Question about Frigidaire Affinity ATF8000FS
Frigidaire affinity irregular spin
Model ATF8000FS1, serial XC73818480, 15 mos. old. In perm press cycle, it does not spin after wash or rinses EXCEPT does do final spin, though sometimes not until the last minute after much sucking out of water. In normal cycle, it will sometimes spin after wash and rinse if it is happy with the size and balance of the load (one bath towel will throw it off). Final rinse same as perm press cycle. I have had to resort to forcing it to spin after wash cycle by stopping it and changing to spin only cycle. This is a 12 minute cycle and it often tumbles and sucks H2O for 11 minutes and finally spins for 3 or 4 more minutes. If it is in a good mood it will spin at around 6 mins. in that cycle. This is all frustrating and a big waste of time. No error codes have appeared.
  • rsprentall Apr 14, 2009
    You may be correct about control board problem. But it seems strange that I get no error codes.
    You asked about strange noises...it seems loud and "sucks" a long time when it is in drain cycle and this loud draining goes on for several minutes. It is also overly sensitive to weight and balance of the load. Thanks for quick reply.
    Thanks again, but are there any filters or hoses (other than the one drain line out the back) that are accessible on this thing? It is a stackable with the dryer on top. I assume that needs to come off to be able to get at anything. Probably will call the local Frig. serviceman, but I was hoping to be able to tell him what the exact problem was when I called.
    Top Expert:
  • Frigidaire Master
  • 74,945 Answers
THE OUT OF BALNCE SENSOR MAY BE DEFECTIVE AND PREVENTING THE SPIN CYLCE, ALSO THERE ARE MANY FAULTS THAT MAY NOT SET A TROUBLE CODE.
Posted on Apr 14, 2009
  • 11,896 Answers
I believe the control board is at fault. Your selector switch or the control board that sends information to the motor is not communicating due to technical errors. this is something that will most likely have to be repaired by a technician. Unless you have an error code. Do you have an error code or any weird noises?
  • Nate Stansfield
    Nate Stansfield Apr 14, 2009
    check your drains, filter and hoses for clogs. They to will cause same problems
Clean tub options keeps blinking on affinity frigidaire fafs4474lwo model
Hello Jodi, thank you for your post!
Your Frigidaire washer (FAFS4474LW0) will automatically prompt you to run the CLEAN WASHER cycle typically every 50 cycles. If you wish to begin the cycle, press SELECT when prompted. This maintenance cycle uses hot water and two rinses to remove residue that may cause odor. For best results, I recommend to use the CLEAN WASHER cycle once a month
You may press the CANCEL button to manually perform the cycle at another time if you prefer. You can do this by following these directions:
    ·Rotate cycle knob to Rinse & Spin
    ·Then press the CLEAN WASHER option button
    ·The LCD screen will display "SYSTEM CLEAN"
    Hope this helps! - Z
Jul 19, 2014 | Frigidaire Fafs4474lw Affinity 3.81 Cu Ft...
E47 and no spin cycle on ATF8000fs1
E47 error is for the door lock assembly. Here is the part to order.
Here is a video to show you how to make the repair.
Dec 06, 2012 | Washing Machines
I have a frigidaire front-loading Affinity model #atf8000fs1 washer with the stack kit placing the dryer on top. During the spin cycle, it dances frantically and when I canceled the cycle and opened the...
Go to www.repairclinic.com and enter atf8000fs1. You will see a list of common replacement parts (including the gasket) and may be able to view a generic Frigidaire video showing disassembly.
Apr 16, 2017 | Frigidaire ATF6000ES Front Load Washer
I have an affinity washer, stackable, model atf8000fs1, it runs for 15 minutes and quits, help
sounds like it has a bad timing cycle when it reaches that point the catch for the next cycle don't engage if this is the case the timer will need replacing i suggest contacting a service dept hope this helps
Aug 30, 2010 | Frigidaire Affinity ATF8000FS
The spin cycle is not functioning
electronical fault not motor but the controil unit is no working ok ....
Aug 30, 2009 | Frigidaire ATF6000ES Front Load Washer
Wont do spin cycle
sounds like a timer problem. contact a wholesale applaince parts distributor such as First Source. They will be more than happy to help you. You will need to provide them with make and serial no.
May 14, 2009 | Magic Chef CAV4000AWW Top Load Washer
Frigidaire washer machine stop in the middle of the cycle
Replace your lid switch.
The machine must have a goodd lid switch to continue timer functions after wash and rinse.
Feb 28, 2009 | Frigidaire FWS833A Top Load Washer
Frigidaire Affinity ATF8000FS Logo
164 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
