Question about Philips Televison & Video
Phillips magnavox This is a philips magnavox tv about 19 or 20''. manufactured 1995. slept with the tv on all night. woke up to turn of tv next morning and had problems turning it off then finally i got it of and it never turned back on again. i cant say its the cable because the cable box turned on just fine. I tried disconnecting everything and just plugging in the tv by itself to an outlet and it still did not turn on. model#pr1914c122, serial#45773449,chassis model no. 19p608-00AA I have a philips mag modle# pr1917c122 serial # 17570558 chassis modle # 19a800-7561 it was working fine and then it just did not want to turn on.There is no picture no volume. I change the batter on the remot did not work, check my cabel its working fine. I thing my T.V blew a feues or something. can any on help!!!
    Top Expert:
  • Philips Master
  • 41,667 Answers
Could be an open internal fuse or power supply failure
Posted on Mar 18, 2017
  • 308 Answers
SOURCE: Sony FD Trinition WEGA KV-32fs120 32" (no picture)
If the standby light is blinking 5 times then repeating, it is likely a problem in your picture tube or related circuitry. Other possibilities include the "Jungle" IC which takes care of the video, chroma and deflection processes and is a bear to replace. Either way, it could be an expensive repair.
Posted on Feb 11, 2007
MikeNJ1964
  • 398 Answers
SOURCE: television died
Unplug the set, remove the back and follow the power cord onto the main board, where you will see a small glass fuse. Replace that fuse with a new GMA 6.3 amp fuse. I have seen many of those fuses in Panasonics "pop" for no apparent reason. If that does not fix it then replace the back and have the set serviced by an experienced tech.
Posted on Jul 08, 2007
SOURCE: onkyo reciever (R550) and comcast cable box won't talk to each other
Having the same problem, Please help.
Posted on Apr 23, 2008
SOURCE: SANYO Model CLT2054 Television
same problem, sound no picture. took it off wall disconnected power and smacked it a couple of times. Plugged it back in and works fine
Posted on May 08, 2008
SOURCE: Unable to turn TV on at all
Thanks compro, a trip to Radio Shack and two bucks latter the TV is up again. I know it is a temp fix but I needed to keep it running till I'm able to get a Sony flat screen. This TV is one heavy piece of glass, also putting the rear cover back on can be a chore. I will talk to Panasonic tomorrow to let them know this is a common problem with this set, for what ever its worth..
Posted on Jun 01, 2008
Remote control phillips cl032
Please go to below website you can get the codes to programme your remote.
http://www.urc.philips.com/
Please select the below informations.
1. Location
2. Select your remote
3. On your left side you will have an option called as REMOTE CONTROL CODE FINDER.a76bc94.jpg
4. Select the device you need to programme and the make of the device you will get the codes for your device.
Thank you
Jul 29, 2010 | Philips Magnavox Learning Universal Remote
Hi Lost instructions. Would like to obtain how to program my Philips Magnavox remote. Don't know if the #2 MP#20C103-1 or the 1-0010 are the model #s. Thanks
Turn TV on, press and hold CODE SEARCH button until light comes on, press TV, the light will blink and remain on, enter the code, the light will go off, press POWER untill TV goes off....hope this was helpful...
Apr 23, 2010 | Philips Magnavox Learning Universal Remote
My tv won't go past channel 17
Please try this free Philips Flat Panel Television owners manuals, user guides & how to ... A B C D E F G H I J K L M N O P Q R S T U V W X Y Z ... 13" LCD-TV PF7835 - Philips 20" LCD-TV Product Brochure ... 13MC3206 - Magnavox TV/DVD Combination ...
tv.manualsonline.com/manuals/mfg/philips/philips_flat_panel_televis... - 674k - Cached
Aug 21, 2009 | Philips Magnavox 20MS233S 20" TV
I bought a 1995 magnavox at pawn shop today and a attenna but tv wont let me select vhs/uhf attenna mode so the tv just snowy do you know how i can get it onto vhs/uhf mode. I believe this is a phillips...
This would be VHS only that i know of if you do not have a remote to switch to the other side is what you need its available at www.remotes.com but I beleave this is VHS only. thanks
Aug 19, 2009 | Philips Magnavox MPD845
NEED CODES for my rca tv
I wish someone would bring a suit against any of these manufacturers using the term 'universal.'
At best, they are 'multibrand' and, with the proliferation of 'brands,' there never will be one that can rightfully claim to be 'universal.'
There may never be a code for your brand available in every remote.
Try searching the Philips site for a later code list and if that doesn't help, try the other Funai/Philips/Magnavox brands:
Funai, Symphonic, Sylvania, Emerson, Aventura, Durabrand, ESA, Magnavox, INSIGNIA, and Misakai
Aug 07, 2009 | Philips Magnavox Learning Universal Remote
Phillips Magnavox Proj. TV only makes cyclic chirping sound
Most common reason is shorted convergence chips. Goto the site www.TvRepairKits.com and get their "chirping set" repair kit.
Feb 01, 2009 | Philips Magnavox 9P6034C 60" Rear...
Phillips magnavox smokes
Replace the bad cap:
Capacitor C506 = 680pF 2kv = 483512247584 part number
Buy at tritronics by credit card: 800-638-3328
Oct 24, 2006 | Philips Magnavox 27MS343S 27" TV
Televison & Video Logo
188 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
