Question about EA - Electronic Arts Need for Speed : Most Wanted
I can`t enter the repair shop-need for speed most wanted
When am driving at the free roam mode.. i can`t enter or get inside the repair shop or to upgrade my car even though am already outside the said shop.. help* Ty
  • Anonymous May 10, 2009
    Same as him
2 Suggested Answers
SOURCE: cant enter the repair shop
You're not supposed to do anything but drive around in free roam mode to learn where everything is at. If the problem persists and goes into the career mode then I would have your disc resurfaced. That might also fix any problems you are unaware of.
Posted on Jun 24, 2009
Reduced engine power
Have the vehicle checked for DTC'S - diagnostic trouble codes ! Do you know what electronic throttle control is ? The gas pedal assembly has electrical connector an sensors inside ,hooked to the PCM / ECM - engine computer . The engine computer uses these position sensors inputs to control the DC motor on the throttle body to open the throttle plate to control the speed . Plus there are position sensors inside the throttle body to input PCM/ECM to see if it's calculations are corect . Your best bet maybe to take it to a qualified repair shop .
Drive by Wire Function and diagnostics by Wells
Reduced Engine Power Mode
When the PCM detects a condition with the TAC system, the PCM may enter a reduced engine power mode. Reduced engine power may cause one or more of the following conditions:
• Acceleration limiting--The control module will continue to use the accelerator pedal for throttle control; however, the vehicle acceleration is limited.
• Limited throttle mode--The control module will continue to use the accelerator pedal for throttle control; however, the maximum throttle opening is limited.
• Throttle default mode--The control module will turn off the throttle actuator motor and the throttle will return to the spring loaded default position.
• Forced idle mode--The control module will perform the following actions:
- Limit engine speed to idle by positioning throttle position, or by controlling fuel and spark if throttle is turned off.
- Ignore accelerator pedal input.
• Engine shutdown mode--The control module will disable fuel and de-energize the throttle actuator.
May 12, 2017 | 2004 GMC Sierra Denali
How to remove roming option from sim
Hi Navya,
You may want to try this steps I have for you resolving your issue on roaming how to remove. Hope it helps.
First, press and hold the Power button for 2-3 seconds. Tap Airplane Mode. Wait for 1 minute. Press and hold Power button again. Select Turn off Airplane Mode. See if your phone will be normally or still get Roaming.
If not, turn off your phone. Turn it back on. Go to Settings->Wireless & Network->Mobile Networks. Tap to UNCHECK Data roaming. See if your phone will work normally.
Please let me know if this answer will work out. If does not work or you have any questions/concerns, do not rate yet! Click on Reply to Expert to reply so we can continue to work on this issue. Thank you!
If the icon is gone As long that you went inside the Mobile Networks settings and UNCHECK the Data Roaming box. That should work fine.
Apr 26, 2014 | Samsung Galaxy S Duos S7562 White Dual SIM...
My phone is saying digital roam mode when i make an outgoing call, how do i take it off so i can make outgoing call with no problem.
This is pretty much what you need to do. Just turn off all the roaming features. However when you roam it typically means you dont have service through Sprint so dont be surprised if when you turn off roaming capabilities your phone doesn't get ANY signal. Here's the link to your phones manual page 112 is about roaming.
Setting Roam Mode
Your phone allows you to control your roaming
capabilities. By using the Roaming menu option, you
can determine which signals your phone accepts.
Choose from two different settings on your phone to
control your roaming experience.
1. Press > Settings > More... > Roaming > Set Mode.
2. Highlight an option and press .
n Sprint Only to access only the Sprint network and
prevent roaming on other networks.
n Automatic to seek service on the Nationwide Sprint
Network. When Sprint service is unavailable, the
phone searches for an alternate service.
Call Guard
Your phone has two ways of alerting you when you are
roaming off the Nationwide Sprint Network: the
onscreen roaming icon and Call Guard. Call Guard
makes it easy to manage your roaming by requiring an
extra step before you can place or answer a roaming
call. (This additional step is not required when you make
or receive calls while on the Nationwide Sprint Network.)
