type in the network key and confirm it. Then click on Connect. Network key is the password you type on the key 1 of the wireless settings of the router.
If you are using Windows Vista, please follow the steps below:
a. Click Start then select Connect To.
b. Connect to a network window will show up.
c. Select your wireless network and click Connect.
d. It will ask you for a network key. Type in the network key and confirm it. Then click on Connect.
From the above configuration, please check if you can now access the Internet.
Posted on Apr 14, 2009
I lost the pin number from my netgear router wgr614, now I'm trying two setup my new computer on a different internet provider, you can help me?
If you are on a new internet provider you will need to hit the reset button on the back (most likely a small object like a paperclip end will need to be put in and held for about 10 seconds or so), this will restore your router to its factory settings and your login will be whatever it was when you bought it, ( usually username is admin and password admin or blank). Then you will have to set up your router with the configuration settings provided by your new ISP.
Jan 06, 2011 | NetGear WGR614 Wireless Router
Trying to connect netgear wgr614v9 router to new toshiba computer with windows 7 ....setup says unsupported operating system....what do I do
As netgear setup disc doesnot support Win 7.
U need to manually setup the netgear product
-- hard resett the router using a restore factory setting hole on the back of the router
-- open the netgear router page using www.routerlogin.com
-- Username - admin , Password - password
-- run setup wizard
-- if it detects dynamic ip then press next
-- and on the left u will see wireless settings under setup .
-- secure the network using WPA_PSK(TKIP)
-- and then apply .
In case if it will detect static or fixed ip .
Then click on " Basic settings "
-- Under router MAC address
-- select "use computers MAC adress "
-- Apply
-- And then Powercycle the network..
-- And u will be able to go online ..
Jan 02, 2010 | NetGear WGR614 Wireless Router
No Setup CD
Are you trying to set up the router ?
You can do it without the CD. You can do it manually.
First make sure that your computer is able to go online when connected directly to the modem.
Then connect the modem and computer to the router and check the settings of the router.
Click Here for step by step solution
Nov 27, 2009 | NetGear WGR614 Router
Lost the smart wizard installation disc...how do
The wireless router can be configured without a CD by using the IE browser.
To connect to your wireless router, it needs the router’s wireless settings configured and also needs the wireless cards in all the laptops and or computers to be configured with the router’s wireless settings. Then the laptops and desktop computers can communicate with your wireless router.
To set-up and secure the wireless router from unauthorized access, follow these steps: -
1. Connect the wireless router to your computer with a LAN cable.
2. Start your browser and enter the router's configuration URL IP address. (http://192.168.0.1)
3. Enter the router setup, login and password (default login = admin
and the default PW = password)
4. Change the admin password
5. Go to the wireless settings and change the default SSID and turn off SSID broadcast.
6. Setup encryption key the strongest is WPA2 (if not then WPA).
7. For further security measures - turn on MAC address filtering and enter the MAC address of the wireless cards on the computer/s you want to connect to this wireless router.
8. Record the settings you have made and keep it in a safe place and Save the settings.
9. Configure the wireless cards on the computer/s with the SSID and encryption settings of the router.
10. Remove the LAN cable between the router and the computer then the computers should be able to connect to the router wirelessly.
Nov 20, 2009 | NetGear WGR614 Wireless Router
I have bought a netgear WGR614-6 wireless router for my pc ,on Virgin broadband , but I got no set-up disc. Can I download anything to make it work. I am computer-thick so please tell me in VERY simple...
You don't need the cd. You can configure the router through the browser. Here's the manual link. The chapter easy setup and configuration will help you set it up without the cd.
http://kbserver.netgear.com/pdf/wgr614v6_ref_man_20Apr05.pdf
(page 18 if in a pdf reader)
Nov 09, 2009 | NetGear WGR614 Wireless Router
Can't get the setup disk to setup. Says
No you just need a Vista 64bit driver. Try this download:
http://kb.netgear.com/app/answers/detail/a_id/784
Oct 04, 2009 | NetGear WGR614 Wireless Router
Lost connection with xbox360
1. Do you have a computer connected to the Internet?
2. if so, access the router's setup page and verify its wireless settings. Check SSID and the wireless security enabled into it.
3. Configure your xbox with the wireless settings in your router.
Oct 31, 2008 | NetGear WGR614 Router
Install netgear wgr614
Well which version of that router are you using - there are 9 different version of that model of router - you can find it most likely on the bottom of it on a sticker - find your version and here is a link to getting the manual for your versioin - the manual will tell you how to set it up by using your browser instead of the CD - if you have any problems then i can help you - just let me know. Thanks.
Sep 03, 2008 | NetGear WGR614 Wireless Router
I lost the cd to set up one of my computers...
You do not need the installation CD to install the router. The CD is just a convenience item for computer novices. Netgear does supply SETUP documentation for many of its routers that take you through the manual installation of them.
For the WGR614 router, the manuals for the different versions can be found here:
http://kbserver.netgear.com/products/wgr614.asp
If you have problems or do not completely understand the installation process, please do not hesitate to ask here or e-mail me.
Jul 14, 2008 | NetGear WGR614 Wireless Router
Lost intall disk
Well, i have set up several routers and they actually run better without the setup disk. as long as you know how to set it up, you it will work fine. (Setup disks tend to be over controlling of your network.)
To setup:
-Unplug your modem of all plugs.
-plug in your cable wire to the back of the modem.
-Plug in the ethernet wire from the modem to your router.
-Turn on the power(plug in) to your modem and give 2 mins.
Plug in ethernet cord from router to your computer.
-Plug in power to your router and give 30 seconds.
-power on your computer and give 1 min after start up.
-Make sure your internet is working and you are good 2 go.
Mar 23, 2008 | NetGear WGR614 Router
NetGear WGR614 Wireless Router Logo
80 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
