Question about Mitsubishi WD-52525 52" Rear Projection HDTV
TV has distortion very small on top and bottom which will flicker
It will flicker at the distortions at times where it will change colors and then go back to normal. The brightness doesnt seem as bright as it once was either. Please some suggestions. Some days works better than others.
    Novelist:
  • 159 Answers
This tv has two common problems:
in the power supply (set does distotions and shakes a lot etc very unstable until the set cannot work at all).
powerfully color gets back with a deep clean in the reflexion area. I'm sorry this job is for a technician, The set is so intricate for those two problems that any bad movement in this precision job could send the tv straight to wherever is bad.
Posted on Apr 17, 2009
Lines going through it and is very distorted
Search Results
    Troubleshooting Distorted Pictures - Stereo & Video Repair ...
    www.stereoandvideorepairco.com/.../DistortedPictureTroubleshooting.ht...
    Usually, this occurs on CRT projection TV's, and occasionally on CRT ... Dark, light, or colored bars can be seen rising slowly through the picture, ... Known as "hum bars" or "common-mode noise," these result from AC power line hum coming ...
    Flat Screen TV Has Lines Going Through Screen - Possible ...
    removeandreplace.com/.../flat-screen-tv-has-lines-going-through-screen-...
    Jun 17, 2015 - Flat Screen TV Has Lines Going Through Screen - Possible Bad ...inch LCD TV which is showing lines (vertically) and getting extremely hot. ..... If you leave the projection TV on for a certain amount of time does it ..... If so the plasma gas is most likely causing the screen to become distorted or color issues.
    Distorted Colors in an LCD Projector ' Business ...
    yourbusiness.azcentral.com/distorted-colors-lcd-projector-8597.html
Feb 08, 2016 | Televison & Video
JVC AV48WP30 Projection TV..Half picture distorted and flickering
Ur convergence is dead.Must replaced the 2 convergence ICS and all it resistors.The shop will cost U $300 for parts and parts.
Feb 10, 2010 | JVC AV-48WP30 48" Rear Projection...
My rca toshiba 50 inch projection tv is showing a 3d color curve
Need the model number to help as I am not sure of you have a RCA or a Toshiba
Dec 19, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Distorted picture on screen
Projection sets have two very common problems.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 28, 2009 | RCA P60920BL 60" Rear Projection...
My 36 inch RCA tv has black bars on the top and bottom of the screen. The color is also dark even in daylight scenes. Can you help with this color.
as a general rule, vertical faults can be divided into two types: ones that cause geometric distortion (a circle will not be round) and those that simply black out a portion of the screen. the former are faults in the vertical oscillator, drive, or output stages. the latter are blanking faults. blanking faults are almost always caused by electrolytic capacitors changing value and thereby changing the timing of the pulses which blank the screen during vertical retrace. In other words, the pulses are turning off the video signals at the wrong time. the most common true vertical fault is geometric distortion and a foldover of white lines at the top of the screen. this is almost always caused by the electrolytic capacitor on or near the collector of the vertical output transistor or part of the IC which has the supply voltage (B+) on it. In the old tube days, the general rule was that bottom distortion was in the cathode of the output tube and distortion at the top was caused by a fault in the drive circuit. this may help the solution!!
Mar 27, 2009 | RCA F36673ET 36" TV
The picture on my 2 yr old Toshiba 42hm66 DLP tv starts flickering and with alot of rainbow looking distortion after an hour of veiwing. I replaced the lamp, but it sill has the probelm. Any idea what...
I hope this helps you but you might wanna look into some other posts too cause it goes farther then the lamps and color wheels. Basically it's a bad product and the consumer should be fixing it. But your problem seems to be the color wheel. Or just a good cleaning. We replaced the lamb in ours and still had a color problem. We're gonna do an exstensive cleaning and dusting of our unit and if it don't work. We're going straight to the manufactor. This is enough with this product! It's costly to repair and still don't have the quality picture it should. It's more then a simple fix and too costly for ppl to just fix and move on. For how old these products are this all should not be happening.
Dec 02, 2008 | Toshiba 62HMX84 62" Rear Projection HDTV
Sony KP-53XBR35 TV Concave top & Bottom in wide screen, along with color distortion around sides
thats usually a convergence IC failure, Are you able to move the red and blue colors in the convergence adjustment menu?
Jul 14, 2008 | Televison & Video
Sony Bravia LCD Flickers/distorts
Wanna sell the tv for parts? Kev0201@yahoo
Sep 14, 2007 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Pictue problem
One of your convergence output IC's has burnt out and needs to be replaced. When the IC that handles the Red Vertical (RV) channel goes bad then a small low-value resistor usually burns out with it and the red color will sag inwards at the top and bottom. If you have no experience in repairing and realigning convergence circuits then allow a qualified tech to handle it for you.
Jul 07, 2007 | Toshiba 50H72 50" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