To turn Call Guard on or off:
Call Guard.
2. Select On or Off.
To place roaming calls with Call Guard on:
1. From standby mode, dial 1 + area code + the
seven-digit number and press .
2. Read the message and press .
Note Call Guard is turned on by default on yourphone.
To answer incoming roaming calls with Call Guard on:
1. Press .
Data Roam Guard
Depending on service availability and roaming
agreements, yourphone may be able to access data
services while roaming on certain other networks. You
can set your phone to alert you when you are roaming
off the Nationwide Sprint Network and try to use data
services such as messaging.
To set your Data Roam Guard notification:
Data Roaming.
n Always Ask (default mode) sets your phone's Data
Roam Guard feature on. You will see a prompt that
will require you to respond anytime you access
data services while roaming.
n NeverAsk turns your phone's Data Roam Guard
feature off. Your phone will not notify you of your
roaming status when you access data services.
Touse data services when Data Roam Guard is active:
© When a notification appears informing you that data
roam charges may apply, press ROAM (left softkey)
to connect.
Note If the Call Guard feature is set to On, you need to
take extra steps to make and receive roaming calls.
Mar 08, 2011 | Sanyo SCP-2700 Cell Phone
T foreward or rewind. kicks out the tape.
You ether got a bad mechanism, something inside Kids like to stick coins/ Grilled cheese sandwich's in the mechanism instead of tapes or you had a band break.
I would say have it looked at by a VCR repair shop or have a look inside yourself for any objects that might be out of norm.
You will never believe what you find in these units specially if you got kids roaming the home.
Please do not forget to rate and leave feedback for your free answer today.
Thanks
Oct 21, 2010 | Sylvania 2870LV VHS VCR
I use msn Explorer as my Browser and email. I can also use internet explorer but prefer msn explorer. my Favorites (MSN6) File is corrupted. I have called msn to correct the problem and they cannot delete...
Click Start
Click Run
Type CMD
Press ENTER
Type CD \
Press ENTER
Type CD user name (whatever your 'user name' is)
Press ENTER
Type CD Application Data
Press ENTER
Type CD Roaming
Press ENTER
Type CD MSN6
Press ENTER
Type DIR /A
Press ENTER
You should see your "favourites" file, and maybe a few others.
Enter CD ..
Press ENTER
Enter RMDIR /S MSN6
Press ENTER
Enter 'y' to confirm that you want to delete the 'MSN6' folder.
Jul 07, 2010 | Computers & Internet
Cant enter the repair shop
Jun 08, 2009 | EA - Electronic Arts Need for Speed : Most...
I want cheat codes for this game called need for
  • Cheat mode Enter "!mr. blonde" as a profile name to unlock all bonuses and get $500,000. Note: There is a space in this code. You must still purchase the unlocked items.
  • All tracks, cop cars in Tuner Takedown mode, and $100,000 Enter "!get-set" as a profile name to unlock all tracks, cop cars in Tuner Takedown mode, and $100,000. -From: audiofreak39@adelphia.net
  • All cop cars in Quick Race mode Enter "!bacon" as a profile name to unlock all cop cars in Quick Race mode. -From: audiofreak39@adelphia.net
  • All performance and visual upgrades and $200,000 Enter "!tuner-well" as a profile name to unlock all performance and visual upgrades and $200,000.
  • Easy money Replay the Boss levels to get big cash bonuses.
  • Faster nitrous refill When you drive over 200 mph, the nitrous will fill up twice as fast.
  • Apr 09, 2009 | Electronic Arts Need For Speed Most Wanted...
    EA - Electronic Arts Need for Speed : Most Wanted Logo
    1,395 people viewed this question
    Top EA - Electronic Arts Video Game Consoles & Games Experts
    James Wishart
     Shayaan Tanwir
    Shayaan Tanwir
    Person On the...
    Level 1 Expert
    Are you an EA - Electronic Arts Video Game Console and Game Expert? Answer questions, earn points and help others
