Problemwith spacebar Good day, i havea problem with my keyboard. My spacebar doesn't works fine, 'cause i have to push just in the middle to work. If i push it in the sides, don't work. I have a Lenovo 3000 N200. Thanks for your help.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 133 Answers
If you take all those tiny screws out of the bottom of the keyboard you'll see a circuitboard with three copper "design" spots(usually 3) under the spacebar..........the ones NOT in the center of the spacebar are dirty. You could use some alcohol or acetone to clean the outside "designs".....(warning) Acetone will damage plastic!!!!!!!!
there are a lot of rubber caps that WILL fall out of place when you turn it over) (the actual keys could fall out too) (Be careful when you take off the bottom of the keyboard!!!!) Clean the ones that align with the SPACEBAR!!!! Dont touch or clean anything else that wasn't working....... Gently place the bottom back on and screw down the bottom cover with a cross pattern.....(left>right...top>bottom).....If this dosn't work....the best part is that a new keyboard........is fairly cheap....mtg
Posted on Apr 14, 2009
Asus intermittant spacebar
use air pressure in can for to clean the keyboard.. you can buy from radio shack or other electronic store. you can too reisntall the driver keyboard can be corrupted. Uninstall and reinstall the driver update from you supplier computer.God bless you
Apr 04, 2013 | Computers & Internet
Spacebar on keyboard makes my computer go to sleep mode
Sounds like your keyboard is sending the wrong signal (the one telling your PC to enter sleep mode) to your motherboard when you press space key, which (if true) would indicate it's faulty. It could also be you've contracted a virus and is playing a particularly nasty practical joke on you (let's hope that's all it does). Try connecting another keyboard to your PC and see if that helps. If it doesn't, then you'll need to clean your computer of any viruses. Try also disconnecting your mouse and see if that changes anything. If your keyboard comes with a shortcut utility software for it, run it and check there's no shortcut set on your keyboard's space bar. You've additionally specified you're not using wireless keyboard, but could you also please write what OS you're on?
Mar 23, 2012 | Compaq Keyboard
The far right and left ends of the spacebar do not work. In order to use the spacebar function, the direct middle of the button has to be pushed down.
You need to reposition (clip) the torssion bar under the spacebar key (a steel wire formed in a wide U shape), it is unhooked, call for a professionnal if you'r not sure how to do this as you may brake the plastic hinge if you don't know what you'r dooing...
Aug 09, 2011 | Toshiba 310CDT Keyboard
Hi my keyboard started working erratically a few days ago. it's an A4tech keyboard. and at first while using photoshop the spacebar stops working then I would have to reset it to have it start working...
It sounds like the keyboard is starting to you can try a different keyboard if you have one and it that works your keyboard is bad. If your other keyboard doesn't work to your port were your keyboard is plugged into maybe going bad, let me now if any of this helps.
Aug 02, 2011 | Compaq Keyboard
Spacebar on my Microsoft Natural Ergonomic Keyboard 4000 is sticking in the down position.
Take out the space bar button and change the position of the "sway bar" shown in http://www.paulstravelpictures.com/MS-Natural-Ergo-Keyboard-Sticky-Spacebar-Fix/index.html
There are 3 positions you can keep the sway bar - The middle positions worked for me and probably will work for you too.
Sumesh K
Jun 14, 2011 | Microsoft Natural Ergonomic Desktop 7000...
My spacebar is not working correctly it sticks and I really have to push it hard for it to work correctly
try flipping the keyboard upside down and see if anything falls out. if it still doesn't work your best bet is probably to just buy new keyboard. they aren't expensive.
May 13, 2011 | Computers & Internet
The spacebar on my HP pavilion dv3z drives me nuts. It only spaces when it hit it right in the middle. My usual movement hits the right hand side, and produces no space. Can I replace the keyboard? The...
If the system is out of warranty, you can replace the single offending keyboard key by going here to identify it. http://www.machinaelectronics.com/store/keyboardkeys/HP_Pavilion_DV9000_DV9000Z
If you don't want to get that involved, the only easiest solution is to replace the entire keyboard. Check to ensure that this part that should work with your laptop here:
http://www.machinaelectronics.com/store/buypart/HP_Pavilion_DV9000_DV9000Z/441541-001
Nov 12, 2009 | HP Pavilion dv9000z Notebook
Frustrating problem with spacebar causing skip
did you tried to clean the inside of the keyboard coz sometimes the dust is the cause why some characters not working properly.
Sep 16, 2009 | Computers & Internet
Mx3200 First the spacebar won't work andthenitworkstoowell.
did you check to make sure that the springs and bar under the spacebar are seated correclty?
Sep 30, 2008 | Logitech 967437-0403 Keyboard
Keyboard space bar
only two possibilities, first is the rocker springs at each end or the bar are causingit to not make contact. or the bubble switches under the keyboard. I had a similar problem on an inspiron 6400 and I had to VERY CAREFULLY remove the keyboard,then the button to reach the bubble switch which had lost the plastic bushing that covered the shorting contact, good luck given the insane price that dell wanted for a new keyboard fixing it myself was the option.
Jan 04, 2008 | Dell Inspiron 2200 Notebook
Computers & Internet Logo
625 people viewed this question
David Payne
David Payne
