Question about Harley Davidson 426290 AM/FM Radio
Static on FM and AM
The CD works, AUX, CB, and Intercom. only the radio does not, I know its not the antenna it just scans once in a great while it may start working.
  • stanfordrand Apr 14, 2009
    The Radio is HD Part# 76330-03A
    HD Part # 76330-03A not 426290?
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • Harley Davidson Expert
  • 281 Answers
Surge protector in those early units may be shorted. www.ironcrossaudio may be able to help
Posted on Aug 17, 2009
My old unit stopped working;(worked perfect for many years) so I replaced with a new same model and I have bad interference and FM static. Sometimes the FM station overrides the express radio and all you...
The very first XM radios, (SkyFi2, MyFi, Roady2) up until they were put in red boxes, had a VERY strong FM transmitter, so strong, that when Sirius was their enemy, they complained to the FCC and they made the FM transmitters real weaklings. So unless you have one of the first two batches of XM radios, the FM transmitters now are real junk and you're better off using an AUX input on the radio or a cassette tape adapter. Okay? Thanks.
Mar 26, 2015 | Audio Players & Recorders
My Jensen MCD 5110 Marine radio acts like the antenna is unplugged. I can't figure out how to remove the radio from it's sleeve to re-plug the antenna jack (if that is the problem)
I don't know much about marine radios. I am a ham radio operator, but they are much the same, if you do not hear any static (with squelch control turned down), then I suspect you are correct about the antenna. It could be the antenna itself, or the coax line to it, or the connection point at the radio or at the antenna. You're stuck without being able to remove it. If you do and find nothing at the radio, you'll need to check the connection at the antenna etc. Good luck.
Nov 21, 2014 | Jensen Mcd5110 Marine Radio /am/ Fm/ Cd...
Pioneer cd player quit workin and i have static in radio could my fm modulator be bad and can that keep my cd player from working
Your modulator shouldn't effect the cd player. But it can cause static in your fm if you leave it on. Make sure the modulator is turned off before trying to use the regular fm. Also, if its a wired modulator, then check the antenna connections. If it's wireless than it should not effect anything. Depending on the radio, get a aux input on it. Wireless fm transmitters are the worst.
May 25, 2012 | Car Audio & Video
Lost the FM signal this morning, AM still works fine. all I get is static on FM with some intermittent what sounds like CB radio.
hello please check the rear of the radio as antenna could have come away from it hearing sounds like cb radio do you mean transmissions can you hear someone talking ,its probably someone near you that you are picking up
Mar 17, 2011 | Sony CDX-CA750X CD Player
I broke my cable that connects the antenna to the transever and my radio isn't working right all im getting is static and my s/rf meter is bouncing off the wall
contact the cb shop in temple, tx hwy 95&fm 93 google them cb shop temple, tx......
they have the lowest prices around. guaranteed
Nov 28, 2010 | Midland 1001Z 40-Channels Base CB Radio
HOW DO I GET RID OF STATIC IN MY STILETTO 2 CAR DOCK
First, you have to find out if the intereference is coming from your power supply or your FM radio. Are you listening to the Stiletto2 on your car FM radio? Is you car FM antenna visible? First try using a different FM frequency - that is the most simple fix. Second, if you car radio has an "AUX" input jack, use that to eliminate static. If the interference is from the car ignition, that is most difficult to eliminate, but you can try a clip-on ferrite ring on your power cord.
In summary, try a different FM frequency, 2nd, try using an AUX input cable, and if you've done either of those, then the noise may be in the power. Make sure to turn the AUDIO OUPUT level of the Stiletto2 all the way up so that your car radio won't have to be up so loud. Go luck, and let me know if this works for you. Happy New Year too!
JohnnyElectron
Nov 26, 2010 | Audio Players & Recorders
My Sony CDX-MP70 unit plays CDs and works on aux off my iPod but when I try to listen to am or fm it's nothing but static if I scan for a station it will just search forever, I took it apart but it all...
Check for a loose antenna connection, at the unit and where your antenna is attached to your car. Also, check fuses, some cars have 'powered amplified' antennas.
If those dont work, try resetting the unit. On most units there is a small pinhole behind the faceplate(not on the faceplate). Could also be the internal tuner has gone out...
Hope this helps
Aug 24, 2010 | Sony CDX-MP70 CD Player
Static on chevy 1500 radio
how many miles on the truck? when were the wires last replaced. They may look fine but have very small cracks in them causing interference
Jul 08, 2009 | 1999 Chevrolet K1500
Static
A simple monopole antenna tuned to the FM band should be almost 3 feet long. Notice that your Belkin box doesn't have that. When you touch the gooseneck, you couple some of the signal out your arm, and you become the antenna. Sort of.
Also, your car radio antenna is in a terrible position to receive it. It may even be on the roof of your car, which is great for receiving vertically polarized FM stations from far away but bad for receiving signals from inside the car, through sheet metal.
The other problem is that there are legal limits to what these gadgets can transmit. I had one that really stunk, and when I took it apart it had a spot labeled "ANT" on the circuit board, and with a 32 inch piece of wire attached, the power radiated was 20 dB higher ... that's 100 times as much. I picked it up almost 100 feet away. Your old one probably put out too much power.
Now if you wound a couple foot long piece of wire around your Belkin and fooled around with it a bit, you'd probably notice that the signal comes in nice and clear, because it takes the place of your arm grabbing the gooseneck. You could clip the other end somewhere where it wouldn't rattle around. But, you know, that could be ******* and folks in cars around you might hear it.
Apr 01, 2017 | Belkin TuneBase
Cb radio
You may be generating a harmonic from the cb that is picked up by the radio. Check if different channels and if AM/FM act the same. Also if a cd unit, does playing a cd produce the same effect. If all stations and the cd player do the same thing, interference is most likely coming in on the radio power or ground leads. You can get an inline noise filter from radio shack: http://www.radioshack.com/product/index.jsp?productId=2103979&cp=2032058.2032230.2032273&parentPage=family
or you can make your own if you have an old computer power supply by using the toroids if you can get to the power supply lead. Make sure the radio housing is electrically connected to ground. The interference may also be coming in on the radio antenna. Try moving the cb antenna away from it if possible, or test by rotating the cb antenna to a horizontal position temporarily.
Oct 26, 2007 | Radio Shack TRC-503 CB Radio
Harley Davidson 426290 AM/FM Radio Logo
179 people viewed this question
Top Harley Davidson Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Harley Davidson Audio Player and Recorder Expert? Answer questions, earn points and help others
