Question about Mitsubishi WS-55411 55" Rear Projection Television
Mitsu WS-55411 RPTV-power going on and off..won't stay on!
TV just started having this problem a couple of days ago. Turned on TV and in a few minutes it went off by itself. After 20 seconds it came back on...and has continued to going "on and off". I disconnected power cord overnight. When I reconnected cord and turned on TV in the morning it stayed on for a couple of minutes and then started turning on and off again.
Is this a defective power module or is there something I can try before calling in repair?
Thank you.
    Genius:
  • 1,139 Answers
It is possible that the Low Voltage power module is defective, however I would first check the High Voltage power supply for bad capacitors (they tend to go bad first). In fact check both boards for bad capacitors (they will look puffy in appearance if they are really defective).
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Posted on Apr 14, 2009
  • Henry McKelvey
    Henry McKelvey Apr 14, 2009
    In addition, have the technician check the DM board, it usually has defective capacitors.
WS-55411 What seven capacitors need replacing? 2-3 code Problem
U check the power supply board,check all cap,and replaced it?Ur tv make buzzing noise when u turn on power?Ur flyback is dead.
Mar 17, 2010 | Mitsubishi WS-55411 55" Rear Projection...
Mitsu WS-55859---turned off & only powers up for 2 secs
2,2 is short protection.
98% chance the fuse or fuses (there are two 5 amp pico fuses) that protect the convergence circuit are blown. If you find F9AO4 OR F9AO5 on that board check them--if either is open the STK-393-110 DID IT.
Fairly short life for this chip if it was installed correctly and had heat sink compound applied to it--once in a while you get a bad one.
If this has helped you, rate this solution as I do this here for FREE.
sd tech
Nov 19, 2009 | Mitsubishi WS-55859 55" Rear Projection...
Mitsubishi 55411 projection tv has red band across bottom
go into the customer menu and select convergence with the original remote; if either the red or blue will not move in some direction, you have a bad convergence IC(the WS-55411 uses two STK-392-110 CONVERGENCE IC chips)
Aug 12, 2009 | Televison & Video
Mits 55908 Convergence problem
Good Day, John;
It sounds like the Convergence IC's have poor solder connections, by re-soldering the convergence output IC's should solve your problem. The IC's are large and mounted to large silver "heat sink" with STK 392 # on them. Good Luck, big IRISH.
Aug 29, 2008 | Mitsubishi WS-65809 65" Rear Projection...
TV not turning on after left on
ok 6 hours is not long but i would deffintly say u have a power issue now with the box inside over heated and burnt out will have to be prfessionaly replaced
Jul 18, 2008 | Mitsubishi WS-55411 55" Rear Projection...
4 pin or 6 pin
It has neither. It is not firewire capable.
Jul 17, 2008 | Mitsubishi WS-55411 55" Rear Projection...
Mitsubishi turns on for 3 seconds then shuts off..after power surge
try holding in the menu and input buttons together on the front panel for about 8 seconds to see if the self diagnosis feature will blink a two digt code then let me know what happens
Jun 05, 2008 | Mitsubishi WS-55411 55" Rear Projection...
Powers off
these set have lots of bad conections and have a problem with two bad caps in the 9 volt reg curcuit one is right behind the reg
Nov 03, 2007 | Mitsubishi WS-55411 55" Rear Projection...
Mitsubishi WS-55411 55" Rear Projection Television Logo
324 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
