Sony Handycam DCR-HC30E Mini DV Digital Camcorder Logo
Posted on Sep 12, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Recording problem i have all manues but when i record i got the black screen both in LCD as well as view finder
Anonymous
Level 3:
  • Master 752 Answers
  • Posted on Sep 12, 2007
Anonymous
Master
Level 3:
Answers
752
Questions
0
Helped
393272
Points
1932
Your CCD imager chip is damaged. Will require repair between $100-300 depending on shop.
The problem i m having with my camcorder is when i want to record film screen goes blank but i can watch my previous recorded videos
Look in the view finder when recording instead of the screen. if you see the image there then the unit is probably set to look through there. Many of the new units dont' have a full view finder to lens item they actually have a small lcd screen inside the view finder. Check your options for recording.
Also if the view finder is tilted you need to close that before usign the lcd.
The image will not appear simultaneously on the LCD
monitor and the viewfinder. It will appear in the
viewfinder when the LCD monitor is in the lock position,
and it will appear on the LCD monitor when fully
extended.
3helpful
Viewfinder and LCD screen only show black and record black
If camcorder shows old recorded tapes picture with correct colors in LCD but does not show live view in camera mode to record new movie then its ccd imager chip failure.
And if camcoder shows live view and old recorded tapes in its eye piece view finder but does not show any thing in LCD the its problem of broekn/ cracked flexible wire between lcd board and main board of camcorder.
Let me know your finding with bit detail to provide you solution/ helpful info.
Black LCD screen but Lens view & record fine
It is possible you have turned the LCD screen off - Go to the settings in the camera and reselct the LCD Screen on.
May 11, 2009 • Cameras
No picture on lcd & view finder
PLease see http://www.fixya.com/support/t131881-sony_cam_recorder_wont_record for more information on this i have had the same problem, faulty CCD image processor chip.
Sound but no picture.
if you are able to playback previously recorded cassette and the picture is perfect then its not the head. then the problem is with the image grabbing section i.e. the CCD. May be its damaged and needs replacement.
3answers
Black LCD and view finder
you need to go to the service center for replacing the ccd image sensor...i know it is free for replacing that image sensor cause your camera is one of the recall product due to the production error of the image sensor...log on to the sony site and go the costumer service ...
Black screen
it's a bad ribbon to the ccd have to send in pretty common problem
2answers
Camera mode recording/displaying right
what is the model number? if it's 10 years or older you are most likely dealing with bad surface mounted capacitors.
Nikon coolpix 5700
at the back of the camera next to the view finder (bottom right hand corner) is a button and icon marked SEL. pressing this button toggles the lens image from the view finder to the lcd screen and back again. IF neither view is available then I suspect your camera needs some TLC at a repair shop. hope this helps.
No Picture in LCD or Viewfinder
Hello, please contact the Authorized Sony Service for Sony recall action. If you need more info please advice.
Top Sony Video Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
