Question about SanDisk Sansa e260 MP3 Player
MY SANSA ISNT RECOGNIZED BY MY PC!
Im getting super mad and this darn popup keeps saying "found new hardware mtp device" and my mp3 is connected but the windows media player 11 says it isnt!! HELP
  • fathimashazm Apr 16, 2009
    My sansa e 260 mp3 isn't recognized by PC. So I cannot add/ delete songs.
  • acrazyone1 May 11, 2010
    Since when does Windows Media Player recognize MP3s?
    President:
  • SanDisk Expert
  • 652 Answers
Try connecting it to another computer and see if it will recognize it as sansa or removable drive. if it does then download the sansa update software and install it. Make sure you disconnect the sansa and connect it when asked. This will update your sansa and add the Usb Mode. Try to connect it to your computer at home it should recognize.... link for update software (http://mp3support.sandisk.com/sansa/Installer/1082/SansaUpdaterInstall.exe) download to a flash drive much easier Make sure USB mode is MSC I use my computer to drag and drop my music from my music folder to the sansa media folder.... Open my computer click on folder what ever folder has your music in it and drag to media folder and drop (click on the (+)where it say's sansa )
Posted on Apr 15, 2009
SOURCE:
Accidentally deleted everything on sansa e250 computer can't see device.
Hi there
I can understand issue. When you say the device is not detected. Then it could be an issue with the system files would have got deleted because of the format.
To fix this issue, i would recommend you to keep the device in MTP mode ( Menu->Settings->USB->MTP).
Connect the device to the computer.
It will give the message as Found New Hardware.
Go ahead and install the MTP drivers by following on screen instruction.
Then Unplug the device.
Restart the computer.
Connect the device.
Now we are offset and device will be detected.
IF still you have issue kindly revert..... Good luck
Feb 18, 2010 | SanDisk Sansa e250 MP3 Player
Player does not connect using MTP USB mode
Uninstall the MTP device in device manager to prevent the annoying problem of continuous pop-ups.
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Nov 30, 2008 | SanDisk Sansa e250 MP3 Player
Sandisk Sansa View isnt recognized by Windows Media Player
unplug mp3 player from pc
uninstall the Sansa software
reinstall the sansa software
replug the mp3 player
-Tha Mp3 Doctor
-Tha Mp3 Doctor
Nov 11, 2008 | SanDisk Sansa e250 MP3 Player
Help someone
-Tha Mp3 Doctor
Aug 04, 2008 | SanDisk Sansa e250 MP3 Player
MTP wont install
if that failed, why don't you do what it says and call the device manufacturer - i mean, really
just kidding
if you have Vista, forget about it
-Tha Mp3 Doctor
Jul 24, 2008 | SanDisk Sansa e250 MP3 Player
Sansa e250-MTP Driver
I would plug it into a different computer first, and see if you can get it working/recognizing - it rules out any USB related issues
Sansa has obsolesced this product - they took the driver off their website a few months ago
If you want to reacquire the MTP driver, then go to Microsoft website, and enter "MTP Porting Kit" - make sure you get the one for your specific OS - XP, Vista, etc.
Here are last ditch, desperation techniques to try:
-Tha Mp3 Doctor
Jul 04, 2008 | SanDisk Sansa c200 MP3 Player
Msc not recognized
-Tha Mp3 Doctor
May 30, 2008 | SanDisk Sansa m240 MP3 Player
Ipod has stopped working completely
-Tha Mp3 Doctor
Nov 15, 2007 | SanDisk Sansa e250 MP3 Player
Gone mad
-Tha Mp3 Doctor
Aug 08, 2007 | SanDisk Sansa e200 MP3 Player
SanDisk Sansa e260 MP3 Player Logo
169 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Ekse
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
