Question about Kitchen Ranges
Simpson 2001 electric oven and cook top. Fan in oven stopped working .It was noisy for a while then just stopped altogether. Can it be replaced?Can you give a service repairers contact in the sunbury macedon gisborne area in victoria aust.
  • 11,896 Answers
Yes the fan bearing are shot. They always make screaching/scratching noises before failing. There should be four bolts you can remove to pull off fan. You will have to remove rear panel of oven and remove inside racks for easier access.
You can find parts repairclinic.com or ApplicancePartsPros.com or www.simpson.com
I use repair clinic.com for all appliance parts.
Posted on Apr 14, 2009
I have a 'Simpson 2001 Thermaflow Oven' and a few months ago, i was heating it up, and i heard a pop, from then on my oven has not heated up, i cannot seem to find what is wrong with it!! Please...
I would say that the oven element has blown. It is common especially if you have a fan forced model. Make sure the fan works before you go buying a new element as the replacement will fail early. Simpson ovens have to be removed from the wall cavity to replace the fan and the element. Make sure you tuen the power off before doing anything...
Give the parts supplier your model number so that you get the fight element ( and fan) if necessary.
Jul 31, 2011 | Ovens
My Neff U1721 bottom oven has just stopped working - the fan still works, although is a bit noisy - what could be the problem/
Sound like the element has burnt out but if your fan is also noisy it is probley running slow which may have caused the element to overheat and burn out so it would be a good idea to replace the element and the fan motor
Regards
Ian
Apr 20, 2011 | Neff U1721 Double circotherm Electric Oven
Hi, I have a Electrolux EOG 900 builtin gas oven & gas grill, fan very noisy. Its 10 years old, willl the grill & oven pack in if the fan gives up altogether. Would it cost alot to fix. Hope to...
They won't pack up.. The fan is there to circulate the warm air. It might not heat up or cook as quickly as it used too. It will not cost much to fix though, labor will usually cost more than the part itself.
Good Luck
* If you found this solution helpful, please vote positively.
Feb 18, 2011 | Electrolux Ovens
Fan stops intermittently
If you are referring to the main oven fan, then that indicates it is failing.
It will only be a matter of time before it stops altogether.
Only solution is to replace the fan motor.
Please rate my solution.
Thankyou.
Jan 11, 2010 | Neff U1421 Double circotherm Electric Oven
I have lost my manual for a Simpson Appolo Atlas Stove
call manufactuerer and ask if you can order one or try to do so online
Dec 22, 2009 | Stoves EC500DOA Electric Kitchen Range
Oven switches on and off itself while cooking,
The element in the main oven switches on and off as it reaches the correct temp, this is supposed to happen, however, if you mean the oven is going off altogether, then I would suspect that it is overheating, and the safety stat is cutting the oven off.
Check to see if the top cooling fan is working o/k. because if it is not, then this will cause the prob.
Thanks.
Nov 10, 2009 | Hotpoint UY46 Style Line Stainless Steel...
Oven stopped working halfway through cooking. grill still works but top oven also stopped working
Sounds like to overheat device(s) kicked in. Is the background cooling fan still operating? i.e. that is the fan that continues to run for about 10 mins once everything on the device is switched off.
As well as hearing it, you should be able to feel a gentle draft of air coming out of the gap between the top and bottom doors.
Oct 04, 2009 | Stoves 720EF Electric Double Oven
Zanuisi top oven making noise
Yes , there is a cooling fan located at the top of the oven
It could be the fan blades catching, or a noisy fan bearing.
You would have to access it by removing the top oven cover to check., and yes it could be as a result of having it cleaned.
Plz rate my solution.
Thanks.
Dec 31, 2008 | Zanussi ZDF490 Electric Double Oven
Simpson 2001 series upright electric stove oven does not get hot only gets warm
It could be the oven element (behind the cover plate in the back of the oven), or the fan not blowing the heat into the oven.
Aug 19, 2008 | Ovens
Kitchen Ranges Logo
95 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
