Question about Sony Computers & Internet
Sony Vaio computer not recognizing added RAM
Hello, I have recently put 4G of RAM into my Sony Vaio in place of the previous 2G of RAM. I bought 2 identical pieces like suggested and put them in correctly. My problem is that my computer is not recognizing the additional 2G of RAM, it still says that I only have 2G in there when there is actually 4G. What should I do so that my computer will recognize the rest of the memory?
  • 2 more comments
  • jmt3z4 Apr 14, 2009
    I have a 32-bit operating system, but my specs say that I can actually fit up to 4G into my computer on the Sony support website. It did say it would only max out from 3-3.5G but im not seeing that either. Im still seeing teh same exact amount of RAM as before I put the new 4G in? I dont know what else to do.
    I have 2 different slots. The RAM I bought was the suggested speeds and number of pins as recommended and matching. Each slot is able to fit 2G, a total of 4G capability. I have a Sony Vaio VGN-CR320 E/L model computer. I will try putting one 2G card in one slot and see if its recognized and do the same w/ the other card and message back.
    I have 4G (2x2) of Transcend 200pin ddr2 (800) so-dimm
    Alright, thanks for all the help, I was able to figure it out. I turned of the computer and switched and swapped them and it ended up working. I put each one in individually and separate then put them both back together and it ended up working. Thanks a lot man.
  • 2,229 Answers
First, do you have a 32-bit or 64-bit operating system. Unless you have the latter, you will only see 3GB maximum.
Second, did you look at the Sony specs (you didn't say what model you have)? Chances are your Sony maxes out at 2GB.
Posted on Apr 14, 2009
  • 1 more comment
  • Art Ellison
    Art Ellison Apr 14, 2009
    In my experience, there are several kinds (manufacturers) of memory that are just not compatible with computer brands.
    do you have 2 or 4 slots?
    Since you said you put 4 in place of 2, that seems like you have 2 slots. What happens when you populate just one slot?
    Do you see 2 GB?
    How about the other slot? Do you see 2 GB?
    There could be a memory setting in the BIOS, but not having a Sony, I can't say for sure. I'm assuming you got the right speed of memory. Some are actually interchangeable.
    You still didn't say which Sony you have, so I really can't help much by doing any independent research.
  • Art Ellison
    OK. And as I said, one unknown is the memory brand here.Kingston and Transcend are usually good. But I've had experience with lots of others.
  • Art Ellison
    Glad we got to the bottom of it.
    You're certainly welcome
    Problem Solver:
  • 12 Answers
Try updating your bios it might recognize the memory upgarde then
Posted on May 10, 2009
INSTALLED NEW RAM UPGRADE TO BOOST FROM 1G TO 2G COMPUTER DOES NOT RECOGNIZE NEW RAM STILL SHOWS 1G.
Make sure it is the correct ram for your computer. If you just added one ram chip then try swapping them and make sure they have a tight fit.
To test the new chip replace the old one with it and turn on your machine. If it doesn't see it then it is either bad or not the correct one.
Let me know how it goes.
Dec 14, 2010 | HP Compaq Presario SR2170NX (RK549AA#ABA)...
I have a dell dimension 4600. It has original memory cards installed. 2 256 MB for a total of 512 ram. I recently tried to install 1 GB memory card. When I start up computer it beeps several times,...
hello
several beeps in a system is caused by a memory issue -- If you've recently added or tried to add additional memory to the computer and have started getting these beeps. Remove all new memory you've added to the computer. If the computer works fine after removing the new memory you're encountering either an incompatibility or defective new memory.
Sometimes when the computer is moved and/or over time a memory stick can become loose causing the computer to be unable to read the memory or get errors as it's reading it. Try fixing this issue by opening the computer removing each of the memory sticks you have in the computer and then placing them back into the computer.
If reseating the memory did not resolve the issue try swapping the location of the memory. If you have only one stick of memory in the computer try moving it to another slot and then boot the computer.
If you have more than one stick of memory try removing all but one stick of memory and boot the computer. If this does not resolve the issue try removing that stick of memory and try one of the other sticks of memory.
the specs can be found at this link
http://support.dell.com/support/edocs/systems/dim4600/en/4600i/sm/specs.htm
the system you have is upgradable to 4G of RAM, and this RAM must be installed in equal pairs
so if you have 4 slots to insert memory in (assuming you will retain the 2 256M) , you must install the other slots by 2 512M, 2 1G or 2 2G DIMMs -- make sure you isntall exact same DIMMs, dont mix memory makers or specs, other than what Dell specifies
memory type must be
PC2700 (333-MHz) or PC3200 (400-MHz) DDR SDRAM
(non-ECC)
i hope this helps --
Dec 09, 2010 | Dell Dimension 4600 PC Desktop
I upgraded my memory RAM 2g and added 1g so it makes a 3G of ram but how come when my pc boot up up i can only see 2G ram single chanel. wen i go to my my computer----properties----general under computer:...
Could you please go online and in a search engine type "MAX RAM E-Machines (here put your model #)." Pick a link that secribes your maxi,um ram and if it's only 2GB you'll have your answer. If the max is higher there should be instructions on how to set the computer to acess and show the RAM.
Regards,
Selk
Nov 19, 2010 | E-Machines eMachines Desktop PC
Ram Installation more than 3G ex: (4G or 5G) will read 3.25 G How? i am using 2 units of KVR800D2N6/2G pulse 1G original>
Probably your Operating System is a 32bit. 32bit OS can only read up to 3GB of RAM regardless of the capacity of RAM you install. For example you installed 2pcs of 2GB RAM, that makes it 4GB in total, 32bit OS will only recognize 3GB. upgrade your OS to a 64bit OS and you can upgrade your RAM up to 8GB depending on how much your motherboard can handle.
Sep 15, 2010 | Computers & Internet
When I power up computer, I get 2 very rapid beeps, pause, 6 beep
it depends on the beeping
but i guess it's ur graphic card
make sure that the card is firmly in place and also check the memory modules.
Sep 14, 2009 | Sony VAIO RB30C (VGCRB30) PC Desktop
I am trying to add additional ram to an aspire 5315 with vista. when i start up. I cant get it running. What should I do to activate the second RAM slot? I am trying to upgrade to 4G by adding another...
my deskto acer no AC512. after re formating the pc i lost the sound and vdieo, and iam not having the original cd with me
How to re install the same?
Aug 24, 2008 | Acer Computers & Internet
Adding memory
Try re-seating the RAM. If that doesn't work ensure that your laptop supports the ram you bought. If the RAM you have is PC2700 and your computer only supports up to PC2500 (for example) it wont work.
Aug 19, 2008 | Sony VAIO FRV25 Notebook
Vaio startup problem
Ok, what is most likely wrong in that situation is that the computer is having trouble dealing with the new changes and may not like the new changes that have taken place so called, so what you would do is try and take the computer to a computer shop and tell them what issue your having with it and see if they can find a way to help you.
Jul 03, 2008 | Sony PCGFX120 VAIO Notebook
Sony Vaio-s460
probably arent fully seating the ram modules. push them into the slot until the little side levers close on their own.
May 17, 2008 | Sony VAIO VGN-S460 Notebook
Adding RAM
If it has 4 slots and supports 2Gb max with 2 slots currently populated with 2 x 256mb chips you'll need to remove both those chips and install 4 x 512mb chips to reach the max of 2 Gb.
May 10, 2008 | Sony VAIO RB30C (VGCRB30) PC Desktop
Computers & Internet Logo
171 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
