Question about Panasonic DMR-EZ47V DVD Recorder/VCR
Error code RC3
When trying to use the remote I get an RC3 error code and the remote won't control any function.
I absolutely can't believe this worked for me, I'm so excited!! My error was RC3; my remote had an OK button (not Enter) for a Panasonic DVD/VHS recorder. I held down OK and the number 3 and the remote started working!! Thank you so much, I was getting very frustrated!
Posted on Jan 31, 2009
  • Joe L
    Joe L Jul 24, 2014
    If this does not work: (Manually) turn off the unit - Press and hold the POWER button then the "3" button - 5 seconds
Hold enter and push the error code number with enter and hole 5 sec. and the remote will function properly again.
Posted on Jan 15, 2009
  • Rick Sep 02, 2011
    Thank you very much ! I was pulling my hair out and I was about to go buy a new DVR. Thank You again !
I found the fix in the Guide book for my Panasonic DVD player (DMR-ES20). Push the Enter button and the # it indicates on the display (e.g. RC3) on the remote for at least 3 seconds. Fixed it!!! woohoo!
Posted on Oct 07, 2007
Had the same problem on new unit. Was getting ready to ship it back. This worked GREAT. Thank you so much. Great servive.
Posted on Jan 07, 2010
Thx
Posted on Jun 02, 2008
SOURCE:
GE 24927 Universal Remote Control - Black codes
https://elektrotricks.blogspot.com/
https://electrotechnician.blogspot.com/
https://electronicshelponline.blogspot.com/
https://homenol.blogspot.com/
https://remotesearch.blogspot.com/
Please visit these sites to get some details. Set-up code list and proceedings of many brand remote controls are given in detail.
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device./
Apr 18, 2018 | GE Televison & Video
I need the code for a Soniq T.V please.
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Programming Notes
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window" to get gathered related posts.
Jul 23, 2016 | Televison & Video
Error rc 1 but cannot engage the setup in order to follow instructions provided by panasonic
press and hold the numbered button
corresponding to the code on the
remote control simultanously with OK button for approx 10 secondes
ex: if rc1 appear on panel press number 1 and ok button on the remote for approx 10 sec. ( if RC2 press number 2, if RC3 press number 3)
Oct 06, 2013 | Panasonic DMR-EZ28K DVD Recorder
RCA Universal Remote
Check it with an other code. Then an other. Choose one code, that gives maximum functionality. This is a trial and error method. Never expect that a universal remote control will function to all the functions to a TV. If you wish to get more setup codes to check, visit this site, and pull up older posts there. Setup code list to many popular remote controls are given. Try other codes. Check these two sites.
Apr 25, 2013 | Televison & Video
Universal remote control code for prestiz tv
0257,0192,0221. Try these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name list" in alphabetical order. Pull up older posts.
Programming Notes
Search the site by type in the "brand name" to your device; that you want set-up code, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Dec 27, 2012 | Universal Remote Control Remote Control
I will program the remote the correct way, but still it won't program. When I'm done typing in the code for my ESA tv, I'll press the power twice and it'll turn off. Then I'll try...
Hello
Codes for ESA TV with RCA RCR312w are:
10812, 10171, 11963
1* Manually turn on the component you want the remote to
control.
2* Locate the enclosed Code Lists. Find the list for the
component you wish to program. Find your component's
brand. You will see a listing of four-digit codes for each
brand. If your brand isn't listed, use one of the Code Search
methods to program the remote control.
3* Press and hold the component key (TV,
VCR•DVD, SAT•CBL) you wish to
program. The illuminated ON•OFF key
turns on and remains on. If you release
the component key at any time during the Direct Code
Entry procedure, the illuminated ON•OFF key blinks four
times, and the process is exited.
4* While holding down the component key, consult the
Code Lists for the four-digit code that corresponds to your
component's brand and use the number keys (0-9) on the
keypad to enter it. While you are pressing the numbers, the
illuminated ON•OFF key turns off.
5* After the fourth number is entered, the illuminated ON•OFF
key turns on. At this time, release the component key. If the
illuminated ON•OFF key turns off, you have entered a valid
code and have followed the correct procedure for Direct
Code Entry
If you enter a code number that is not in the Code Lists or
you do not follow all of the steps for Direct Code Entry,
the illuminated ON•OFF key blinks four times when the
component key is released. This is an indication that a
programming error has occurred. In that case, repeat the
Direct Code Entry process from step 3.
Tip: Throughout the programming of each key, be sure to keep the
remote pointed at the IR sensor of the component you are currently
programming the remote to control.
6* To confirm that the component key is programmed with
the correct code for maximum functionality, test the
component. Attempt to control a variety of the component's
functions with the remote. If some of the features of your
components do not work, try programming the remote with
a different code in the list until you find the code that allows
the remote to control the majority of your component's
functions. Different codes can provide different levels of
functionality
Jul 08, 2011 | RCA RCR312W Remote Control
Samsung LN-T2353H Remote Control for Pace RNG110
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://homenol.blogspot.com/
Programming Notes
Jul 22, 2017 | Televison & Video
Panasonic DMR-EZ28 won't talk with remote
hi you need to reprogram the remote to fit with the unit there have 3 codes for remote 1 or 2 or 3 to reprogram your remote with the code indicated on your display press and hold the [3] and [ENTER/OK] buttons together for approx 5 to 10 seconds, then release
Jun 24, 2009 | Panasonic DMR-EZ28K DVD Recorder
Remote control
re-sync remote by pressing "enter"/"OK" while holding number "1" or "2" or "3" - the proper number should be displaying on unit as RC1, RC2, or RC3
Mar 31, 2009 | Panasonic DMR-EZ47V DVD Recorder/VCR
Dvd recorder remote control
Anytime your unit displays RC1, 2, or 3 - the remote code needs to be reset. Other messages are "chk remote n" or "set n", n being the number 1, 2 or 3. These remote codes are set in case you have multiple products that interact w/ the remote - so when operating one device the other doesn't interfere. Unfortunately, every now and then for completely unknown reasons, they can slip out of the proper code. All you have to do (if your remote is, in fact, functional) is press and hold the number on the remote that corresponds with that which displays on the unit - in your case the number 3, and hold the Enter key at the same time for about 5 to 10 seconds. This should resume operation shortly thereafter. However, you will not see any confirmation on the display as you are performing this reset. It is trial and error.
Jan 28, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
Panasonic DMR-EZ47V DVD Recorder/VCR Logo
2,540 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
