Question about iLO V27DMBX Television
Ilo 42" plasma
My ilo 42" plasma went to black and white. I can't find the manual and searching in the menu has not helped. What can I do?
SOURCE: ilo pdp4210ea1 now all black and white
V-Chip Factory code is not 0000 as it say in there book they put that # in, 8202 is the real Factory v-chip code
Posted on Sep 07, 2008
SOURCE: ilo 42"widescreen lcd tv
I hooked a sylvania 220sl8 dvd/cd/vcr, The vcr works, the dvd does not. Why?
Posted on Oct 18, 2008
  • 12 Answers
SOURCE: 42 inch ilo tv black picture sound only
If the fuse burned out the the tv would not turn on at all. When the tv is on is the back light still on? If its not its probably the back light that needs changing. If its on then its one of the circuit boards.
Posted on Jun 21, 2009
  • 1077 Answers
SOURCE: I have 42 in ilo plasma tv. I can turn tv on but
Most likely the TV has a Mother board related issue. Your TV is just like a computer. When it freezes up, nothing responds and you have to pull the plug to turn it off.
But, I can't say it's 100% the problem because I can't actually look at the tv over the internet.
If by chance the TV is still under warranty, go that route.
If not under warranty and If you have some electronic experience, if you can find and purchase a Service Manual over the internet; It will help you diagnose the source of the problem and fix it by soldering in the new part or replace the whole circuit board. The Service Manual will give you circuit diagrams, test points, and part# lists.Service manual cost about under $20. Most cases the new part cost less than $15. New circiut board, depending on type, may cost about $125.
I hope I shed some light on the subject for you.
Posted on Jul 08, 2009
  • 8457 Answers
SOURCE: my sanyo 42 plasma screen just went black..can hear it but
Ur Tuner Signal board it dead,must replaced this board.
Posted on Feb 06, 2010
  • 115 Answers
SOURCE: I own a viore 42 inch plasma tv I bought in 06
The x sus and the y sus boards need to be replaced. A chip popped off the back and what you hear is electricity arching over the chip. Very common on plasmas.
Posted on Aug 10, 2010
0 characters
1 Points
I have horizontal lines in black and white on the whole screen and tv will not turn off manually,the tv is an ilo 42 inch plasma.I only selected IBM because ilo was not listed
The problem is in the vertical section of your TV.Ethier it is loose connection or leaked capacitor or deffective vertical ic.Try to resolder first the vertical section.If did not work replace leaked capacitor around the vertical ic,then check the 12 v dc supply of vertical ic and final ok the rest is good replace vertical ic.
Jul 16, 2011 | Flat Panel Televisions
Jun 02, 2009 | iLO LCT32HA36 Television
Ilo pdp4210ea1 now all black and white
yes I can help you all you have to do is turn off the set and wait for about 30 minutes and then turn your set back on the problem should be resolved sincerely ,unplug the set firsthave a nice day
Jan 30, 2008 | iLO V27DMBX Television
Ilo 42" plasma tv model#pdp4210ea1
my 42" ilo plasma started going black on the outside to middle, now its totally black and no sound the power indicated lites for a min then the tv shuts off
Jan 10, 2008 | iLO 3200 32 in. LCD Television
I have suddenly lost the picture on T.V. but still hear audio of program...
sounds like your input board went out. I had the same problem on the ILO version of this panel. Got a replacement part off of Ebay. Search for Ilo plasma on ebay and it will come up
Sep 08, 2007 | Tatung P42BSKT 42 in. HD-Ready Plasma...
Ilo 42 in plasma
This must be a Samsung controller inside. Samsung controller have trouble finding if signal is ntsc or pal when tv is turn on before the source. If this is the case, just turn off the tv, start the cablebox and power on the tv again.
Jan 16, 2007 | iLO V27DMBX Television
Picture on 42 in plasma went black
No recharging....just recycling. ILO S-U-C-K-S !
Dec 28, 2006 | iLO 2600 Television
iLO V27DMBX Television Logo
160 people viewed this question
Top iLO Flat Panel Televisions Experts
Jaime Hernandez
Jim Goldsmith
Jim Goldsmith
Are you an iLO Flat Panel Television Expert? Answer questions, earn points and help others
